    Where the limit of stepper driver per boards come from ?
    Hardware dev
    574
    • jrocklandundefined
      jrockland
      I tried Duet3HC and they are a total disaster.
      I still try to get reprap to work with my machines..
      If I get a board made following the Duet3 design, could I just make it with 24 stepper drivers on the main board ? If there is a limitation, where would it be ?
      Thank
      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @jrockland
        @jrockland said in Where the limit of stepper driver per boards come from ?:
        Could you expand upon that a bit please.
        Saying they are a "total disaster" with no other information is of little use with regards to improving the product.
        jrocklandundefined 1 Reply Last reply Reply Quote 1
          Phaedrux Moderator @jrockland
          Step pulse generation maybe? Electrical connections to the CPU perhaps?
          jrocklandundefined 1 Reply Last reply Reply Quote 0
            jrockland @fcwilt
            @fcwilt I had been talking with the guy's here for over 2 months. Multiple communication and memory issues.
              jrockland @Phaedrux
              @Phaedrux well yea it is what I would love to know. If the Dev can tell me if it is possible Ill hire someone to make it.
              • fcwiltundefined
                fcwilt @jrockland
                Well it is a whole new architecture and the problems are being addressed.
                I certainly wouldn't call it a "disaster".
                I'm rather surprised it's going as well as it is.
                And I have complete faith it will all get sorted before too long.
                How many steppers do you need for your machines?
                  jrockland @fcwilt
                  @fcwilt o im sure they will find a way to make it work someday, but on 3 boards attached to different projects I couldnt get a single print out of it. So I called this a disaster.
                  biggest one is a double inverted h-bot on a xyzuv gantry (5 axis) equipt with a quad remote/direct extruder..:
                  2X, 2Y, 4Z, 4E and 1 for the treadmill bed. So 13 steppers.
                  Dont get me wrong, I think the guys did an awesome job with the firmware and the 6HC, but maybe can bus wasnt the best choice for communication... im not in electronic so Idk.
                  • fcwiltundefined
                    fcwilt @jrockland
                    A Duet 2 WiFi with Duex 5 can control 12 steppers if you use 2 external drivers.
                    Could you get by with 3Z?
                    So this is a combination printer and exercise machine?
                    jrocklandundefined 2 Replies Last reply Reply Quote 0
                      jrockland @fcwilt
                      @fcwilt I might give a try to the duet2, havent see much complaint about the duex 5.. but Im not sure I want to spend more money on duets. On our actual printers we use marlin's boards and we don't have issues.
                      The printer bed is a treadmill type (unlimited Z / non-stop parts production.)
                        jrockland @fcwilt
                        @fcwilt cant do 3Z, my gantry is 5 axis (does 45° angle on X and Y)
                        • fcwiltundefined
                          fcwilt @jrockland
                          I have five sets of Duet 2 WiFI / Duex 5 combos - it was my setup of choice - but the new Duet 3 parts look promising.
                          The only one I'm prepared to use in a printer at this point is the Duet 3 Mini 5 which is very nice for simple printers.
                          As to your 4Z setup - are you tilting the bed with it?
                          IF, I say IF that is the case why is 3Z not possible - 3 points define a plane.
