    Z_probe issues with Anet A8
    575
    • Jagofletchundefined
      Jagofletch
      I've managed to get the Z axis motors working with the following change..
      I have an NO probe, so M558 required the "I1" command to invert the signal
      M558 P4 C"^zprobe.in" H5 F120 T6000
      changed to
      M558 P4 C"^zprobe.in" I1 H5 F120 T6000
      Now I'm still left with the issue of the probe recognising the bed (LED lights up when it's close enough) but the board not telling the motors to disengage.
      M119
      Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: at min stop
      • Vetiundefined
        Veti
        @Jagofletch said in Z_probe issues with Anet A8:
        I1 is a version 2 command. inversion is done with !
        if the z probe is always triggered there is a problem wit your wiring.
          Jagofletch
          The motors weren't engaging with ! but they've started working with the version 2 I1
          My probe isn't always triggered. It will trigger (LED on) when it senses the bed, as you would expect. I've checked the wiring for the Z probe multiple times but I will have a triple check.
          • Vetiundefined
            Veti
            the relevent information about triggering is what m119 reports
              Jagofletch
              Sorry, I must've deleted that from my last reply.
              M119
              I'm wondering if it may be that I'm using the wrong diode from the Probe in
              • Vetiundefined
                Veti
                if that is an npn probe
                Duet 3, Duet 2 Maestro, or revision 1.04 or later of Duet 2 WiFi or Duet 2 Ethernet: you can connect the output of the sensor directly to the Z-probe IN pin.
                  Jagofletch
                  I have 12v feeding the sensor, can the Z probe in handle that voltage? I'm not entirely sure what an NPN outputs on its signal wire.
                  • Vetiundefined
                    Veti
                    see
                    https://duet3d.dozuki.com/Wiki/Hardware_Overview
                    PCB revision v1.04
                    The Z probe input improved to tolerate inputs up to 30V.
                    so just make sure you have revision 1.04
                    • Vetiundefined
                      Veti
                      if you are not sure if your probe is npn why did you wire it as npn?
                        Jagofletch
                        Oh I was sure it was NPN. I'm just very new to Duet and there's a lot of info I'm having to juggle. So I may not be putting my point across properly.
                          Can you post the results of M122 to check the firmware version? Also post the results of M98 P"config.g"
                            Jagofletch
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
                            Board ID: 0JD0M-9P6M2-NW4SS-6JKFD-3SD6N-KUZBL
                            Used output buffers: 1 of 20 (10 max)
                            Static ram: 25632
                            Dynamic ram: 93680 of which 0 recycled
                            Exception stack ram used: 276
                            Never used ram: 11484
                            Tasks: NETWORK(ready,652) HEAT(blocked,852) MAIN(running,3816) IDLE(ready,196)
                            Owned mutexes:
                            Last reset 00:03:01 ago, cause: power up
                            Last software reset at 2021-02-05 20:20, reason: User, spinning module GCodes, available RAM 11356 bytes (slot 1)
                            Error status: 0
                            Free file entries: 10
                            MCU temperature: min 24.6, current 26.7, max 26.8
                            Supply voltage: min 12.4, current 12.5, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
                            Date/time: 2021-02-05 20:27:09
                            Cache data hit count 646318362
                            Slowest loop: 2.08ms; fastest: 0.07ms
                            I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                            Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                            Bed compensation in use: none
                            === MainDDARing ===
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0, aux move: no
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is idle in state(s) 0
                            serial is idle in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 15.44ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is running
                              WiFi firmware version 1.23
                              WiFi MAC address 24:a1:60:2f:8c:06
                              WiFi Vcc 3.33, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 23648
                              WiFi IP address 172.20.10.2
                              WiFi signal strength -65dBm, reconnections 0, sleep mode modem
                            M98 P"config.g"
                            HTTP is enabled on port 80
                            FTP is disabled
                            TELNET is disabled
                            Warning: M308 command is not supported
                            Warning: M950 command is not supported
                              Your config is trying to use the command syntax for RRF3 but you only have RRF2 installed. I suggest you update.
                              If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                              That will get your firmware and DWC up to date.
                              For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                              https://configtool.reprapfirmware.org/Start
                                Jagofletch
                                If anybody else is reading this and having the same troubles I will be back to post my methods for getting everything working. At the moment I have had some troubles with upgrading from 2.x to 3.x, that's now sorted, but it has messed with my configuration. Some of the axis don't respond, the probe still doesn't register and the axis that do work are reversed (even reversing the direction in config.g doesn't solve the issue). I have a few weeks of freelance work before I can get back to it.
