    DuetWifi not booting anymore
    Using Duet Controllers
    364
    • Mirageundefined
      Mirage
      I searched the forums for similar issues but could not find anything.
      It started to loose wifi connection every 10 seconds, then nothing....
      I have checked all wires, made sure no dust was on the board and on the Duex5.
      Only a solid red and solid blue leds are on when plugged in, no flashing. The Duex5 shows no led at all.
      I have tried un powering the Duet and connecting usb cable. YAT sees nothing either.
      All fuses seem to be good.
      Is there anything else I can try? Board has been on this machine for 2 years.
      Thank you for your help.
        Does anything show in the device manager when it's connected via USB?
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        You could perhaps post some photos of the board to see if there is any damaged component.
        • Mirageundefined
          Mirage
          Device manager does not see it... I'll take them out tomorrow for close inspection of the boards.
          • Vetiundefined
            Veti @Mirage
            @Mirage said in DuetWifi not booting anymore:
            you most likely have to test different usb cables. some users had to try up to 18 different ones until they found one that was working
            Mirageundefined 1 Reply Last reply Reply Quote 0
            • Mirageundefined
              Mirage @Veti
              @Veti I am using the one provided with the Duet in the first place. are you saying it might not work?
              • Vetiundefined
                Veti
                just to rule it out.
                usb cables can break too.
                • Mirageundefined
                  Mirage
                  Ok small update: (A positive one)
                  I have unplugged all components from the board including Duex5 except power source. The board powered and the esp connected to wifi! wooohooo! I then reconnected all components one after another (Duet powered off during each plugging of course) and I was able to reconnect all components until full functionality again.
                  I am suspecting some cabling malfunction at this point, that would be the only logical reason I see. The printer works again.
                  Will keep you posted of further development.
                    That's a relief. 🙂
