    Update to RRF3 -> password doesn't work anymore
    Duet Web Control
    569
    • CMPundefined
      CMP
      I tried changing it with the command line after refreshing nothing changed.
      Accessing with a diffrent browers: No password required.
      When using M98 P"config.g":
      Microstepping - X:16(on), Y:16(on), Z:16(on), U:16(on), E:16(on):16(on)
      Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 299C
      Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 644C
      I assume that means my config.g is working.
      Is it possible that this problem has to do something with our network?
        Which version of DWC are you using? Check the Settings General tab.
        • CMPundefined
          CMP
          DWC 3.2.0
            Confirm that you are running the 6HC in standalone mode, not with a Pi attached?
            • CMPundefined
              CMP
              No, I'm using it with the Pi. But the Problem was the same with the duet 2 ethernet (but with an older RRF 3 Version)
              The password on the PI and the duet are the same.
              • Vetiundefined
                Veti
                @CMP said in Update to RRF3 -> password doesn't work anymore:
                this means there is an error with your micro stepping command.
                CMPundefined 1 Reply Last reply Reply Quote 0
                • CMPundefined
                  CMP @Veti
                  @Veti I think thats because I didn't care to write the command for 1/16 step for all steppers since its the default.
                  • Vetiundefined
                    Veti
                    did you try dc42 suggestion to send the M551 manually?
                    • CMPundefined
                      CMP
                      Yes I did and it didn't work
                      • chrishammundefined
                        chrishamm administrators
                        There is no support for password authentification in SBC mode yet. Since DuetPi + DSF v3.3 will get optional HTTPS support I'll check if I can add it to the next release.
                        To use M551 with v3.2 you must revert to standalone operation for now. If you are using your board(s) in standalone mode and it isn't working, please share your full config.g.
                        Duet software engineer
                        • CMPundefined
                          CMP
                          Thank you for the Information.
                          I'll try it in standalone mode, the next time I get the chance.
