Mini5+ "mcu-temp" sensor definition does not work
Using Duet Controllers
    oc_geek
    ; Define MCU sensors which will be available in DWC Extra View
    M308 S3 A"MCU" Y"mcu-temp"
    M308 S4 A"Duet Drivers" Y"drivers"
    For some reason the M308 "mcu-temp" doesn't work - error sensor "mcutemp" does not exist (and yes the "-" is removed in the error message)
    (The drivers one perfectly works)
    Any help please ?
    Does the Mini5+ use a different name for the MCU Temp Sensor ?
    (i saw this same command in the Wiki)
    Thanks
    undefined 1 Reply Last reply 21 Jan 2021, 21:06 Reply Quote 0
      Can you send M122 and report the results? Should be running fw 3.2 final.
      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
        oc_geek
        Yes i'm on Rel 3.2
        Here is the dump of M122
        1/21/2021, 9:46:46 PM M122
        RepRapFirmware for Duet 3 Mini 5+ version 3.2 running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: F8W09-K196U-D65J0-40KM0-LH03Z-Z1XLX
        Used output buffers: 3 of 40 (11 max)
        Static ram: 98732
        Dynamic ram: 113696 of which 92 recycled
        Never used RAM 32696, free system stack 200 words
        Tasks: NETWORK(ready,202) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,123) MAIN(running,440) IDLE(ready,20) AIN(blocked,267)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:01:05 ago, cause: power up
        Last software reset at 2021-01-19 23:49, reason: User, GCodes spinning, available RAM 32696, slot 0
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Aux1 errors 0,0,0
        Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
        Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
        Date/time: 2021-01-21 21:46:45
        Cache data hit count 137638723
        Slowest loop: 27.84ms; fastest: 0.12ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.8ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Bed heaters = 0 -1, chamberHeaters = -1 -1
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 21.01ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.25
          WiFi MAC address f4:cf:a2:6f:e9:87
          WiFi Vcc 3.46, reset reason Power up
          WiFi flash size 2097152, free heap 25104
          WiFi IP address 10.0.0.7
          WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          === CAN ===
          Messages queued 585, send timeouts 583, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
          dc42 administrators @oc_geek
          @oc_geek said in Mini5+ "mcu-temp" sensor definition does not work:
          Unfortunately the SAME54P20A chip used in the Duet 3 Mini does not have a functioning temperature sensor. In theory it does have an on-chip temperature sensor, but the errata document for the chip says it doesn't work. Microchip has told me that they don't expect to fix this in a new revision of the chip any time soon.
            oc_geek
            ok that explains a lot, thanks !
            Perhaps worth to mention it in the docs so others will know as well
              I'll add a note to the documentation.
              6 out of 6
