    how do i do dual endstops for X and Y axis on my cnc
    CNC
    1.7k
    • Svenvdbundefined
      Svenvdb @Veti
      @Veti i am using 3.1.1 (2020-05-19b2).
      Thank you for the link. this is definitely helpful.
        Phaedrux Moderator @Svenvdb
        @Svenvdb said in how do i do dual endstops for X and Y axis on my cnc:
        "ystop=e1stop"
        That should be a + not an =
        • Vetiundefined
          Veti
          also you might want to switch to cnc mode
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_Select_CNC_Device_Mode
          • Svenvdbundefined
            Svenvdb
            I fixed it !!. my endstops were on NC, I put a ! in front of it to make it a NO and now it works
            I used the normal code for the home command and the M574 in my config.
            I found this other forum post from a guy with a similar problem. https://forum.duet3d.com/topic/20318/mpcnc-duet-3-sbc-dual-endstop-for-x-and-y-axes?_=1609092505581
            And I read from this link https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
            that @Veti provided that in 3.0 and above you don't have to separate the axis.
            Thanks, @Phaedrux for noticing my error in the code, that would probably have taken me a day to figure out.
            • shanteundefined
              shante
              Hi
              Can someone help mi with problem i have?
              there is something wrong with my homing Y.
              I do homig, steppers are moving, they both hit endstops, move back a bit, but then, only one on my steppers is going to hit endstop (Zstepper is triggers zstop).
              Ystepper is not hitting the endstop. LED on mb is not lid.
              Board: Duet 2 WiFi (2WiFi)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
              Duet WiFi Server Version: 1.25
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Feb 20 2021 18:30:24 GMT+0100 (Central European Standard Time)
              G90                                     ; send absolute coordinates...
              M83                                     ; ...but relative extruder moves
              M550 P"Primo"                       ; set printer name
              M552 S1                                 ; enable network
              M586 P0 S1                              ; enable HTTP
              M586 P1 S0                              ; disable FTP
              M586 P2 S0                              ; disable Telnet
              M569 P0 S0                              ; physical drive 0  X
              M569 P1 S1                              ; physical drive 1  Y
              M569 P2 S0                              ; physical drive 2  Z
              M569 P3 S0								; physical drive 3  E0
              M569 P4 S1								; physical drive 4  E1
              M569 P5 S1								; physical drive 5 goes forwards
              M584 X0:3 Y1:2 Z4 P3						; set drive mapping
              M350 X16 Y16 Z16 I1                 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00				; set steps per mm
              M566 X900.00 Y900.00 Z60.00				; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z280.00			; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00				; set accelerations (mm/s^2)
              M906 X900 Y900 Z900 I30            ; set motor currents (mA) and motor idle factor in per cent
              M84 S60                                 ; Set idle timeout
              M208 X0 Y0 Z0 S1                        ; set axis minima
              M208 X480 Y350 Z200 S0                  ; set axis maxima
              M574 X1 S1 P"xstop+e0stop"              ; configure active-high endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop+zstop"
              M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:215 Y15:195 S20                ; define mesh grid
              M140 H-1                                ; disable heated bed (overrides default heater mapping)
              M575 P1 S1 B57600                       ; enable support for PanelDue
              M501                                    ; load saved parameters from non-volatile memory
              homex.g
              ; homex.g
              ; called to home the X axis
              G91               ; relative positioning
              G1 H2 Z5 F6000    ; lift Z relative to current position
              G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 H2 X5 F6000    ; go back a few mm
              G1 H1 X-235 F360  ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-5 F6000   ; lower Z again
              G90               ; absolute positioning
              homey.g
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 H2 Y5 F6000    ; go back a few mm
              G1 H1 Y-235 F360  ; move slowly to Y axis endstop once more (second pass)
              thank you for any help
                Phaedrux Moderator @shante
                @shante said in how do i do dual endstops for X and Y axis on my cnc:
                Remove the H2 on those moves in your homing files. It's ok on the Z axis.
                You need to increase the distance of the first homing moves. They must be longer than your axis length.
                Why do you have P3?
                shanteundefined 1 Reply Last reply Reply Quote 0
                • shanteundefined
                  shante @Phaedrux
                  @Phaedrux said in how do i do dual endstops for X and Y axis on my cnc:
                  Ok, removed H2 and increased the distance in both home.g files. Thanks.
                  But nothing changed, X homing OK, Y does not.
                  Why do you have P3?
                  Isn't that P3 to show those 3 axes? To home them and move them?
                    Why do you have P3?
                    You can leave the P3 off entirely. It's mainly used for when you have multiple temporary axis like UVW. You're not doing anything like that since with RRF3 you don't need to split up the axis for homing anymore.
                    What exactly happens with the Y axis when you do homey?
                    Does it move in the correct direction towards the endstop?
                    Does it stop before it hits the endstop?
                    If you click the endstop by hand while it's moving does it stop the axis?
                    • shanteundefined
                      shante @Phaedrux
                      P3 removed.
                      when i try to home Y. Steppers are moving, direction is ok. They both hit endstops, if misaligned stepper that did not hit the unstop is mooving until he does hit endstop. Then they move back together, and together in correct direction moving lowly towards endstops. However only one endstop is triggered and then steppers stops, homig ends as homed.
                      Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        @shante Can you send M98 P"config.g" in the console and report the response?
                        M574 Y1 S1 P"ystop+zstop" Do both endstop LEDs work correctly when you manually click the switch?
                        • shanteundefined
                          shante @Phaedrux
                          @Phaedrux they do, if tested manualy and in first homing pas. After second pas, that slow approach, only one is triggered, Ystop, and Zstop is not. Stepper do not come close to trigger it, its like 0.5mm away.
                            @shante Can you send M98 P"config.g" in the console and report the response? Also the results of M122 please.
                            • shanteundefined
                              shante @Phaedrux
                              @Phaedrux
                              M98 P"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Warning: Macro file config-override.g not found
                              m122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                              Board ID: 08DGM-9T6BU-FG3S4-6J1FL-3SN6S-9SNRH
                              Used output buffers: 4 of 24 (20 max)
                              Static ram: 23460
                              Dynamic ram: 72128 of which 52 recycled
                              Never used RAM 16440, free system stack 119 words
                              Tasks: NETWORK(ready,187) HEAT(blocked,366) MAIN(running,543) IDLE(ready,20)
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:00:50 ago, cause: software
                              Last software reset at 2021-02-25 21:13, reason: User, GCodes spinning, available RAM 16408, slot 2
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 38.0, current 38.4, max 38.6
                              Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: position 0, standstill, SG min/max 0/109
                              Driver 1: position 0, standstill, SG min/max not available
                              Driver 2: position 0, standstill, SG min/max not available
                              Driver 3: position 0, standstill, SG min/max 0/69
                              Driver 4: position 0, standstill, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Date/time: 2021-02-25 21:14:03
                              Cache data hit count 60171643
                              Slowest loop: 8.73ms; fastest: 0.21ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 3.2ms, write time 1.5ms, max retries 0
                              DMs created 83, maxWait 34339ms, bed compensation in use: none, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 10, completed moves 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                              === AuxDDARing ===
                              Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 201.46ms; fastest: 0.11ms
                              HTTP sessions: 2 of 8
                              - WiFi -
                              Network state is active
                              Failed messages: pending 0, notready 0, noresp 1
                              WiFi firmware version 1.25
                              WiFi MAC address cc:50:e3:4a:ad:68
                              WiFi Vcc 3.31, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 25680
                              WiFi IP address 192.168.1.81
                              WiFi signal strength -73dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              M122 sent after homig X and Y
                                So they are aligning properly on the first pass until both endstops are triggered, but not on the second pass?
                                Can you make a video showing what's happening?
                                • shanteundefined
                                  shante @Phaedrux
                                  @Phaedrux
                                  Yes, exactly.
                                  No video yet, as im rewiring endstop and stepper. Tried replaced endstop, no joy.
                                  New wiring will be with yet another endstop, we will see.
                                  Do i need to split steppers if adding offset to one of steppers will be needed?
                                  If so can you write me example code how to do that?
                                    @shante Some videos/photos of the setup would help to understand what's going on.
                                    • shanteundefined
                                      shante
                                      After rewiring(new wires for stepper and endstop) and new endstop, issue is gone...
                                      Thank you @Phaedrux for your help and patience with me.
