    After update 2 v3.2 no response
    Firmware installation
    1.5k
      I suppose that's possible, but I'm not sure.
      When you're in standalone mode please send M122 and M122 B1 (B2, B3, etc for each expansion board you have) and report the results here please.
      ahwitmerundefined 1 Reply Last reply Reply Quote 0
        You can then use M997 B# to update the expansions.
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M997_Perform_in_application_firmware_update
        To ensure all the right firmware files are present, upload this zip file to the system tab first.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        • ahwitmerundefined
          ahwitmer @Phaedrux
          @Phaedrux Okay performed
          Result:
          MAINBOARD
          M122
          === Diagnostics ===<LF>
          RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)<LF>
          Board ID: 08DJM-956L2-G43S4-6J1D8-3SJ6M-9B6GG<LF>
          Used output buffers: 1 of 40 (20 max)<LF>
          === RTOS ===<LF>
          Static ram: 149788<LF>Dynamic ram: 94936 of which 164 recycled<LF>
          Never used RAM 113944, free system stack 166 words<LF>
          Tasks: NETWORK(ready,183) ETHERNET(blocked,118) HEAT(blocked,293) CanReceiv(blocked,848) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1121) IDLE(ready,19)<LF>
          Owned mutexes: USB(MAIN)<LF>
          === Platform ===<LF>
          Last reset 00:18:26 ago, cause: power up<LF>Last software reset details not available<LF>
          Error status: 0x00<LF>
          Aux0 errors 0,0,0<LF>
          Aux1 errors 0,0,0<LF>
          MCU temperature: min 38.3, current 39.6, max 39.6<LF>
          Supply voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes<LF>
          12V rail voltage: min 11.3, current 11.4, max 11.4, under voltage events: 0<LF>
          Driver 0: position 0, standstill, reads 712, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 1: position 0, standstill, reads 713, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 2: position 0, standstill, reads 712, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 3: position 0, standstill, reads 712, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 4: position 0, standstill, reads 712, writes 0 timeouts 0,
          Driver 5: position 0, standstill, reads 712, writes 0 timeouts 0, SG min/max not available<LF>
          Date/time: 2021-01-20 19:55:07<LF>
          Slowest loop: 130.25ms; fastest: 0.05ms<LF>
          === Storage ===<LF>
          Free file entries: 10<LF>
          SD card 0 dete
          cted, interface speed: 25.0MBytes/sec<LF>
          SD card longest read time 3.5ms, write time 0.0ms, max retries 0<LF>
          === Move ===<LF>
          DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000<LF>
          === MainDDARing ===<LF>
          Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>=== AuxDDARing ===<LF>
          === Heat ===<LF>
          Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1<LF>
          === GCodes ===<LF>
          Segments left: 0<LF>
          Movement lock held by null<LF>
          HTTP is idle in state(s) 0<LF>
          Telnet is idle in state(s) 0<LF>
          File is idle in state(s) 0<LF>
          USB is ready with "M122" in state(s) 0<LF>
          Aux is idle in state(s) 0<LF>
          Trigger is idle in state(s) 0<LF>
          Queue is idle in state(s) 0<LF>
          LCD is idle in state(s) 0<LF>
          SBC is idle in state(s) 0<LF>
          Daemon is idle in state(s) 0<LF>
          Aux2 is idle in state(s) 0<LF>
          Autopause is idle in state(s) 0<LF>
          Code queue is empty.<LF>
          === Network ===<LF>
          Slowest loop: 3.19ms; fastest: 0.02ms<LF>
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          Telnet(0), 0 sessions<LF>HTTP sessions: 1 of 8<LF>
          • Ethernet -<LF>
            State: active<LF>
            Error counts: 0 0 1 0 0<LF>Socket states: 2 2 2 2 2 0 0 0<LF>
          === CAN ===<LF>
          Messages queued 1603, send timeouts 0, received 4818, lost 0, longest wait 120ms for reply type 6024, free buffers 48<LF>
          ok<LF>
          EXPANSION BOARD 1
          M122 B1
          Diagnostics for board 1:<LF>
          Board EXP3HC firmware 3.1.0 (2020-05-15b1)<LF>
          Never used RAM 163.4Kb, max stack 352b<LF>
          HEAT 1088 CanAsync 1452 CanRecv 1420 TMC 156 AIN 524 MAIN 2208<LF>
          Last reset 00:18:34 ago, cause: power up<LF>
          Driver 0: standstill, reads 28888, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 1: standstill, reads 28888, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 2: standstill, reads 28887, writes 0 timeouts 0, SG min/max not available<LF>
          Moves scheduled 0, completed 0, hiccups 0<LF>
          VIN: 23.8V, V12: 12.2V<LF>
          MCU temperature: min 38.2C, current 38.4C, max 38.4C<LF>
          Ticks since heat task active 229, ADC conversions started 1114472, completed 1114472, timed out 0<LF>
          Last sensors broadcast 00000000 found 0 232 ticks ago<LF>
          Free CAN buffers: 36<LF>
          NVM user row de9a9239 aeecffb1 ffffffff ffffffff<LF>
          ok<LF>
          EXPANSION BOARD 2
          M122 B2
          Diagnostics for board 2:<LF>
          Never used RAM 163.3Kb, max stack 368b<LF>
          Last reset 00:18:38 ago, cause: power up<LF>
          Driver 0: standstill, reads 596, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 1: standstill, reads 596, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 2: standstill, reads 596, writes 0 timeouts 0, SG min/max not available<LF>
          Moves scheduled 0, completed 0, hiccups 0<LF>VIN: 23.7V, V12: 12.2V<LF>
          MCU temperature: min 40.2C, current 40.4C, max 40.6C<LF>
          Ticks since heat task active 19, ADC conversions started 1118012, completed 1118012, timed out 0<LF>
          Last sensors broadcast 00000000 found 0 22 ticks ago<LF>
          ok<LF>
          EXPANSION BOARD 3
          M122 B3
          Diagnostics for board 3:<LF>
          Never used RAM 163.3Kb, max stack 336b<LF>
          HEAT 1080 CanAsync 1452 CanRecv 1420 TMC 156 AIN 524 MAIN 2184<LF>Last reset 00:18:44 ago, cause: power up<LF>
          Driver 0: standstill, reads 6405, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 1: standstill, reads 6404, writes 0 timeouts 0, SG min/max not available<LF>
          Driver 2: standstill, reads 6404, writes 0 timeouts 0, SG min/max not available<LF>
          VIN: 23.9V, V12: 12.2V<LF>
          MCU temperature: min 39.1C, current 39.2C, max 39.4C<LF>
          Ticks since heat task active 241, ADC conversions started 1124234, completed 1124234, timed out 0<LF>
          Last sensors broadcast 00000000 found 0 244 ticks ago<LF>Free CAN buffers: 36<LF>
          ok<LF>
          CoreXYUV
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in After update 2 v3.2 no response:
            Did you do this?
            • ahwitmerundefined
              ahwitmer @Phaedrux
              @Phaedrux
              Good evening, yes I did!
              Results:
              M997 B1
              Board 1 starting firmware update<LF>ok<LF>
              M115 B1
              Duet EXP3HC firmware version 3.2 (2021-01-05)<LF>ok<LF>
              M115 B2
              Board EXP3HC firmware 3.1.0 (2020-05-15b1)<LF>ok<LF>
              M997 B2
              Board 2 starting firmware update<LF>ok<LF>
              M115 B2
              M997 B3
              Board 3 starting firmware update<LF>ok<LF>
              M115 B3
              CoreXYUV
                Ok that's a good sign. Now that we've confirmed that your mainboard and expansions are all working correctly in standalone mode and have the correct and matching firmware versions installed maybe we should try SBC mode again.
                Reconnect the Pi ribbon, remove the SD card from the Duet, and remove the ethernet cable from the Duet, and boot up the duet and pi.
                ahwitmerundefined 3 Replies Last reply Reply Quote 0
                • ahwitmerundefined
                  ahwitmer @Phaedrux
                  @Phaedrux
                  Connected the RPI
                  Started up the machine
                  Succes
                  Nicely connected to 192.168.0.5
                  CoreXYUV
                  • ahwitmerundefined
                    ahwitmer @Phaedrux
                    @Phaedrux
                    Uploaded the config files for my setup and connected again.
                    Problem solved!
                    Thanks a lot Phaedrux
                    CoreXYUV
                    • ahwitmerundefined
                      ahwitmer @Phaedrux
                      @Phaedrux
                      Do you need additional information from my duet, for your file?
                      CoreXYUV
                        Glad it's working now.
                        Next time you update, use sudo apt update and sudo apt upgrade so that everything can be kept in sync.
                        • ahwitmerundefined
                          ahwitmer @Phaedrux
                          @Phaedrux Yes I will, thank you again!
                          CoreXYUV
