    New experimental firmware 1.19beta9
    Firmware installation
    12
    56
    6.8k
    • MrBlomundefined
      MrBlom
      same as cubexupgrade cant get the X and Y working
      on a corexy
      they are swaped
      • DjDemonDundefined
        DjDemonD
        Yeah I just noticed this on my corexy, had to swap the y motor direction in the end. Working now.
        www.precisionpiezo.co.uk
          deckingman
          @MrBlom:
          on a corexy
          they are swaped
          See the Big Bold letters in DC's original post
          • larsundefined
            lars
            @dc42:
            Lars, thanks for running that. If you want to try fixing it yourself, I believe the issue is with CoreBaseKinematics.cpp line 47. It should call ZLeadscrewKinematics::Configure not Kinematics::Configure.
            Did the change you suggested and got it working:
            M671
            Z leadscrew coordinates (250.0,560.0) (560.0,-10.0) (-60.0,-10.0), maximum correction 0.50mm
            G32
            Simulated calibrating 3 leadscrews using 3 points, deviation before 0.098 after 0.000, corrections: -0.189 -0.065 0.118
            Found one small bug in ZLeadscrewKinematics::Configure:
            bool seenS;
            gb.TryGetFValue('S', maxCorrection, seenS);
            Need to initialize seenS to false or you will not get reporting of current settings…
            • MrBlomundefined
              MrBlom
              @deckingman:
              @MrBlom:
              on a corexy
              they are swaped
              this dident work for me
              Important! On a CoreXY machine, you need to either swap the X and Y motor connections, or set the Y axis factor to -1 in the M667 command. Similarly for CoreXZ and CoreXYU machines.
              • Eddiieundefined
                Eddiie
                @dc42:
                Eddie, what happens if you command bed levelling from PanelDue and then look at the Console page? When you say 'bed levelling' do you mean G31 auto calibration, or G29 mesh bed compensation?
                The console says nothing more after successfully connected to the network and showing the ip address.
                strange.
                I am not sure what the bed leveling button issues as a leveling command; I meant to ask that -
                WebUI says "Auto Delta Calibration" (button) clicking the drop-down there are options, of course, Run mesh, Show Mesh, etc… Selecting these says there is no valid grid defined for G29.
                Here is the contents of my bed.g, - OH, I guess this is G31, Auto. Tthe Paneldue and WebUI appear to execute the same function when pressing the button.
                Can try other betas if you want me to. This is the same bed.g that has been in use since I owned the board.
                ; Auto calibration routine for delta printers
                ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g.
                M561						; clear any bed transform, otherwise homing may be at the wrong height
                G31 X0 Y0					; don't want any probe offset for this
                G28						; home the printer
                ;G1 X0 Y0 Z350 F8000
                ;*** Remove the following line if your Z probe does not need to be deployed
                ;M98 Pdeployprobe.g			; deploy the mechanical Z probe
                ; The first time the mechanical probe is used after deployment, it gives slightly different results.
                ; So do an extra dummy probe here. The value stored gets overwritten later. You can remove this if you use an IR probe.
                ;G30 P0 X0 Y0 Z-99999
                ; Probe the bed and do 6- or 7-factor auto calibration
                ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                ; 16 points, 7 factors, probing radius: 75, probe offset (12, 0)
                G30 P0 X0.00 Y74.06 Z-99999 H0
                G30 P1 X38.45 Y46 Z-99999 H0
                G30 P2 X63.79 Y11.25 Z-99999 H0
                G30 P3 X56.91 Y-32.86 Z-99999 H0
                G30 P4 X14.08 Y-66.15 Z-99999 H0
                G30 P5 X-25.65 Y-70.48 Z-99999 H0
                G30 P6 X-64.95 Y-37.50 Z-99999 H0
                G30 P7 X-53.86 Y13.02 Z-99999 H0
                G30 P8 X-48.21 Y57.45 Z-99999 H0
                G30 P9 X0.00 Y35.72 Z-99999 H0
                G30 P10 X25.23 Y14.57 Z-99999 H0
                G30 P11 X25.23 Y-14.57 Z-99999 H0
                G30 P12 X0.00 Y-35.72 Z-99999 H0
                G30 P13 X-32.48 Y-18.75 Z-99999 H0
                G30 P14 X-32.48 Y18.75 Z-99999 H0
                G30 P15 X0 Y0 Z-99999 S7
                ;*** Remove the following line if your Z probe does not need to be retracted
                ;M98 Pretractprobe.g				; retract the mechanical Z probe
                G1 X0 Y0 Z150 F15000			; get the head out of the way of the bed
                The G1 X0 Y0 Z150 F1500 no longer does anything or does not get executed.
                Let me try commenting out that line real quick as a test..
                – Commenting out the G1 line had no affect.
                Let me try removing F30 P15 line.
                Ok, commenting G30 P15 X0 Y0 Z-99999 S7 out, the script completed.
                However, it never reports the before and after settings. So that line is probably where the problem is.
                One last note:
                Hitting the button from the paneldue does not cause an AJAX error on the WebUI. Whereas, clicking the button in the webUI to level the bed, will generate an AJAX error, on the Paneldue console it will say "connected to wifi network" and show the ip address it obtained, again. So something restarts when issuing the command from the WebUI that does not restart when doing it from the Paneldue. I gunna say the S7 parameter is what causes something bad to happen. The head moves to that location.. the very next thing is S7.
                Let me know if there is more I can do.
                • tapeundefined
                  tape
                  hello after firmware update for 1.19beta the wifi module stoped responding,
                  Upload successful
                  WiFi module started
                  Error: Failed to initialise WiFi module, code -10
                  [ERROR] Error: Failed to initialise WiFi module, code -10
                  what can i do to fix this?
                  thanks in advance
                    A Former User
                    @tape: Do you mean "update from 1.19 beta"? Please check if all the firmware versions are correct or just try flashing Firmware/Server again.
                    My question:
                    In standalone access point mode (M589 S"DuetWifi" P"Silverspoon" I192.168.1.1 –> M552 S2) I can connect to the DuetWifi.
                    DHCP works as I get an IP adress but "ping 192.168.1.1" leads to "Destination Host Unreachable".
                    So I don't have access to the web interface. However the Web Control was accessible before when connecting to a known network (mode M552 S1).
                    • larsundefined
                      lars
                      @lars:
                      I get some weird behaviour when using the web interface Machine Control with second tool.
                      Test Setup:
                      Disable all tool change scripts.
                      Run home all (Script will inactivate both tools with T-1)
                      Switch to T0 and move it to -33 as I don’t want T1 to crash into it
                      Switch to T1
                      X -1
                      T1 moves to min position (-5) and stops to respond to X interface commands.
                      I can however move T1 using the g-code console: G1 X10 will move t1 to X10 absolute.
                      Once I have issued G1 X10 in the g-code console I can use the interface Machine Control again to move X.
                      If I switch T0 and back to T1 the first x command in the Machine Control will move T1 to min position (-5) and stops to respond to X interface commands.
                      I have tracked down this bug to how currentUserPosition is used in GCodes::DoStraightMove. After tool switch to T1 and a G1 X-1 is issued it currentUserPosition[0] (x-axis) has the value of T0 X (-33 in the quoted example). It will take this value and substract 1 for relative move of X. Later in the code this value (-32) is mapped to U and limited to min value -5 (So T1 will in my case move from 525 to -5 when issuing a relative move G1 X-1).
                      Either the currentUserPosition must be updated on tool change so that the X reflects the mapped tools coord or the mapping need to be done in DoStraightMove… Whats do you think David?
                        @lars:
                        @dc42:
                        M671
                        G32
                        bool seenS;
                        Thanks, I've just put that fix in my source code.
                          @tape:
                          Upload successful
                          WiFi module started
                          thanks in advance
                          Were you upgrading from version 1.18.2 or earlier? If so, did you follow the instructions at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta as specified in the first post in this thread?
                            @Eddiie:
                            @dc42:
                            strange.
                            One last note:
                            Ok, so you meant auto delta calibration, not bed levelling. It's working for me. When you get the Ajax Error message, what is the Error Reason given at the bottom of the error message box?
                              @nokian:
                              My question:
                              There is a bug that is causing message packets to be lost when the WiFi module is put into access point mode. We haven't tracked it down yet. Some other projects are having the same problem, so it looks like the bug may be in SDK code that is closed source.
                                @lars:
                                @lars:
                                Test Setup:
                                Switch to T1
                                X -1
                                Thanks for investigating this. I'll take a look at it tomorrow. I thought we were already updating currentUserPosition on a tool change.
                                • larsundefined
                                  lars
                                  Need to increment numXAxes, numYAxes in GCodes::ToolOffsetInverseTransform! Added in code below.
                                  void GCodes::ToolOffsetInverseTransform(const float coordsIn[MaxAxes], float coordsOut[MaxAxes])
                                  	const Tool * const currentTool = reprap.GetCurrentTool();
                                  	if (currentTool == nullptr)
                                  		for (size_t axis = 0; axis < numVisibleAxes; ++axis)
                                  			coordsOut[axis] = coordsIn[axis]/axisScaleFactors[axis];
                                  	else
                                  		const uint32_t xAxes = reprap.GetCurrentXAxes();
                                  		const uint32_t yAxes = reprap.GetCurrentYAxes();
                                  		float xCoord = 0.0, yCoord = 0.0;
                                  		size_t numXAxes = 0, numYAxes = 0;
                                  			coordsOut[axis] = coordsIn[axis] + currentTool->GetOffset()[axis];
                                  			if ((xAxes & (1u << axis)) != 0)
                                  				xCoord += coordsIn[axis]/axisScaleFactors[axis] + currentTool->GetOffset()[axis];
                                  				numXAxes += 1; <-----------------
                                  			if ((yAxes & (1u << axis)) != 0)
                                  				yCoord += coordsIn[axis]/axisScaleFactors[axis] + currentTool->GetOffset()[axis];
                                  				numYAxes += 1; <-----------------
                                  		if (numXAxes != 0)
                                  			coordsOut[X_AXIS] = xCoord/numXAxes;
                                  		if (numYAxes != 0)
                                  			coordsOut[Y_AXIS] = yCoord/numYAxes;
                                  	coordsOut[Z_AXIS] -= (currentZHop + currentBabyStepZOffset)/axisScaleFactors[Z_AXIS];
                                  • Eddiieundefined
                                    Eddiie
                                    @dc42:
                                    It is working for you using the same settings I posted above?
                                    Communication Error
                                    An AJAX error has been reported, so the current session has been terminated.
                                    Please check if your printer is still on and try to connect again.
                                    Error reason: timeout
                                    Before going to beta9 I was on beta6 which worked ok for "auto delta calibration" button on the WebUI and on the Paneldue but wifi did not work reliably.
                                    Testing betas 6, 7, 8, 9, my problem with auto delta calibration began with beta8. Any suggestions?
                                    Changing bed.g, allows the calibration to be reported, but don't think it gets stored..
                                    ;G30 P15 X0 Y0 Z-99999 S7
                                    G30 P15 X0 Y0 Z-99999 S-1
                                    However, if I reverse the commands so that S-1 is done before S7, I get new message
                                    "Bed calibration error: 7 factor calibration requested but only 0 positions provided."
                                    – I guess S-1 prints the values then empties the memory.
                                    -- S4 behaves the sames as S7.
                                      Eddiie, thanks for testing those firmware versions, know I know is where to look for the problem.
                                      Lars, thanks again.
                                        @Eddiie:
                                        -- I guess S-1 prints the values then empties the memory.
                                        Thanks. Please can you connect Pronterface or another USB host program, then send M111 S1 P4 to enable Move module debug output. Then run your normal auto calibration routine. You should get a pile of output, something like this:
                                        >>> m111s1p4
                                        SENDING:M111S1P4
                                        Debugging enabled for modules: Move(4)
                                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11)
                                        ; G31 sent here
                                        Z probe offsets: 1.057 1.064 0.320 0.357 0.348 0.340 0.261 0.328 0.296 0.271 0.299 0.324 0.371 0.415 0.379 0.336, mean 0.423, deviation from mean 0.244
                                        Stops X1.008 Y-0.638 Z-0.370 height 470.183 diagonal 360.290 radius 180.338 xcorr -0.15 ycorr 0.10 zcorr 0.00 xtilt -0.110% ytilt 0.020%
                                        Derivative matrix
                                        Normal matrix
                                        Solved matrix
                                        Solution: -0.9157 -1.8949  1.3887  0.2035  1.1017 -0.1917 -0.5625  2.2428
                                        Residuals:  0.2199  0.1975 -0.3050  0.0289  0.1166  0.0552 -0.1193 -0.0617  0.0439  0.1128 -0.0040 -0.2779 -0.0455  0.0023  0.0606 -0.0241
                                        Expected probe error:  0.2029  0.1733 -0.3350 -0.0003  0.0934  0.0381 -0.1296 -0.0632  0.0474  0.1124 -0.0110 -0.2896 -0.0661 -0.0194  0.0533 -0.0411
                                        Derivative matrix
                                        Normal matrix
                                        Solved matrix
                                        Solution:  0.0742  0.1298 -0.1810  0.0102 -0.0396  0.0284  0.0135 -0.1845
                                        Residuals:  1.0768  1.0913  0.3501  0.3830  0.3720  0.3548  0.2685  0.3317  0.2945  0.2681  0.3044  0.3385  0.3790  0.4441  0.3915  0.3532
                                        Expected probe error:  0.2226  0.2006 -0.3055  0.0260  0.1171  0.0532 -0.1225 -0.0601  0.0457  0.1097 -0.0060 -0.2755 -0.0582  0.0091  0.0657 -0.0243
                                        Stops X0.633 Y-1.937 Z1.304 height 469.840 diagonal 360.290 radius 180.552 xcorr 0.92 ycorr -0.06 zcorr 0.00 xtilt -0.476% ytilt 1.392%
                                        where … represents several rows of numbers. Please post that output.
                                        • Eddiieundefined
                                          Eddiie
                                          I notice at the end of "auto delta calibration" that the serial port disconnects.
                                          I am a network guy, my terminal of choice is currently Putty.
                                          Here is the output:
        ok
        Z probe offsets: 3.972 2.639 2.760 2.408 2.649 3.463 3.923 2.348 3.903 1.253 0.840 0.557 0.731 0.944 1.210 0.114, mean 2.107, deviation from mean 1.269
        Stops X0.000 Y0.000 Z0.000 height 349.900 diagonal 215.000 radius 88.000 xcorr 0.00 ycorr 0.00 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                                                    Derivative matrix
                                          Your radius is 180, mine is 88, radius is the middle to edge of print plate, right?
                                            It sounds like your Duet is resetting after running auto calibration. So please run it again, then reconnect (via the web is fine) without resetting the Duet again and run M122. Post the data listed under "Least Reset Reason" and "Last software reset code".
