Troubleshooting bed heater
Please post the contents of the config.g file using the </> tag.
Config file below. So far I've tried with both PID and bang bang mode set for the bed. Thanks.
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 22 2021 13:40:37 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Sulla" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E837.20 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X370 Y250 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off ; Tools M563 P0 S"E0" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
was it working before or are you setting up the printer new?
ie. did you just upgrade from version 2 to 3? -
That all looks right.
Do you have a blade type fuse between the power in connector and the bed heater connector?
Measure the voltage between the power in connector GND terminal and the bed heater connector VIN terminal.
@Veti the heated bed was working with the stock MKS gen 1.4 board.
I upgraded the firmware on the duet before setting it up so I did not try the heated bed with the older firmware.
check the fuse on the board
@fcwilt well now I feel just a little dumb.. The fuse is the issue.
Now I wonder what should be done moving forward? I know the black widows started shipping with an external mosfet at some point after I purchased mine but I never installed one. I read some posts from other black widow users on the forum that didn't seem to think the external mosfet was necessary, but if I tripped the fuse presumably on the first attempt at heating the bed I wonder will it be safer to install an external mosfet?
Thanks for the help.
@Dee_Pee
measure the resistance of the bed. -
Well do you know how much current the bed heater is supposed to draw?
If you don't can you measure it's resistance?
I do not know off hand how much current it is supposed to draw but I am measuring 1.4 ohms on the bed.
I'm linking below to a bed heater that is sold as a replacement for the black widow but I think this one would be an upgrade for my machine which is likely part of the issue at hand. My widow is an early version that came with a PCB heatbed and before they started shipping with the mosfet, as I said before. The stock connector that came with the kit has always been a little shoddy with voltage and ground split over four wires. There was a reason they started shipping them with mosfets afterall. I know one popular mod is to solder the wires directly to the bed for a better connection so I will start there but I wonder if I should still plan to add a mosfet if I want to use my current heated bed with the Duet.
I was able to run a PID autotune and heat the bed up 90C without burning out the new fuse, however each subsequent attempt at heating the bed has so far resulted in a fault.
If you power supply is 12V you are OK with that heater - if 24V then you need an external device of some sort.
What sort of fault are you seeing?
I am using a 24V PSU so I will plan to add the fet while I am doing my other upgrades.
The faults stated the bed was not heating as fast as expected.
Thanks for the help!
@Dee_Pee said in Troubleshooting bed heater:
That's strange - with 24V power it should heat up just fine.
To verify are you using PID mode?
@fcwilt Yes, I am using PID mode. After replacing the fuse it did heat up just fine the first time and sustained a temp around 90C to complete a PID autotune. I received the faults when I then tried to run off a print afterward.
I've soldered the wires to the bed and was able to heat it again and begin a print. I suspect the issue was probably due to the cruddy connection where the wires enter the bed probably adding a bit of resistance there. My bed and hot end sensors now give matching readings at room temp whereas before they were at least a few degrees apart so this theory seems to check out so far.
Thanks again.
