    Rotary delta calibration not implemented?
    LPC
    4.9k
    • Orang_undefined
      Orang_ @PCR
      @PCR I have one of these https://www.youtube.com/watch?v=COUdIsoDgMw&ab_channel=AlexKorvinWorkshop
      Orang_undefined 1 Reply Last reply Reply Quote 0
      • Orang_undefined
        Orang_ @Orang_
        @Orang_ https://www.thingiverse.com/thing:3489886
        • Orang_undefined
          Orang_ @jay_s_uk
          @jay_s_uk but smoothie doesn't work quite right.
            jay_s_uk @Orang_
            @Orang_ who said anything about smoothieware?
            • alankilianundefined
              alankilian @jay_s_uk
              @jay_s_uk I think he's saying smoothie (which runs on that thingiverse-link printer) doesn't work, so he's looking at Duet firmware.
              • Orang_undefined
                Orang_ @alankilian
                The project specified in the link works on smoothie. but I reconfigured it to rrf
                jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                  jay_s_uk @Orang_
                  @Orang_ ah, ok. no problem
                    dc42 administrators @Orang_
                    @Orang_ said in Rotary delta calibration not implemented?:
                    @dc42 said in Rotary delta calibration not implemented?:
                    That is correct. The problem is that there are potentially many calibration variables for a rotary delta. For example, there are two pivot locations (like the tower position corrections for a linear delta), three upper arm lengths, three lower arm lengths, three pivot height corrections, three homing position corrections, and the delta radius. That's 18 parameters. It's unlikely the by probing a flat bed and measuring the height errors, it would be possible to calibrate all of these. However, if some of these are known to be accurate (for example, if all the arms are manufactured to precise lengths) then it may be possible to auto-calibrate the remaining parameters.
                    I can try adding auto calibration when I have time, but it might not give very good results.
                    Thank you, I really like your firmware, if there are any changes with the calibration, please let me know, I would be happy to test it. Also there is not a big group of people who own similar printers I think they will also support it.
                    Do you know which parameters of your machine are likely to be accurate, and which need to be calibrated?
                    Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.
                    Orang_undefined 2 Replies Last reply Reply Quote 0
                    • Orang_undefined
                      Orang_ @dc42
                      M669 K10 U169.85 L320 R55.94 A-45:52 H432 X-60,Y60,Z180
                      U, L, - maybe accurate enough to measure;
                      R,H - within a small margin of error
                      A - it is difficult to measure without special tools
                      x y z - depends on the construction of the printer
                      • Orang_undefined
                        Orang_ @dc42
                        "Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers."
                        is it possible in the future to add support for spi or i2c external ram?
                        or is it easier to buy a board with more memory?
                          No.
                          Yes, such as the Duet 3 MB6HC or Duet 3 Mini.
                          • Orang_undefined
                            Orang_ @dc42
                            Why doesn't the G30 work in any way? I can't properly measure multiple points(
                              Because the auto calibration code has to be written to suit the kinematics, even though the basic principle will be the same as for a linear delta. We may also need a more sophisticated way of configuring which parameters are to be calibrated, rather than just having a # of parameters as we do for linear delta.
                              My guess is that the homing switch positions and delta radius are the most important to calibrate. Do you agree?
                              • Orang_undefined
                                Orang_ @dc42
                                "My guess is that the homing switch positions and delta radius are the most important to calibrate. Do you agree?" - Yes, you're right.
                                • Orang_undefined
                                  Orang_ @dc42
                                  @dc42 you didn't do any "calibration"?
                                    I don't have a rotary delta. I implemented the kinematics for a user who had one.
                                    • Orang_undefined
                                      Orang_ @dc42
                                      @dc42 And thank you for that.
                                      • Orang_undefined
                                        Orang_ @dc42
                                        @dc42 do you happen to know this user?
                                          If you enter rotary delta in the search box for this forum, you will find his posts.
                                          I will add calibration for rotary deltas to the firmware wishlist.
                                          • Orang_undefined
                                            Orang_ @dc42
                                            Thanks
