Actual movements during failed simulation
I've changed it to:
if (hSquared < -0.001 * fsquare(rParam)) // allow the radius to be up to sqrt(0.001) ~= 3.2% too short
In the 3.2.2 code, hDivD will be a NaN if the radius is too short, so it's not surprising that it misbehaves.
Actually that's still wrong. (r + xr)^2 ~= r^2(1 + 2x) if x is small, so I will use this instead:
if (hSquared < -0.02 * fsquare(rParam)) // allow the radius to be up to 1% too short
@dc42 Looks good!
Now, back to the other problem; that an error during simulation may cause physical movement. In 3.2.2 I can't cause the "too small radius"-error any more, but looking at the source code, I realized that I can provoke an error by setting identical start end end points for G2 or G3 with an R parameter.
This code:
G28 ; Home all axes G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion G1 Z20.000 F7800.000 G1 F1800.000 G1 X115 Y115 G1 F200.000 G3 X115 Y115 R5 M0 ; Stop print
will cause the message "Error: SetPositions called when DDA ring not empty" as well as "Error: G2/G3: radius is too small to reach endpoint" when run in simulation mode. It also causes a physical movement (some 10mm in the negative X direction).
Hope you can replicate this behaviour.
Thanks, it sounds to me that when the error occurs, the simulation is exiting before the DDA ring has been emptied, which ties in the message.
@dc42 I have also noted another symptom, probably due to the same problem.
When printing (not simulating) the code above, the same unexpected movement as in simulation takes place when the error occurs and printing is aborted. The axes remain in homed-status but the coordinates have not been updated with that last movement.
@ÖrjanE said in Actual movements during failed simulation:
Do you get the "SetPositions called when DDA ring not empty" message again?
@dc42 said in Actual movements during failed simulation:
No.
And now I can't replicate that second behaviour (extra movement when not simulation). Perhaps it is state-dependent and du to some leftover state from the failed simulation. -
@dc42 Forget about the "second symptom" (problem during actual print). I have restarted the duet and fail to repeat the problem. It may be that I misinterpreted what happened when I tested this.
Regarding the move when simulating; it makes sense that it is the last move/moves that remain queued when simulation mode is turned off prematurely. The move does not seem to be random, but consistent with the last move that should have been done (in simulation) before the error occurred.
Thanks for your example. I have reproduced the issue, and fixed it in the 3.3 branch source code. Moves already prepared and put into the movement queue are now completed when a job is aborted.
@dc42 Great!
Thanks for your work in maintaining this software. -
@dc42 Great!
Thanks for your work in maintaining this software.Thanks for your clear description of the issue and GCode file to reproduce it.
