using M3 command to open and close a switch
CNC
647
    anagh
    Hello, I have a duet 3. I want to use the M3 command to open and close a switch. Initially, I tried to use a relay by connecting it to a fan output (out3). My hope is to be able to use the output3 voltage to switch the relay and close the switch. Here is what I used in config.h for that.
    M950 F0 C"out3" Q100 ; create fan 0 on pin out3 and set its frequency
    M563 P0 S"Spindle" F0
    M453 S"Spindle" P"out3" R12000 F2000 T0
    I read somewhere that the P parameter for M453 has been discontinued. When I remove P parameter, the "Spindle" in the DWC becomes inactive
    But when I send M3 S10000 command and connect a multimeter across the out3 pin, I don't get any voltage. Can anyone help me with this. The firmware I am using is 3.1.1.
    If there is any other better way to open or close a switch with M3 command (I can not use any other command), please let me know. Thanks!
      Why must you use M3? I don't understand the requirement.
      Rather than treating it as a fan, why not treat it as an i/o pin and switch it with M42.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M42_Switch_I_O_pin
        anagh
        @Phaedrux This is mainly due to legacy reasons. My Gcode has several M3 and M5 commands. If I decide to switch them with M42, it will be cumbersome. Also, I use one more machine with a different controller which uses M3 and M5. So I will have to maintain separate sets of Gcodes for both machines.
        I can use M42 as a last resort. But preferrably, I would like to use M3 and M5.
          A Former User
          Does your M3 specify an fixed RPM with the S parameter? If so you should be able to use just M435 C"out3" Rn where n is the same RPM you use for M3.
          @anagh said in using M3 command to open and close a switch:
          M453
          in 3.2 M435 has a dedicated pin for on/off shouldn't that do what you need it to do regardless of speeds?
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_in_RepRapFirmware_3_2_and_later
          in either case skip the M950 and M106 not sure you need M563 either.
            anagh
            My M3 does not specify a fixed speed. For the other controller, my Gcode just has M3 without the S parameter.
            I will try using just M435 and let you know how it goes. Thanks for your help!
              anagh
              @bearer I tried using M453 C"out3" R5000 in config.h. After that when I send the M3 S5000 command, I get a message saying "M3 S5000 command not supported in machine mode FFF". When I just M3, it accepts it but I don't get any voltage across out3 and after that when I send M5, I get the same error message of command not supported.
              Am I doing something wrong here?
              ? 1 Reply Last reply 21 Oct 2020, 14:32 Reply Quote 0
                A Former User @anagh
                sounds like M453 didn't put the firmware in cnc mode
                what do you get if you query with M450?
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M450_Report_Printer_Mode
                  anagh
                  In hindsight, the error is funny. In your earlier message, you mentioned M435 instead of M453. So I typed in M435 instead of M453 even though I knew I had to use M453.
                  I corrected that and now it is working. I have to use M3 Sxxxx to turn on the switch instead of just M3 like I did for the other controller but I will live with it.
                  Thanks a lot for your help.
                    A Former User
                    lol, sorry - don't trust random strangers on the internet at 3am😇
                    anyways, as long as the other controller doesn't complain about he S parameter then I'd say thats the way to go then.
                      Alpenprinter
                      I have a quite similar Problem:
                      I want to switch a on/off realy to switch the spindle via the M3/M5 command.
                      The relay is connected the fan port 7 of a Duet3 board.
                      I configured the following lines:
                      "M453 P7 S0 T0 C"out1+out7+out2" ; set CNC Mode"
                      Result:
                      "M3" does not switch the relay, but "M3 S1" does.
                      "M5" stops the spindle, as intended.
                      How can I configure the board, so I can switch the spindle with "M3" only, without M1, because this is how the gcode ist generated my the postprocessor?
