    DuetWIFI Web Interface will not connect, but did before
    1.6k
    • HenryDaraundefined
      HenryDara @dc42
      @dc42 Sorry, I meant M588 Forget WiFi host network which reported back success.
        HenryDara @elmoret
        @elmoret You are right, my bad. It was the PanelDue that had China on the board. Comfort level rising. 🙂
          1. What error message does your browser give when you enter the IP address of the Duet in the address bar?
          2. Please confirm that after you check you can ping the Duet, if you power down the Duet you can no longer ping it.
          3. Is the blue LED on the WiFi module lit?
          HenryDaraundefined 2 Replies Last reply Reply Quote 0
            HenryDara @dc42
            @dc42 Im getting unable to connect messages from the browser. I tried Chrome, Firefox, and IE. I can open other pages on these browsers. I did already confirm by powering off and then NOT pinging, then powering on and being able to ping again. The blue light is on solid, and when I run a M552 S1 I get confirmation of connection to the same access point as the PC is currently on, as well as the IP address of the web server on the Duet.
              HenryDara @dc42
              @dc42 I think for now I just need a workaround for when the interface doesnt work. I was using it to edit the machine configuration, which modified the Config.g file seamlessly. Now I think I have to make edits manually to that file on my PC, and saving to the file on the SD card. Kinda scary, and cumbersome, but ive already wasted a day on this, and I dont seem to be getting anywhere.
                Are you running compatible versions of the main firmware and DuetWiFiServer? All recent main firmware versions work with DuetWiFiServer 1.20. You can run M122 to check the firmware versions.
                  HenryDara @dc42
                  @dc42 It returned...
                  === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC5(RTOS) running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DGM-9T6BU-FG3SN-6JTDG-3S06S-KBYVF......
                    HenryDara @dc42
                    @dc42 So it started working on all browsers, and connects instantly again. The only thing I did was re-write a new config.g file to the SD card with minor machine modifications (namely motor direction) Another difference was that I changed the machine name in the new Config.g file. If it happens again, I will try changing only the machine name to see if it has an affect.
                    piundefined 1 Reply Last reply Reply Quote 0
                    • piundefined
                      pi @HenryDara
                      @HenryDara
                      Cannot get interface to load ....board responding in yat....but no access to interface
                        Phaedrux Moderator @pi
                        @pi Please start a new thread.
                        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help?_=1613530139742
