    Early RRF 3.3beta files available
    Beta Firmware
    8
    16
    1.3k
    • Luke'sLaboratoryundefined
      Luke'sLaboratory
      Excited to see if this addresses some of the oddities i've experienced
      Luke
      http://lukeslab.online
      • evomotorsundefined
        evomotors
        @dc42 I Installed 3.3, but it didn't fixed my issue.
          @evomotors, please do the following:
          1. Use M115 to verify that 3.3beta is installed on all the boards
          2. Run M122 B# for the main board and each expansion board to clear the stats
          3. Run a test print that demonstrates the problem
          4. Generate a M122 report from the main board and each expansion board, and post them here. It needs to be the first M122 from each board after running the print. If you don't want to run the entire print, you can pause the print, wait for everything to stop, and then run the M122 reports.
          The "steps commanded" and "steps done" figures on the expansion boards should be equal, indicating that every step commanded over the CAN bus has been executed.
            For anyone using this 3.3beta firmware on a EXP1XD board:
            We have found and corrected a problem with setting the step pulse width, and updated the EXP1XD firmware at the link I gave at the start of this thread. So please update your EXP1XD boards to this new firmware. The new firmware reports build time 17:18:18 in M122 and M115.
            • Nuramoriundefined
              Nuramori
              I didn’t see it, so I’d figure I’d ask....does this beta (or a near future 3.3 beta) allow for auto PID tuning with a toolboard?
                dc42 administrators @Nuramori
                @Nuramori said in Early RRF 3.3beta files available:
                Not yet, it's next to be implemented when some remaining issues with expansion boards and high CAN message rates have been fixed.
                • Nuramoriundefined
                  Nuramori
                  Are these updatable with AP “apt upgrade” if we’re on the unstable branch?
                    Phaedrux Moderator @Nuramori
                    Considering that it's a dropbox link, probably not available on the unstable package server yet.
                    • aleohlundefined
                      aleohl
                      Will test it out straight away, good job!
                      I and everyone in my team are very impressed by your swift action in regards to our issues with step pulses. I hope we can figure it out together, both for us and, of course, the community.
                      Would it make any difference if you had remote access to Atmel ICE kit connected to our devices? If so just send me an email!
                      Also, do you think it would help us anything if I hook it up and does some trial-and-error to see if I can get more verbose logs or something like that?
                      • aleohlundefined
                        aleohl
                        Great improvements!
                        Not possible to say by this time if the issue is completely resolved or just great improvement. We will do some more testing.
                        Thanks @dc42 and team for your great effort and speed!
                        I try to follow along with the changes in the code base, good way to learn the inner workings.
                        • symekutzundefined
                          symekutz
                          So I'm confused M303 is not implemented but in the changelog it says it is.
                          [Duet 3 expansion/tool boards] Heater tuning is now implemented (M303) along with heater feedforward
                          When I try it I get:
                          Error: M303: remote heater auto tune not implemented
                          m122
                          RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                          Board ID: 08DJM-956L2-G43S4-6J1F2-3SN6P-1U6QG
                          Used output buffers: 1 of 40 (18 max)
                          m122 b21
                          Diagnostics for board 21:
                          Duet TOOL1LC firmware version 3.3beta (2021-01-21 11:34:37)
                          So I'm a thinking the changelog is ahead of the code?
                          Let me know if I missed something please.
                            Download the official 3.3beta1 release from github.
                            symekutzundefined 1 Reply Last reply Reply Quote 0
                            • symekutzundefined
                              symekutz @dc42
                              @dc42 It's running now thank you!
                                Locking this thread because the early beta files have been superseded by the official 3.3beta1 release on Github.
