    Capricorn PTFE Tubing XS- Low Friction
    85
    18.5k
    • kraegarundefined
      kraegar
      I'd missed this thread before, but just wanted to add that I switched to Capricorn PTFE for my bowden a few months ago, and it was a drastic improvement. The only issue I've had with it was a cheap spool of filament that jammed… the filament was > 1.78mm in spots. Outside of that bad roll, it's been awesome. I highly recommend i t.
      • FrankNPrinterundefined
        FrankNPrinter
        and i thought printing the e3d ptfe clip was rough LOL that is microscopic… but is it really higher res? eventually would like to be able to print gears so accuracy is important to me but that seems a bit much for my needs not to mention print times...ugh :).
        • Whitewolfundefined
          Whitewolf
          @kraegar:
          Did you lower all your retraction settings? I found that i needed to lower retraction down quite a lot after the upgrade as i quickly jammed and needed to perform a cold pull with nylon to clear everything.
            Whitewolf
            @FrankNPrinter:
            you should be able to do gears just fine with .35 or .4 nozzle if you're calibrated well.
            • Sethipusundefined
              Sethipus
              I'm glad I found this thread. I just ordered some of that Capricorn XS tubing from Filastruder. I've been trying to reduce the problems I get with corner blobbing and blobbing at layer line ends due to bowden system pressure. I've been using the pressure advance feature, and with the settings I've got so far it's been helping, but hasn't eliminated it.
              If this Capricorn reduces the filament compression (more like kinking than strict compression, but you know what I mean) that should help a lot more. This bowden system pressure is the one thing I really don't like about my printer as compared to my direct extruding Di3. Other than this my D-bot is better than my Di3 in every way.
              Btw, I have a little experience looking at extrusion "pulsing" quality when changing microstepping. When I increased the microstepping I was using on my extruder I saw an improvement in the consistency of the extruded line widths. It's tiny, but you can actually see it pretty clearly on the surface of top layers. There are little "segments" if you will due to extruder stepping, and the size and distance between segments was clearly reduced as I upped the microstepping. I'll see if I can find the photo I had before that showed this.
              • Sethipusundefined
                Sethipus
                Here's an image showing two printed gears (to be used with my belted extruder). The one on top was printed with my extruder stepper set to use 32x microstepping. The one on the bottom had the extruder using 16x microstepping.
                If you look carefully you can see the "step pulsing" artifacts are smaller and closer together in the 32x microstepping print as compared to the 16x print.
                A geared vs. non-geared extruder should show similar differences due to step pulsing. If anyone's confused, I'm calling it "step pulsing" when the pressure in the extruder system is increased suddenly and then decays a little as plastic flow reduces the pressure due to the discrete steps nature of the stepper motors we use. The closer together the steps are, the lower the difference will be between the highest and lowest pressure (and hence flowrate) of the system as it prints, as well as the frequency of these pressure pulses. The geared extruders have the same effect, ie: more pulses per mm of printed line, at lower pressure difference per pulse.
                • kraegarundefined
                  kraegar
                  @Whitewolf:
                  @kraegar:
                  Yes, I went from 3.5mm retraction and still some fine stringing, to 1.3mm retraction, zero stringing. No other change than the Capricorn bowden tubing, cut to the same length. (E3dv6 & titan combo)
                    Whitewolf
                    Yes i experienced the same result with setting extruder to 32… the layer lines on the side become pretty difficult to see without the right reflection or close up photo at 32
                    currently back at 16 just until i dial in my top speed then ill try switching back to 32
                    I plan on testing a 0.9 degree motor for my extruder as well.
                    you should try printing with Igus Iglidur 180 PF filament... it is expensive but incredibly precise, it can print straight up in the air and 90 degree overhangs without issue.... with this precision comes tell tail signs of extruder issues which has helped me fine tune even further.
                    That and it makes for some seriously sharp gears and bushings.
                    I will be doing a review in a new thread soon
                    • Sethipusundefined
                      Sethipus
                      @Whitewolf:
                      you should try printing with Igus Iglidur 180 PF filament… it is expensive but incredibly precise, it can print straight up in the air and 90 degree overhangs without issue.... with this precision comes tell tail signs of extruder issues which has helped me fine tune even further.
                      I agree, the 180 filament prints really well. I've tried it and the 170. Now they've come out with the 260 and something else, I think 210. I'm going to get a sample of the 260 and try it out. It's supposed to be better than the 170 in terms of friction and wear.
                      If you like the Igus filament, if you have a D-bot you should check out my Igus filament bearing pads on Thingiverse. Basically I replaced all 12 mini V-slot wheels that ride in the V-slot grooves of the D-bot's X/Y motion system with carrier blocks that fit in the same space as the wheels did, and have Igus filament pads that actually ride on and in the grooves of the v-slot. This allows a much tighter installation with zero or at least undetectable by hand slop in the fit and alignment of the X gantry and the print carriage. I'm really pleased with it so far. I've been printing entirely without wheels on my X/Y for about 6 or 7 weeks now. I'm currently working on a solution to replace the wheels on the Z axis with Igus pads as well.
                      https://www.thingiverse.com/thing:2373538
                      I've tried the 180 and 170 filament with these pads. The 180 printed easier, but I believe the 170 had less friction and is supposed to wear better. I'd really like to try out the 260 filament.
                        Whitewolf
                        Yeah getting a roll of 260 to compare was on my list, they say its the equivilent of their injection molded parts but we'll see… i actually prefer the 180 over the preloaded igus bearings. When i printed the lm8uu style bearings in 180 i printed them tight and slowly reamed them out with a 8mm drill bit just until they would slowly slide up and down while i flipped the x shaft end for end.
                        Then i took the bearing with my hand and moved it fast up and down.... the slight friction actually is a friend of the 180.... once they are warmed i again tipped it end for end and the speed in which these light bearings move is easily double that of the preloaded igus bearings which weigh a lot more because of their aluminum housing. All while maintaining tight tolerences compared to the sloppy igus bearings.
                        When warmed the bearing actually acts like its running on an air hockey table.
                        I have hopes that the 260 will be similar but with better strength but its up there with 170 in regards to printability.
                        I wish they had more data on their website comparing the differences.
                        That is awesome about printing without wheels.... I printed every moving part with 180 yesterday.... just have to get it all installed now. So far just my X carriage is using 180 bearings
                        If you know where to buy 260 in the US please let me know... I can only find 180 and 170
                        • Sethipusundefined
                          Sethipus
                          Call this lady:
                          Cindy Mowry
                          Igus Inc.
                          East Providence, RI
                          Phone: 800-521-2747
                          Fax: 401-438-7270
                          cmowry@igus.com
                          The j260 filament shows up as $64/250g here:
                          http://www.igus.com/wpck/14928/N15_04_14_iglidur_J260
                          The i170 has the same 250g rolls for about the same price, but they also have a 750g roll for like $94. I was going to order a 750g roll of 170 until I found out about the 260. Now I want to try it before pulling the trigger on the 170. So far I've been using samples from Igus. They'll send a sample out to anyone, but they sent me more than one sample of both the 170 and 180 because I told them I was developing some solutions with them that I intended for general release.
                          Btw, what printer are you using? You just said you printed every moving part yesterday with 180. Every moving part for which printer? A D-bot? If so, I'd be curious what you think of the X/Y motion bearing pads for the D-bot that I linked to in my previous post.
                          • Sethipusundefined
                            Sethipus
                            I've seen quite a few posts where people were building D-bots and then buying expensive Hiwin linear guide rails and bolting them onto the v-slot. I thought that's just ridiculous. Part of the beauty of the D-bot is in the way the rails that make up its frame perform double duty as the linear guide rails for the X/Y/Z motion system. That's very simple and elegant. The only problem is that a lot of people just aren't happy with the performance of the mini v-slot wheels, and find the Hiwin rails give them better precision, less play and slop, low friction, etc.
                            I believe my Igus sliding bearing pad solution that uses the v-slot rails instead of additional bolt-on rails is cheaper than going with Hiwin, while achieving all of the same advantages of the Hiwin guide rails over the v-slot wheels. And best of all, it's an almost invisible mod that people might not even notice, because it doesn't involve bolting all kidns of extra hardware onto the v-slot. The parts I've designed blend in very well with the original D-bot parts they are used with.
                            I've modded my D-bot quite a bit over stock, and yet it doesn't immediatey look to the casual glance like it's heavily modded because I've tried to maintain the simplicity of the design without bolting all sorts of extra crap onto it. I'm about to publish a v2.0 of my Igus bearing pad D-bot X/Y system with more refined carrier blocks that blend in better with the stock D-bot parts they mate up with (there's also a moderate improvement in the Igus sliding pad itself in this v2.0). That will probably go up tonight.
                              Whitewolf
                              i heavily modified a XYZ Davinci Pro…. your linear rail solution has me interested for another build. I will take a closer look tomorrow.
                              Thanks for the igus contact info
                              • Sethipusundefined
                                Sethipus
                                I got my Capricorn tubing yesterday and put one in (using one side of the Chimera for now). It does seem noticeably better.
                                Right now I'm having some trouble understanding a stringing/oozing problem I'm having.
                                With the Capricorn tubing I ran some test prints where I reduced the retraction from the 4.6 I'd been using with my cheapo PTFE tubing in steps all the way down to 2.0, and in some tests, 1.5. With conventional retraction tower tests I saw great results. I've got two retraction tests I'll show in a few minutes that went down to 2.0mm retraction that show zero stringing.
                                Then I printed off a 90-100mm tall Baby Groot and there's just god-awful stringing between his legs, and between his arms and his body. After a 2.0mm retraction Groot showed signs of bad stringing I bumped it to 2.5mm and reprinted, and it's still bad. I'm running one right now at retraction of 3.0mm and I'll see soon enough whether that's going to do it.
                                After the retraction tower tests I was feeling pretty awesome about the possibility of having my retraction down to nearly approaching direct extruder levels, but after these Groot tests I see that's not realistic.
                                I'm a little confused though as to why my retraction tower tests are coming up perfectly stringing/oozing free at 2.0mm, but these Baby Groot's are coming out with awful stringing.
                                I thought I understood retraction pretty darn well, and so this has me nervous, because I know I'm missing something that would explain this.
                                I'll put some photos in just a minute.
                                  deckingman
                                  As the filament passes through the extruder, it get squashed a bit into an oval, or the hobbed bolt bites into it leaving tiny ridges. It doesn't take much of a deformation for the filament to then stick inside the tube. So one possibility for variable retraction with 1.8mm ID tubing is that with short moves followed by retraction, the same piece of filament goes back and forth inside the extruder and gets squashed more than once, leading to extra deformation or hobbed bolt ridges getting bigger, making the filament more likely to stick in the tube (compared to long moves between retraction) causing the extruder to skip slightly.
                                  • Sethipusundefined
                                    Sethipus
                                    Ok here are photos show two different retraction towers and a Baby Groot. The two towers show little/no stringing all the way down to 2.0mm retraction (tiny little nubs of stringing on the widely-spaced towers at 2.0 and 2.5). The Baby Groot was printed at 2.5mm retraction and as stringy as hell.
                                    I'm trying to figure out what I'm missing. The other settings are the same. I've tried obvious things like dropping print temperature. I've tried from 210 C all the way down to this Baby Groot at 190 C, and it hasn't helped.
                                    One hint I have is in this one photo of a retraction tower where there's a little crap thing sticking out about 1/4 of the way up. That's where the process I used there happened to have accidentally some "bottom" layers set up. I suspect it has something to do with the retraction towers being fairly low print density with single or double walls, while the Baby Groots had more infill and hence more printing occurrred between moves. Still not sure why such short retraction works fine on the retraction towers but not well with the real print.
                                    • number40fanundefined
                                      number40fan
                                      Is the printing speed of the towers a lot slower than the speed of the baby groot?
                                      • Sethipusundefined
                                        Sethipus
                                        The towers and the Groot were both set to 60mm/s, but what the actual speed was would be impossible to say, since both have sections small enough that acceleration settings would slow things down somewhat. The arm that you see in the Groot photo is approximately the same diameter as the retraction towers, so we might assume that the nozzle reached similar speeds going around that arm as it did on the towers, though the towers have 90 degree corners and the arm doesn't.
                                        I just ran some more towers where I went from 2 to 3 perimeters to see if the difference was simply down to how much actual printing got done between retractions (see if maybe on the towers the extruder/bowden/nozzle system hadn't reached its normal steady state pressure due to how little was printed between retractions and repriming). At 2.0mm retraction I got enough oozing to create the usual "hangers" sticking off the side of the tower at an angle. At 2.5mm there were little nubbins sticking out, and at 3.0 there were nearly but not quite nonexistent nubbins, and at 3.5mm retraction no sign of any oozing whatsoever.
                                        I've got to go somewhere for a while, so I just started a Baby Groot with retraction set to 3.1mm. I'll see how it went when I get back.
                                        If it works great, and continues to work for other types of prints with larger pieces, sharper corners, wider spaces, etc., then I'll know that for at least this filament the new retraction of 3.1mm is it. This is compared to 4.6mm with my previous cheapo PTFE.
                                        While I was hoping to get it all the way down to 2mm, and thought I had with my original retraction tests, I'll say that 3.1mm from 4.6mm is a huge improvement. It means that the pressure "spring" inside the tubing from the filament kinking up and absorbing or releasing incoming filament feed rates is substantially reduced by using this tubing with its smaller diameter.
                                        This filament (Hatchbox black PLA) measures out at only 1.72 to 1.73mm, unfortunately. If reducing the diameter of the PTFE tube is mostly responsible for reducing the bowden tube pressure spring, then it's probably also true that the closer in diameter you get from the filament to the ID of the PTFE tube, the better. I'd be better off with filament measuring 1.76 or 1.77 than 1.73.
                                        Sounds like a small difference, but the bowden tube pressure spring effect is responsible for keeping filament flowing more than you want going into corners where the deceleration of the nozzle requires slowing down the filament flowrate to avoid blobbing, and not accelerating as fast it should coming out of corners (which results in thinning of the part coming out of the corners). If a difference of only .15mm inside diameter of the bowden tube can drop my retraction from 4.6 to 3.1mm, then .03mm difference in filament diameter is a bigger deal than you'd think.
                                        Most of my filaments measure out at 1.75 or 1.76 or so. I'll have to figure out what filaments tend larger and buy more of that, and less of the stuff that measures smaller. I'm disappointed that this Hatchbox PLA measured out smaller like this. My Hatchbox PETG typically comes in at least 1.75mm.
                                          Whitewolf
                                          I get mixed results based on filament. Some filaments i am running as low as 1.25mm with a 400mm tube.
                                            Whitewolf
                                            I should add that i have not compared different brands of the same type of filament and also pressure advance can have some effects on what you are seeing, try playing with it on the fly when printing grub… it also plays differently based on filament. Also do you use a retainer clip on the collet where the ptfe enters your hotend... i have found this to improve results as well (several designs sare available on thingiverse)
