    Reset during print Part 2 - Duet 3.1.1 / 3.2beta3 - Duet3+SBC
    Beta Firmware
    1.7k
    • Viaundefined
      Via @dc42
      @dc42 Failed again on beta4 (M122 at bottom) they are posted already but will group together here.
      config.g
      [PLA] CFFFP_Top - ReRender - zero temps (1).gcode
      full sys directory: https://www.viaraix.net/duet3-sys.zip
      RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
      Board ID: 08DJM-956L2-G43S4-6J9FA-3S86T-1B5LD
      Used output buffers: 1 of 40 (11 max)
      Static ram: 123212
      Dynamic ram: 168584 of which 704 recycled
      Never used RAM 99692, free system stack 188 words
      Tasks: NETWORK(ready,169) ETHERNET(blocked,110) HEAT(blocked,298) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,358) TMC(blocked,54) MAIN(running,1113) IDLE(ready,19)
      Owned mutexes:
      Last reset 00:00:19 ago, cause: software
      Last software reset at 2020-11-27 11:41, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 99692, slot 2
      Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0044a804 BFAR 0x00000000 SP 0x204100c8 Task MAIN
      Stack: 00000002 ffffffff 00434a29 20410308 000002bc 00469483 0046a3c8 610f0000 2042565c 004691bf 2042565c 00000000 000002bb 0000000a 2042565c 204256c8 00000000 00000001 00000000 00468e53 204256c8 00000000 204256c8 004691bf 00000000 00000000 20425540
      Error status: 0x00
      MCU temperature: min 39.0, current 39.4, max 39.9
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 0, standstill, reads 32774, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 32775, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 32776, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 32777, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 32779, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 32782, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-11-27 11:41:21
      Slowest loop: 6.06ms; fastest: 0.15ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 17.56ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages queued 79, send timeouts 177, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
        Thanks for your new report. I am fairly certain that the memory protection fault was caused by a hardware error, because there is no way that the instruction at that address should fault, nor any way that the faulting address should be zero. So I suggest we swap your board. Who did you purchase it from?
        Viaundefined 1 Reply Last reply Reply Quote 0
        • Viaundefined
          Via @dc42
          @dc42 thanks for your time looking into this. Purchase was from E3D but I have just gone over the 6 months now (purchased 13th May), will you be able to authorise warranty replacement as reported prior?
            Yes I approve a warranty replacement.
            • Viaundefined
              Via @dc42
              @dc42 Thank you, will get in touch with E3D. Many thanks for your help.
                @Via, two more things to try:
                1. Try the new binary at https://www.dropbox.com/sh/tehhdvunh0pgr7q/AADgJ4Qj7W18MYaRRNNDdhpwa?dl=0, although I think it likely that it won't make any difference.
                2. Your MCU temperature may be a little high, depending on how accurate the 39.4C reading is. 40C is well within limits, but the actual temperature could be higher. Please try powering up the board when it is cold and immediately run M122 to check the temperature reading. That will allow you to calibrate the MCU temperature sensor. See https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature.
                • Viaundefined
                  Via @dc42
                  @dc42 MCU was over reading by ~2C so adjusted to compensate and showing ~35C now.
                  Installed new firmware and...
                  30/11/2020, 13:26:02	Finished printing file 0:/gcodes/[PLA] CFFFP_Top - ReRender - zero temps.gcode, print time was 1h 41m
                  So looked promising so without changing anything I reran print to make sure it was not a fluke and sure enough it was 😞 ...
                  RepRapFirmware for Duet 3 MB6HC version 3.2-beta4+4 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                  Used output buffers: 1 of 40 (12 max)
                  Static ram: 123212
                  Never used RAM 99692, free system stack 122 words
                  Tasks: NETWORK(ready,165) ETHERNET(blocked,105) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,352) CanClock(blocked,349) TMC(blocked,20) MAIN(running,1113) IDLE(ready,19)
                  Owned mutexes:
                  Last reset 00:12:51 ago, cause: software
                  Last software reset at 2020-11-30 14:18, reason: MemoryProtectionFault mmarValid daccViol, Move spinning, available RAM 99692, slot 1
                  Software reset code 0x4164 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427004 BFAR 0xb6d799a8 SP 0x2045ff58 Task MAIN
                  Stack: 00000060 000000c0 00000091 96969694 00000001 00468c29 00469614 8100000e 00455a21 0045f237 00000000 2040e064 a5000001 008e0d8e 2040e064 a5000001 00000000 00000001 204281fc 00469d17 0000a5c7 204103b4 2042820c 204281f0 204281fc 20428370 00000000
                  Error status: 0x00
                  MCU temperature: min 34.2, current 34.3, max 36.3
                  12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
                  Driver 0: position -3200, standstill, reads 61020, writes 17 timeouts 0, SG min/max 0/156
                  Driver 1: position -800, standstill, reads 61021, writes 17 timeouts 0, SG min/max 0/319
                  Driver 2: position 2000, standstill, reads 61022, writes 17 timeouts 0, SG min/max 0/184
                  Driver 3: position 0, standstill, reads 61024, writes 17 timeouts 0, SG min/max 0/182
                  Driver 4: position 0, standstill, reads 61027, writes 14 timeouts 0, SG min/max 0/0
                  Driver 5: position 0, standstill, reads 61031, writes 11 timeouts 0, SG min/max 0/0
                  Date/time: 2020-11-30 14:31:40
                  Slowest loop: 12.11ms; fastest: 0.21ms
                  === Storage ===
                  SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                  FreeDm 375 (min 372), maxWait 727688ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 13, completed moves 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                  === AuxDDARing ===
                  Segments left: 0
                  === Network ===
                  Slowest loop: 12.92ms; fastest: 0.03ms
                  - Ethernet -
                  State: active
                  === CAN ===
                  Messages queued 3089, send timeouts 6944, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
                    Thanks, please go ahead with the warranty exchange.
                    Viaundefined jrocklandundefined 2 Replies Last reply Reply Quote 0
                    • Viaundefined
                      Via @dc42
                      @dc42 received replacement board from E3D today and working as expected in standalone, will get round to putting SBC back in this week but happy there shouldn't be any further issues.
                      Thank's again to yourself and @chrishamm for the help
                      • jrocklandundefined
                        jrockland @dc42
                        @dc42 is there a way to properly "flush" the memory on thoses boards ?
                        I have been working on that issue for couples of weeks now on different setups and boards configuration and it seem to happen more and more often on most of them. I wonder if it could be caused by a bad sector or a bug and because of that spot it just happen more and more. (Sorry for my english here, Im french .. trying to explain clairly..)
                        Everytime I update/flash the firmware it seem to crash faster too.
                        At the moment Im down to testing different sd cards, maybe I got some fakes/cheaper cards causing the issue too.
                        Also important point: the setups I have who never been updated (some benchmarks and extruders tester) dont have that issue. Yet..
