Duet 3 mini 5+ connecting fans
1.1k
    Alucardi
    Trying to figure out on how to connect fans. I just have 2 cables. Which pins do i use? I tried V_OUTLC1+ and OUT3-. Should i connect V_OUTLC1+ to out4.tach instead?
    While i typed this message i just saw out 5-6, should i use them instead?
    undefined 1 Reply Last reply 17 Jan 2021, 23:25 Reply Quote 0
      Stephen6309 @Alucardi
      @Alucardi I use OUT5 and OUT6 for two wire fans on mine. Make sure to set the voltage jumper for what your fans need.
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87?lang=en
        Specifically steps 10 and 11.
          Alucardi
          well there is something wrong cause it keeps burning my fans now. I killed 3 fans! WTF it was working fine last night but now out of the blue it kills my fans. I had 3 12v blowers and 2 cooling fans all dead. Even tried pc fan and it died to. What can i can?
          undefined 1 Reply Last reply 18 Jan 2021, 11:01 Reply Quote 0
            Veti @Alucardi
            @Alucardi
            are you sure you changed to jumper to 12v? 24v will burn out the fans.
            undefined 1 Reply Last reply 18 Jan 2021, 11:18 Reply Quote 0
              Alucardi @Veti
              @Veti no. I must have miss read. I read it as 5-6 was set on 12v and 3-4 was vin but it was the other way around 🤷‍♂️
              I do have a few 5v blowers. I also have a bukconverter. Can I just pull power from that? If so do I just connect plus to the converter?
                Veti
                thank you for running the test.
                i always wondered how long 12v fans would survive on 24v.
                so apparently not long.
                undefined 1 Reply Last reply 18 Jan 2021, 11:26 Reply Quote 0
                  Alucardi @Veti
                  @Veti lol not even a second! Btw can I just connect the + to a buck converter and run that on 5v and - to OUT6? Cause I have several 5 volt blowers but no more 12v.
                  undefined 1 Reply Last reply 18 Jan 2021, 11:33 Reply Quote 0
                    Veti
                    that should work, but it would be best if someone else can confirm this works on the mini as well.
                      Alucardi @Alucardi
                      @Alucardi said in Duet 3 mini 5+ connecting fans:
                      @dc42 can you confirm?
                      undefined 1 Reply Last reply 18 Jan 2021, 12:12 Reply Quote 0
                        dc42 administrators @Alucardi
                        Yes, that would work,. However, as well as blowing the fans, it's quite likely that you have blown the fan mosfets on those outputs.
                        undefined 1 Reply Last reply 18 Jan 2021, 12:13 Reply Quote 0
                          Alucardi @dc42
                          @dc42 i tried them with a pc fan and it was fine.
                          undefined 1 Reply Last reply 18 Jan 2021, 12:14 Reply Quote 0
                            That's good news!
                            1 out of 13
