    Problem with rear side of Test Cube
    2.4k
    • dmbgoundefined
      dmbgo
      I think that before embarking on anymore tests, I will put the printer back in its thermal home. I only had it out to solve other issues, which are fixed now.
      Once it is back, I'll level the bed properly and let you know how it goes.
      Regards David Maher
      • dmbgoundefined
        dmbgo
        Oh, and as far as rigidity goes @antlestxp , I have modified the printer and added fairly heavy steel cross pieces on the Y axis and installed rectangular steel bracing pieces into the existing frame. You can see the front cross piece in the photo of the printer above. The standard Black Widow looks quite different.
        If you think I need to go further, please let me know. 🙂
        Regards David Maher
        • fcwiltundefined
          fcwilt @dmbgo
          @dmbgo said in Problem with rear side of Test Cube:
          I check this site on a regular basis so if you include @fcwilt I will get alerted to your posts.
          I will not be at all surprised if ABS prints fine with the enclosure.
          If you haven't researched PETG I think you should check it out.
          This was posted on ALL3DP.COM:
          PETG is stronger, more durable and it prints better. It's also available in transparent colors. ABS is only necessary if you absolutely need the 100°C temperature resistance or its ability to be glued and painted. Otherwise, it's difficult to justify the printing difficulties involved
          • dmbgoundefined
            dmbgo
            Thank you, it sounds like excellent advice!
            Regards David Maher
            • dmbgoundefined
              dmbgo
              @fcwilt
              Well the printer is finally back in its thermal enclosure, there was a bit of a hiatus getting it done, whilst I was doing other things.
              Sadly the symptoms are unchanged. The thermometer on the enclosure says the the internal enclosure temp is around 30C (86 F). I think this should be warm enough to print ABS?
              Regards David Maher
              • fcwiltundefined
                fcwilt @dmbgo
                I have seen articles that suggest 110C. I have seen those that suggest 70C to 90C.
                If any of those are correct then 30C will be much too low.
                Frederick.
                • dmbgoundefined
                  dmbgo
                  That's a pretty high temperature for the enclosure, more like a bed temp. I can try it with a higher temp though.
                  I also have a Prusa MK3, which has an enclosure as well. It prints ABS fine (no curling / lifting) just using the heat generated by the bed. Do you think I should raise the enclosure temp to see if there is any change?
                  I've also bought a stock of PETG now, but haven't tried it yet. If the problem still occurs with PETG does that indicate that it is not caused by the ABS per se?
                  Regards David Maher
                  fcwiltundefined antlestxpundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @dmbgo
                    I found another article which suggests 60-70.
                    I never tried ABS after reading the issues with it and went right to PETG and others. PLA actually is fine for most of what I print.
                    • dmbgoundefined
                      dmbgo
                      Thanks Fredrick,
                      I'll try the PETG and let you know. It might not be for a couple of days.
                      Regards David Maher
                      • fcwiltundefined
                        fcwilt @dmbgo
                        Thanks Fredrick,
                        Barring my dying unexpectedly I will be around.
                        • antlestxpundefined
                          antlestxp @dmbgo
                          @dmbgo you want to be above 60 for the enclosure but not to high if printing small parts. Goal is to have the layer cool just enough to start to become solid but not enough that it shrinks. You want to avoid using the fan because that will cool to rapidly. I will usually print multiple objects when I print abs. My enclosure usually hovers around 70 degrees. Did you ever try printing 2 objects to increase your layer times?
                          • dmbgoundefined
                            dmbgo
                            @antlestxp
                            "@dmbgo you want to be above 60 for the enclosure but not to high if printing small parts. Goal is to have the layer cool just enough to start to become solid but not enough that it shrinks."
                            To answer your last question first, yes, I did print 2 separate test cubes about 250mm apart, to see if the extra time for layers to "set" helped - it didn't, the issue remained unchanged.
                            I'm fairly sure now that it's not being caused by a shrinkage issue. I have, in the past, successfully printed objects in the same enclosure using ABS with similar settings.
                            in a day or so, I will try using PETG with its recommended settings to see if the issue is ABS, or happens with all mediums, as @fcwilt suggested.
                            Regards David Maher
