    Heater scale at 2000 degrees
    440
      @cdthomas9 said in Heater scale at 2000 degrees:
      M140 H0
      M143 S260 ; Set maximum heater temperature to 260C
      M308 S0 P"bed_temp" Y"thermistor" T100000 B3974 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
      M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
      M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
      M950 H2 C"e1_heat" T2 ; heater 2 uses the e1_heat pin and sensor 2
      M307 H0 A103.7 C787.7 D1.0 S1.00 B0
      ;M307 H0 A38.5 C41.1 D1.4 V24.4 B0 ; Set PID values for Heatedbed - derived from autotune
      M307 H1 A250.2 C139.5 D5.4 V24.4 B0 ; Set PID values for Extruder 1 - derived from autotune
      M307 H2 A387.6 C209.9 D5.9 V24.4 B0 ; Set PID values for Extruder 2 - derived from autotune
      M307 H3 A-1 C-1 D-1 ; Disable the 4th Heater to free up PWM channel on the Duex board.
      You only have one M143. You must set it for each heater.
      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M143_in_RRF_3_01RC2_and_later
      • cdthomas9undefined
        cdthomas9
        So remove the M143 I have and add in this?
        M143 H0 P0 S160 T0 A2
        M143 H1 P1 S290 T1 A2
        M143 H2 P2 S290 T2 A2
          Looks ok
            cdthomas9
            I still get the same scale. I can see that it changes to a max of 300 degrees for a second, when restarting the board, but then it jumps to 2000 again.
              What firmware and DWC version?
              Can you post your changed config.g?
                cdthomas9
                M111 S0																	; Debugging off
                G21																		; Work in millimetres
                G90																		; Send absolute coordinates...
                M83																		; ...but relative extruder moves
                M555 P2																	; Set firmware compatibility to look like Marlin
                M208 X-7 Y0 Z0 S1														; Set axis minima
                M208 X252 Y153 Z155 S0													; Set axis maxima (reduced by offset above)
                ; Enable Panel Due Connector
                M575 P1 S1 B57600														; Enables connector and sets baud rate
                M574 X1 S1 P"!xstop"													; X min active high endstop switch
                M574 Y1 S1 P"!ystop"													; Y min active high endstop switch
                ;Manual Bed Leveling
                M558 P9 C"^zprobe.in" H5 F500 T4000 X0 Y0 Z1							; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
                G31 P25 X-36 Y0 Z2.885													; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                M557 X40:190 Y20:145 S20												; Define mesh grid
                ;M671 x144:94:191 Y10:160:160 P0.5 										; Manual screw adjustment locations
                M569 P0 S1																; Drive 0 goes backwards
                M569 P1 S1																; Drive 1 goes backwards
                M569 P2 S0																; Drive 2 goes forwards
                M569 P3 S0																; Drive 3 goes forwards
                M569 P4 S1																; Drive 4 goes backwards
                M350 X16 Y16 Z16 E16 I1													; Configure microstepping with interpolation
                M92 X88.573186 Y88.573186 Z400 E96.27520187033366						; Set steps per mm
                M566 X900 Y900 Z300 E1200												; Set maximum instantaneous speed changes (mm/min)
                M203 X1080000 Y1080000 Z600 E96000										; Set maximum speeds (mm/min)
                M201 X1000 Y1000 Z100 E2000												; Set accelerations (mm/s^2)
                M906 X800 Y800 Z400 E800 I30											; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 																; Set idle timeout
                M584 X0 Y1 Z2 E3:4														; Set drive assignments
                M140 H0
                M143 H0 P0 S160 T0 A2													; Set maximum bed heater temperature to 160C
                M143 H1 P1 S290 T1 A2													; Set maximum heater 1 temperature to 290C
                M143 H2 P2 S290 T2 A2													; Set maximum heater 2 temperature to 290C
                M563 P0 D0 H1															; Define tool 0
                G10 P0 X0 Y0 Z0															; Set tool 0 axis offsets
                G10 P0 R0 S0															; Set initial tool 0 active and standby temperatures to 0C
                M563 P1 D1 H2															; Define tool 1
                G10 P1 X34 Y0 Z0														; Set tool 1 axis offsets
                G10 P1 R0 S0															; Set initial tool 1 active and standby temperatures to 0C
                M207 S1.2 F1200															; Set 1.2mm retract distance for G10 command
                M550 P"Rep2X-EnStein"													; Set machine name
                M552 S1																	; Enable network
                M586 P0 S1																; Enable HTTP
                M586 P1 S1																; Enable FTP
                M586 P2 S0																; Disable Telnet
                M950 F0 C"fan0" Q500													; Set fan 0 value, PWM signal inversion and frequency.
                M950 F1 C"fan2" Q500													; Set fan 1 value, PWM signal inversion and frequency.
                M106 P0 T40:50 H1														; Set fan 0. Thermostatic control is turned on
                M106 P1 T40:50 H2														; Set fan 1. Thermostatic control is turned on
                M950 S0 C"exp.heater3"													; Define BLTouch probe
                M564 H0 ; Allow Movement while axes are NOT homed
                  cdthomas9
                  DWC 3.2.0
                  Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
                  Duet WiFi Server Version: 1.25
                    cdthomas9
                    I recently updated to 3.2 for DWC and the firmware, could there be something in DWC I need to change?
                      The order of heater commands does matter. You've got them all clumped together.
                      I suggest you re-order your commands to group them by heater number rather than command type.
                      Here's an example from the configurator:
                      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                      M308 S2 P"e1temp" Y"thermistor" T100000 B4138  ; configure sensor 2 as thermistor on pin e1temp
                      M950 H2 C"e1heat" T2                           ; create chamber heater output on e1heat and map it to sensor 2
                      M307 H2 B0 S1.00                               ; disable bang-bang mode for the chamber heater and set PWM limit
                      M141 H2                                        ; map chamber to heater 2
                      M143 H2 S280                                   ; set temperature limit for heater 2 to 280C
                        cdthomas9
                        Perfect, thanks!
