    Error: M997: "Duet2CombinedIAP.bin" not found
    Firmware installation
    1.4k
    • pro3dundefined
      pro3d
      Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      • Vetiundefined
        Veti
        upload it as well.
        you can find it at the same place where you downloaded the new firmware
        pro3dundefined 1 Reply Last reply Reply Quote 0
        • pro3dundefined
          pro3d
          This happens when upgrading to 3.2 from 3.1.1
          • pro3dundefined
            pro3d @Veti
            @Veti said in Error: M997: "Duet2CombinedIAP.bin" not found:
            upload it as well.
            I can not find it... Maybe blind
            • Vetiundefined
              Veti
              did you flash via bossa to 3.1.1?
              i.e you never went to 3.0?
              its here
              https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
              pro3dundefined 2 Replies Last reply Reply Quote 0
              • pro3dundefined
                pro3d @Veti
                its here
                Bossa flash yes. NO 3.0
                • pro3dundefined
                  pro3d @Veti
                  @Veti Thanks!
                    If you still have access to DWC the best way to update is to upload the complete release zip file
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                    That way you get the firmware, DWC files, etc etc all together. Just upload the zip file itself to the system tab in DWC.
