Replacement BL touch pins? [High heat printing fails]
Just testing out my new dual extruder setup started printing some test squares with PC, chamber temp was up to 100C, everything was working extremely well, left the garage for 2 minutes and came back to this lol. If your wondering why my bl touch is two sided taped to the extruder body it’s because I designed a mount based of bondtechs cad model instead of measuring the actual extruder body. I printed the mount last night everything came out perfect other than it doesn’t fit was hoping the tape would of held out a little longer, back to the drawing board!
@JPS0284 One place: https://www.ebay.com/itm/Bltouch-Pin-Probe-Replacement-2-Pack-for-BLTouch-And-3D-Touch-/114430343754
I've found that double sided tape is not a reliable mounting method if there is any force apply to what's mounted.
