Duet2 Wifi+Duex5 and SBC
Changed to a short ribbon cable - nothing changed - still "no header" fault message
maybe I should try the duetpi-lite?
@dc42 Sorry for bothering you again. Do you any other ideas?
Sorry for not getting back to you earlier. DuetPi-lite won't make a difference.
Can you please run
DuetControlServer
from command-line with-l debug
to usedebug
log level and post the output? Former output posted here did not contain enough information. -
@wilriker said in Duet2 Wifi+Duex5 and SBC:
Can you please run
DuetControlServer
to usedebug
log level and post the output? Former output posted here did not contain enough information.No problem at all! Don't feel sorry - every help is appreciated!
With what command line exacly? Sorry I am a bit of a noob with RPi and Shell
@taconite What I meant was a command-line shell, i.e. login via SSH or in case you have keyboard and screen connected to the RPi open a shell there (in UI look for Terminal or Shell). Basically the location where you also ran
systemctl status ...
orjournalctl
orjournalctl
.I guess we had a misunderstanding. I understood you that the command line needs to be in SSH or on the pi command itself. I was wondering about the command that I should issue
To phrase it differently I don't know which command I should run.
pi@duet3:~ $ systemctl status duetcontrolserver.service -l debug Unit debug.service could not be found. â duetcontrolserver.service - Duet Control Server Loaded: loaded (/lib/systemd/system/duetcontrolserver.service; enabled; vendo Active: activating (start) since Thu 2021-02-11 20:28:52 CET; 1s ago Main PID: 1596 (DuetControlServ) Tasks: 9 (limit: 2062) CGroup: /system.slice/duetcontrolserver.service ââ1596 /opt/dsf/bin/DuetControlServer Feb 11 20:28:52 duet3 systemd[1]: Starting Duet Control Server... Feb 11 20:28:53 duet3 DuetControlServer[1596]: Duet Control Server v3.2.0 Feb 11 20:28:53 duet3 DuetControlServer[1596]: Written by Christian Hammacher fo Feb 11 20:28:53 duet3 DuetControlServer[1596]: Licensed under the terms of the G lines 1-13/13 (END)...skipping... Unit debug.service could not be found. â duetcontrolserver.service - Duet Control Server Loaded: loaded (/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: enabled) Active: activating (start) since Thu 2021-02-11 20:28:52 CET; 1s ago Main PID: 1596 (DuetControlServ) Tasks: 9 (limit: 2062) CGroup: /system.slice/duetcontrolserver.service ââ1596 /opt/dsf/bin/DuetControlServer Feb 11 20:28:52 duet3 systemd[1]: Starting Duet Control Server... Feb 11 20:28:53 duet3 DuetControlServer[1596]: Duet Control Server v3.2.0 Feb 11 20:28:53 duet3 DuetControlServer[1596]: Written by Christian Hammacher for Duet3D Feb 11 20:28:53 duet3 DuetControlServer[1596]: Licensed under the terms of the GNU Public License Version 3 ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ lines 1-13/13 (END)
pi@duet3:~ $ journalctl -xeu duetcontrolserver.service -l debug Failed to add match 'debug': Das Argument ist ungĂźltig pi@duet3:~ $ journalctl -xeu -l debug duetcontrolserver.service Failed to add match 'debug': Das Argument ist ungĂźltig pi@duet3:~ $ journalctl -l debug duetcontrolserver.service Failed to add match 'debug': Das Argument ist ungĂźltig pi@duet3:~ $ journalctl -l duetcontrolserver.service Failed to add match 'duetcontrolserver.service': Das Argument ist ungĂźltig pi@duet3:~ $
@taconite Sorry, I haven't been clear. So a more step-by-step instruction set.
First make sure to stop the duetcontrolserver service:sudo systemctl stop duetcontrolserver
then run DuetControlServer manually with debug logging enabled:
sudo su - dsf -c "/opt/dsf/bin/DuetControlServer -l debug"
This will output everything directly to the console with logging in debug level.
This is the output
pi@duet3:~ $ sudo systemctl stop duetcontrolserver pi@duet3:~ $ sudo su - dsf -c "/opt/dsf/bin/DuetControlServer -l debug" This account is currently not available. pi@duet3:~ $
sudo /opt/dsf/bin/DuetControlServer -l debug
pi@duet3:~ $ sudo systemctl stop duetcontrolserver pi@duet3:~ $ sudo /opt/dsf/bin/DuetControlServer -l debug Duet Control Server v3.2.0 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized [fatal] Could not connect to Duet (Board is not available (no header)) [debug] System.OperationCanceledException: Board is not available (no header) at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/Due t3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1170 at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean connecting) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataT ransfer.cs:line 162 at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/Duet3D/DuetSo ftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 104 at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/Du etSoftwareFramework/src/DuetControlServer/Program.cs:line 113
again "no header" but I checked the wiring multiple times. Maybe there is something wrong with the small pcb (btw. I already checked for lifted pads and measured the connections)
@taconite I never tested how good it works with the Wifi Module still present. In theory that should work but I only ever tested with a Duet 2 Ethernet with Ethernet module removed. So it's possible that there is an issue with that.
@taconite said in Duet2 Wifi+Duex5 and SBC:
(https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc)
mh okay I thought I read in this topic ((https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc)) that s.o. made it work with the wifi module still present. BTW the LED of the wifi module is not flashing and I installed the duet wifi server fw that came with 3.2 before I moved to the SBC duet FW
@taconite Yes, I think another user got it working with Wifi module still installed. And also for D2SBC build the pin that enables Wifi module is explicitly held low on start-up such that the module does not start but still it being present could lead to signal detrimination.
Anyway, looking again at what you posted above, it says that there is no header. This at least means that the transfer ready pin is working correctly now. You said you have checked the wiring multiple times but please check again that did not mix-up MISO and MOSI - and in doubt try switching them on the RPi GPIO header.
okay seems like a little progress! Wiring was fine but I decided to replace the "little" board.
I get a connection but it seems unstable
and now I get something:[debug] Connection to Linux established! [warn] Restarting transfer because a bad header response was received (0xffffff01) [debug] Updated key limits [warn] Restarting transfer because a bad data response was received (0x0000006c) [warn] Restarting transfer because a bad data response was received (0x00000022) [warn] Bad data CRC32 (expected 0xd6ae08fc, got 0x0400dced) [debug] Requesting update of key boards, seq 0 -> 0 [warn] Restarting transfer because a bad data response was received (0x0000006c) [debug] Updated key boards [debug] Requesting update of key fans, seq 0 -> 0 [debug] Updated key fans [warn] Restarting transfer because a bad header response was received (0xffffff01) [debug] Requesting update of key heat, seq 0 -> 0 [warn] Restarting transfer because a bad header response was received (0xffffff01) [warn] Restarting transfer because a bad header response was received (0x000000fe) [debug] Updated key heat [debug] Requesting update of key inputs, seq 0 -> 0 [warn] Restarting transfer because a bad data response was received (0x00000200) [debug] Connection to Linux established! [warn] Restarting transfer because a bad data response was received (0xffffff6f) [debug] Updated key limits [warn] Restarting transfer because a bad data response was received (0x00000400) [warn] Restarting transfer because a bad header response was received (0xffffff01) [debug] Connection to Linux established! [warn] Restarting transfer because a bad header response was received (0xffffff01) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x10f001fe) [warn] Restarting transfer because a bad header response was received (0xffffff01) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x000000fe) [warn] Restarting transfer because a bad header response was received (0x00000140) [warn] Bad data CRC32 (expected 0x6b118bf2, got 0x9427c9a1) [warn] Restarting transfer because a bad data response was received (0xffffff65) [debug] Connection to Linux established! [warn] Restarting transfer because a bad data response was received (0x00001000) [warn] Bad header CRC32 (expected 0xffffffff, got 0x1523f9ff) [warn] Note: RepRapFirmware didn't receive valid data either (code 0x0004005f) [warn] Restarting transfer because the number of maximum retries has been exceeded [debug] Connection to Linux established! [debug] Updated key limits [warn] Bad data CRC32 (expected 0x59fc6687, got 0x0af43244) [warn] Bad data CRC32 (expected 0x59fc6687, got 0xa820c52f) [warn] Bad data CRC32 (expected 0x59fc6687, got 0xfad539a4) [warn] Restarting transfer because the number of maximum retries has been exceeded [warn] Restarting transfer because a bad data response was received (0x00200020) [debug] Connection to Linux established!
@wilriker Is there something I can do to stabilize the connection?
@taconite You could try reducing SPI frequency in /opt/dsf/conf/config.json
@wilriker it is already lowered to 2MHz
@taconite Try going down (half frequency in each step) to see if you can find a speed at which it still works - if any.
@wilriker Lowered the SPI to 500000 Hz still no stable connection. Could it be that the RapsberryPi power supply is undersized?
The Pi is getting fairly hot.
The transfer ready pin is reading 3,3V (saw that in another thread)
