    First trigger height way off than following
    • PuddingBaer91undefined
      PuddingBaer91
      Hi there,
      i upgraded my Anycubic Predator (delta printer) with the duet smart effector. I noticed when i calibrate the trigger height the first probe is often much more off than the following probes: (probing at the same XY location!)
      10.2.2021, 12:51:38	M98 P"0:/macros/trigger height"
      Stopped at height -0.206 mm
      10.2.2021, 12:51:35	M98 P"0:/macros/trigger height"
      Stopped at height -0.212 mm
      10.2.2021, 12:51:33	M98 P"0:/macros/trigger height"
      10.2.2021, 12:51:32	M98 P"0:/macros/trigger height"
      Stopped at height -0.199 mm
      10.2.2021, 12:51:29	M98 P"0:/macros/trigger height"
      Stopped at height -0.193 mm
      10.2.2021, 12:51:27	M98 P"0:/macros/trigger height"
      10.2.2021, 12:51:24	M98 P"0:/macros/trigger height"
      As i am using 0.9° steppers the difference should only be 0.006 mm. Whats the problem here?
      thank you
      • Vetiundefined
        Veti
        try this macro.
        it does 10 checks with average. this will give a better overview.
        have you adjusted the sensitivity of the smart effector? maybe its note sensitive enough.
          PuddingBaer91
          no i use the stock smart effector values. I think you forgot the macro or i am blind? 😄
