    z only moves to 0, but should still have to be 0.2mm
    • beqbiqundefined
      beqbiq
      i am sorry as i arrive here with such a simple question now. i don't even know how to look for the solution.
      I have the following problem: I let the bed level, then move the nozzle to the center and to z = 0. then I realize that the distance is too big. but the table can no longer go higher.
      therefore my question: can you reset the set z = 0 and move the bed higher?
      thanks in advance!
      • Vetiundefined
        Veti
        it depends on your setup.
        for a probe see
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        • fcwiltundefined
          fcwilt
          We need more information.
          Using the </> tag please post:
          • config.g
          • homeall.g
          • homex.g
          • homey.g
          • homez.g
          • bed.g
          Thank you.
