    New experimental firmware 1.19beta9
    Firmware installation
    12
    56
    6.7k
    • tapeundefined
      tape
      hello after firmware update for 1.19beta the wifi module stoped responding,
      Upload successful
      WiFi module started
      Error: Failed to initialise WiFi module, code -10
      [ERROR] Error: Failed to initialise WiFi module, code -10
      what can i do to fix this?
      thanks in advance
        A Former User
        @tape: Do you mean "update from 1.19 beta"? Please check if all the firmware versions are correct or just try flashing Firmware/Server again.
        My question:
        In standalone access point mode (M589 S"DuetWifi" P"Silverspoon" I192.168.1.1 –> M552 S2) I can connect to the DuetWifi.
        DHCP works as I get an IP adress but "ping 192.168.1.1" leads to "Destination Host Unreachable".
        So I don't have access to the web interface. However the Web Control was accessible before when connecting to a known network (mode M552 S1).
        • larsundefined
          lars
          @lars:
          I get some weird behaviour when using the web interface Machine Control with second tool.
          Test Setup:
          Disable all tool change scripts.
          Run home all (Script will inactivate both tools with T-1)
          Switch to T0 and move it to -33 as I don’t want T1 to crash into it
          Switch to T1
          X -1
          T1 moves to min position (-5) and stops to respond to X interface commands.
          I can however move T1 using the g-code console: G1 X10 will move t1 to X10 absolute.
          Once I have issued G1 X10 in the g-code console I can use the interface Machine Control again to move X.
          If I switch T0 and back to T1 the first x command in the Machine Control will move T1 to min position (-5) and stops to respond to X interface commands.
          I have tracked down this bug to how currentUserPosition is used in GCodes::DoStraightMove. After tool switch to T1 and a G1 X-1 is issued it currentUserPosition[0] (x-axis) has the value of T0 X (-33 in the quoted example). It will take this value and substract 1 for relative move of X. Later in the code this value (-32) is mapped to U and limited to min value -5 (So T1 will in my case move from 525 to -5 when issuing a relative move G1 X-1).
          Either the currentUserPosition must be updated on tool change so that the X reflects the mapped tools coord or the mapping need to be done in DoStraightMove… Whats do you think David?
            @lars:
            @dc42:
            Lars, thanks for running that. If you want to try fixing it yourself, I believe the issue is with CoreBaseKinematics.cpp line 47. It should call ZLeadscrewKinematics::Configure not Kinematics::Configure.
            Did the change you suggested and got it working:
            M671
            Z leadscrew coordinates (250.0,560.0) (560.0,-10.0) (-60.0,-10.0), maximum correction 0.50mm
            G32
            Simulated calibrating 3 leadscrews using 3 points, deviation before 0.098 after 0.000, corrections: -0.189 -0.065 0.118
            Found one small bug in ZLeadscrewKinematics::Configure:
            bool seenS;
            gb.TryGetFValue('S', maxCorrection, seenS);
            Need to initialize seenS to false or you will not get reporting of current settings…
            Thanks, I've just put that fix in my source code.
              @tape:
              Upload successful
              WiFi module started
              thanks in advance
              Were you upgrading from version 1.18.2 or earlier? If so, did you follow the instructions at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta as specified in the first post in this thread?
                @Eddiie:
                @dc42:
                Eddie, what happens if you command bed levelling from PanelDue and then look at the Console page? When you say 'bed levelling' do you mean G31 auto calibration, or G29 mesh bed compensation?
                The console says nothing more after successfully connected to the network and showing the ip address.
                strange.
                I am not sure what the bed leveling button issues as a leveling command; I meant to ask that -
                WebUI says "Auto Delta Calibration" (button) clicking the drop-down there are options, of course, Run mesh, Show Mesh, etc… Selecting these says there is no valid grid defined for G29.
                Here is the contents of my bed.g, - OH, I guess this is G31, Auto. Tthe Paneldue and WebUI appear to execute the same function when pressing the button.
                Can try other betas if you want me to. This is the same bed.g that has been in use since I owned the board.
                ; Auto calibration routine for delta printers
                ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g.
                M561						; clear any bed transform, otherwise homing may be at the wrong height
                G31 X0 Y0					; don't want any probe offset for this
                G28						; home the printer
                ;G1 X0 Y0 Z350 F8000
                ;*** Remove the following line if your Z probe does not need to be deployed
                ;M98 Pdeployprobe.g			; deploy the mechanical Z probe
                ; The first time the mechanical probe is used after deployment, it gives slightly different results.
                ; So do an extra dummy probe here. The value stored gets overwritten later. You can remove this if you use an IR probe.
                ;G30 P0 X0 Y0 Z-99999
                ; Probe the bed and do 6- or 7-factor auto calibration
                ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                ; 16 points, 7 factors, probing radius: 75, probe offset (12, 0)
                G30 P0 X0.00 Y74.06 Z-99999 H0
                G30 P1 X38.45 Y46 Z-99999 H0
                G30 P2 X63.79 Y11.25 Z-99999 H0
                G30 P3 X56.91 Y-32.86 Z-99999 H0
                G30 P4 X14.08 Y-66.15 Z-99999 H0
                G30 P5 X-25.65 Y-70.48 Z-99999 H0
                G30 P6 X-64.95 Y-37.50 Z-99999 H0
                G30 P7 X-53.86 Y13.02 Z-99999 H0
                G30 P8 X-48.21 Y57.45 Z-99999 H0
                G30 P9 X0.00 Y35.72 Z-99999 H0
                G30 P10 X25.23 Y14.57 Z-99999 H0
                G30 P11 X25.23 Y-14.57 Z-99999 H0
                G30 P12 X0.00 Y-35.72 Z-99999 H0
                G30 P13 X-32.48 Y-18.75 Z-99999 H0
                G30 P14 X-32.48 Y18.75 Z-99999 H0
                G30 P15 X0 Y0 Z-99999 S7
                ;*** Remove the following line if your Z probe does not need to be retracted
                ;M98 Pretractprobe.g				; retract the mechanical Z probe
                G1 X0 Y0 Z150 F15000			; get the head out of the way of the bed
                The G1 X0 Y0 Z150 F1500 no longer does anything or does not get executed.
                Let me try commenting out that line real quick as a test..
                – Commenting out the G1 line had no affect.
                Let me try removing F30 P15 line.
                Ok, commenting G30 P15 X0 Y0 Z-99999 S7 out, the script completed.
                However, it never reports the before and after settings. So that line is probably where the problem is.
                One last note:
                Hitting the button from the paneldue does not cause an AJAX error on the WebUI. Whereas, clicking the button in the webUI to level the bed, will generate an AJAX error, on the Paneldue console it will say "connected to wifi network" and show the ip address it obtained, again. So something restarts when issuing the command from the WebUI that does not restart when doing it from the Paneldue. I gunna say the S7 parameter is what causes something bad to happen. The head moves to that location.. the very next thing is S7.
                Let me know if there is more I can do.
                Ok, so you meant auto delta calibration, not bed levelling. It's working for me. When you get the Ajax Error message, what is the Error Reason given at the bottom of the error message box?
                  @nokian:
                  My question:
                  There is a bug that is causing message packets to be lost when the WiFi module is put into access point mode. We haven't tracked it down yet. Some other projects are having the same problem, so it looks like the bug may be in SDK code that is closed source.
                    @lars:
                    @lars:
                    Test Setup:
                    Switch to T1
                    X -1
                    Thanks for investigating this. I'll take a look at it tomorrow. I thought we were already updating currentUserPosition on a tool change.
                    • larsundefined
                      lars
                      Need to increment numXAxes, numYAxes in GCodes::ToolOffsetInverseTransform! Added in code below.
                      void GCodes::ToolOffsetInverseTransform(const float coordsIn[MaxAxes], float coordsOut[MaxAxes])
                      	const Tool * const currentTool = reprap.GetCurrentTool();
                      	if (currentTool == nullptr)
                      		for (size_t axis = 0; axis < numVisibleAxes; ++axis)
                      			coordsOut[axis] = coordsIn[axis]/axisScaleFactors[axis];
                      	else
                      		const uint32_t xAxes = reprap.GetCurrentXAxes();
                      		const uint32_t yAxes = reprap.GetCurrentYAxes();
                      		float xCoord = 0.0, yCoord = 0.0;
                      		size_t numXAxes = 0, numYAxes = 0;
                      			coordsOut[axis] = coordsIn[axis] + currentTool->GetOffset()[axis];
                      			if ((xAxes & (1u << axis)) != 0)
                      				xCoord += coordsIn[axis]/axisScaleFactors[axis] + currentTool->GetOffset()[axis];
                      				numXAxes += 1; <-----------------
                      			if ((yAxes & (1u << axis)) != 0)
                      				yCoord += coordsIn[axis]/axisScaleFactors[axis] + currentTool->GetOffset()[axis];
                      				numYAxes += 1; <-----------------
                      		if (numXAxes != 0)
                      			coordsOut[X_AXIS] = xCoord/numXAxes;
                      		if (numYAxes != 0)
                      			coordsOut[Y_AXIS] = yCoord/numYAxes;
                      	coordsOut[Z_AXIS] -= (currentZHop + currentBabyStepZOffset)/axisScaleFactors[Z_AXIS];
                      • Eddiieundefined
                        Eddiie
                        @dc42:
                        It is working for you using the same settings I posted above?
                        Communication Error
                        An AJAX error has been reported, so the current session has been terminated.
                        Please check if your printer is still on and try to connect again.
                        Error reason: timeout
                        Before going to beta9 I was on beta6 which worked ok for "auto delta calibration" button on the WebUI and on the Paneldue but wifi did not work reliably.
                        Testing betas 6, 7, 8, 9, my problem with auto delta calibration began with beta8. Any suggestions?
                        Changing bed.g, allows the calibration to be reported, but don't think it gets stored..
                        ;G30 P15 X0 Y0 Z-99999 S7
                        G30 P15 X0 Y0 Z-99999 S-1
                        However, if I reverse the commands so that S-1 is done before S7, I get new message
                        "Bed calibration error: 7 factor calibration requested but only 0 positions provided."
                        – I guess S-1 prints the values then empties the memory.
                        -- S4 behaves the sames as S7.
                          Eddiie, thanks for testing those firmware versions, know I know is where to look for the problem.
                          Lars, thanks again.
                            @Eddiie:
                            -- I guess S-1 prints the values then empties the memory.
                            Thanks. Please can you connect Pronterface or another USB host program, then send M111 S1 P4 to enable Move module debug output. Then run your normal auto calibration routine. You should get a pile of output, something like this:
                            >>> m111s1p4
                            SENDING:M111S1P4
                            Debugging enabled for modules: Move(4)
                            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11)
                            ; G31 sent here
                            Z probe offsets: 1.057 1.064 0.320 0.357 0.348 0.340 0.261 0.328 0.296 0.271 0.299 0.324 0.371 0.415 0.379 0.336, mean 0.423, deviation from mean 0.244
                            Stops X1.008 Y-0.638 Z-0.370 height 470.183 diagonal 360.290 radius 180.338 xcorr -0.15 ycorr 0.10 zcorr 0.00 xtilt -0.110% ytilt 0.020%
                            Derivative matrix
                            Normal matrix
                            Solved matrix
                            Solution: -0.9157 -1.8949  1.3887  0.2035  1.1017 -0.1917 -0.5625  2.2428
                            Residuals:  0.2199  0.1975 -0.3050  0.0289  0.1166  0.0552 -0.1193 -0.0617  0.0439  0.1128 -0.0040 -0.2779 -0.0455  0.0023  0.0606 -0.0241
                            Expected probe error:  0.2029  0.1733 -0.3350 -0.0003  0.0934  0.0381 -0.1296 -0.0632  0.0474  0.1124 -0.0110 -0.2896 -0.0661 -0.0194  0.0533 -0.0411
                            Derivative matrix
                            Normal matrix
                            Solved matrix
                            Solution:  0.0742  0.1298 -0.1810  0.0102 -0.0396  0.0284  0.0135 -0.1845
                            Residuals:  1.0768  1.0913  0.3501  0.3830  0.3720  0.3548  0.2685  0.3317  0.2945  0.2681  0.3044  0.3385  0.3790  0.4441  0.3915  0.3532
                            Expected probe error:  0.2226  0.2006 -0.3055  0.0260  0.1171  0.0532 -0.1225 -0.0601  0.0457  0.1097 -0.0060 -0.2755 -0.0582  0.0091  0.0657 -0.0243
                            Stops X0.633 Y-1.937 Z1.304 height 469.840 diagonal 360.290 radius 180.552 xcorr 0.92 ycorr -0.06 zcorr 0.00 xtilt -0.476% ytilt 1.392%
                            where … represents several rows of numbers. Please post that output.
                            • Eddiieundefined
                              Eddiie
                              I notice at the end of "auto delta calibration" that the serial port disconnects.
                              I am a network guy, my terminal of choice is currently Putty.
                              Here is the output:
        ok
        Z probe offsets: 3.972 2.639 2.760 2.408 2.649 3.463 3.923 2.348 3.903 1.253 0.840 0.557 0.731 0.944 1.210 0.114, mean 2.107, deviation from mean 1.269
        Stops X0.000 Y0.000 Z0.000 height 349.900 diagonal 215.000 radius 88.000 xcorr 0.00 ycorr 0.00 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                                        Derivative matrix
                              Your radius is 180, mine is 88, radius is the middle to edge of print plate, right?
                                It sounds like your Duet is resetting after running auto calibration. So please run it again, then reconnect (via the web is fine) without resetting the Duet again and run M122. Post the data listed under "Least Reset Reason" and "Last software reset code".
                                • Eddiieundefined
                                  Eddiie
                                  I am using M997 to move between firmware versions. (bottom of this page: https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta ). I notice after the upgrade that the DuetWiFiFirmware.bin file has been deleted but the DuetWiFiServer.bin file remains.
                                  Thank you for your time looking in to this.
                                  Used output buffers: 1 of 32 (10 max)
                                  RepRapFirmware for Duet WiFi version 1.19beta9 running on Duet WiFi 1.0 + DueX2
                                  Board ID: *****-*****-*****-*****-*****-*****  (removed)
                                  Static ram used: 20904
                                  Dynamic ram used: 99352
                                  Recycled dynamic ram: 2624
                                  Stack ram used: 4000 current, 5212 maximum
                                  Never used ram: 2980
                                  Last reset 00:01:44 ago, cause: software
                                  Last software reset reason: Hard fault, spinning module GCodes, available RAM 0 bytes (slot 1)
                                  Software reset code 0x0033, HFSR 0x40000000, CFSR 0x00008200, ICSR 0x00400803, BFAR 0x29955924, SP 0x2001d3f4
                                  Stack: 00440bb9 0044077a 81000000 200037f4 00000000 000003f9 00000007 e0000000 3fe12609 2001d578 3fe12609 00000000 ffffffe9 5555554c 00155555 97bcbd77 ffe5fe63 ee000000
                                  Error status: 0
                                  Free file entries: 10
                                  ```snip…
                                    Thanks again. From that I can see that is it crashing in a part of the C library that converts floating point numbers to/from character strings using heap-allocated RAM. The never-used RAM in your M122 report is 4.5Kb less than mine is straight after a restart, and given how much extra stack is needed during auto calibration. it's clear that you have been running out of memory during the auto calibration calculation.
                                    I'll increase the free memory headroom in the next beta. Are you using multiple tool definitions? That might explain why you have less free memory available than I do.
                                    • Eddiieundefined
                                      Eddiie
                                      Ah that is it! I have 12 tools defined also a bunch of macros. Diamond hotend.
                                      Most examples show 16 tools. I actually thought of having 32 tools or so. One set for cmy and another for rgb.
                                      Maybe even more for other colors.
                                      Virtual tools are awesome!
                                      I can remove some until the next release. I only use about 8 at one time mostly. Thank you again.
                                      Removed 2 tools, results were shown at then end of calibration, however AJAX error soon followed.
                                      Removed 3 tools and everything seems to be working now.
                                      Curious, how much RAM do you have to play with?
                                      Note, the number of tools has not changed in my configuration for quite some time. Still, something in beta 8 changed to use more RAM.
                                        Yes, beta 8 and 9 use more RAM than earlier versions, and I hadn't noticed how low the headroom had become. I'm reducing the maximum number of random probe points from 64 to 32 in beta 10, which will reduce the static memory requirement by 384 bytes and the auto calibration memory requirement by 3.6Kb (the calibration routine allocates matrices for the maximum allowed number of points). Now that we have mesh bed levelling too, using a large number of auto calibration points seems rather pointless to me.
                                        On my delta running beta9 with just 1 tool configured, never used RAM is reported as 7284 if I send M122 immediately after startup, and 780 after running auto calibration.
                                        I suggest you check that you still have some "never used RAM" left after you run auto calibration with whatever number of tools you want to define. Defining macros doesn't use additional RAM, but running nested macros or running multiple macros concurrently uses a little.
                                        • larsundefined
                                          lars
                                          Is there a change to how speed is set after tool change? In beta 9 I get a very slow (first?) move after tool change compared to beta6 (or was it beta 5)…
                                          The gcode looks ok, setting a decent speed for first layer.Feels like the F6000 is ignored in [c]G0 F6000 X224.353 Y241.088 Z0.3[/c]
                                          G1 X224.04 Y242.012 E10.5916
                                          G1 X224.159 Y241.537 E10.60082
                                          G1 X224.353 Y241.088 E10.61002
                                          G1 F1200 E-5.38998
                                          G92 E0
                                          G91
                                          G1 Z1 F1800 ; move bed down
                                          G90
                                          T1
                                          G92 E0
                                          M203 Z5
                                          M109 S210
                                          M104 T0 S180
                                          G1 F1800 E-2
                                          G0 F6000 X224.353 Y251.088
                                          G0 X219.409 Y243.144
                                          ;TYPE:SKIRT
                                          G1 F1800 E0
                                          G1 F3000 X219.416 Y242.676 E0.00946
                                          ```I only have tfreeX.g tool change scrips.
                                          tfree0.g:
                                          G90
                                          G1 X-33 F18000
                                          G90
                                          G1 X525 F18000
                                            deckingman
                                            @Eddiie:
                                            Eddie. Another way to manage tools with a Diamond is to keep a simple set of tools defined in config.g then define more tools or change mixing ratios in your slicer start gcode. It has the advantage that whenever you print the object, the right mixing ratios will be set (you just need to load the correct filament into each extruder).
