    Rotary delta calibration not implemented?
    LPC
    4.8k
    • Orang_undefined
      Orang_ @dc42
      @dc42 said in Rotary delta calibration not implemented?:
      Do you know which parameters of your machine are likely to be accurate, and which need to be calibrated?
      Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.
      M669 K10 U169.85 L320 R55.94 A-45:52 H432 X-60,Y60,Z180
      U, L, - maybe accurate enough to measure;
      R,H - within a small margin of error
      A - it is difficult to measure without special tools
      x y z - depends on the construction of the printer
      • Orang_undefined
        Orang_ @dc42
        "Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers."
        is it possible in the future to add support for spi or i2c external ram?
        or is it easier to buy a board with more memory?
          dc42 administrators @Orang_
          @Orang_ said in Rotary delta calibration not implemented?:
          No.
          Yes, such as the Duet 3 MB6HC or Duet 3 Mini.
          Orang_undefined 1 Reply Last reply Reply Quote 0
          • Orang_undefined
            Orang_ @dc42
            Why doesn't the G30 work in any way? I can't properly measure multiple points(
              Because the auto calibration code has to be written to suit the kinematics, even though the basic principle will be the same as for a linear delta. We may also need a more sophisticated way of configuring which parameters are to be calibrated, rather than just having a # of parameters as we do for linear delta.
              My guess is that the homing switch positions and delta radius are the most important to calibrate. Do you agree?
              Orang_undefined 2 Replies Last reply Reply Quote 0
              • Orang_undefined
                Orang_ @dc42
                "My guess is that the homing switch positions and delta radius are the most important to calibrate. Do you agree?" - Yes, you're right.
                • Orang_undefined
                  Orang_ @dc42
                  @dc42 you didn't do any "calibration"?
                    I don't have a rotary delta. I implemented the kinematics for a user who had one.
                    • Orang_undefined
                      Orang_ @dc42
                      @dc42 And thank you for that.
                      • Orang_undefined
                        Orang_ @dc42
                        @dc42 do you happen to know this user?
                          If you enter rotary delta in the search box for this forum, you will find his posts.
                          I will add calibration for rotary deltas to the firmware wishlist.
                          • Orang_undefined
                            Orang_ @dc42
                            Thanks
