Duet 2 WiFi: 3.1.1, 3.2.2 upgrades fail, 3.0.0 works ok
EDIT: I am leaving this here in case somebody else looks for it. I shut down and restarted the Duet after a while and the upgrade to 3.2.2 seems to have worked, the only problem being that I didn't get a confirmation of the upgrade; the screen just kept showing the "Please wait..." message.
Yesterday I upgraded my Duet 2 WiFi from 2.x to 3.0.0 firmware by uploading through the web UI, which worked fine. I then wanted to proceed to 3.1.1, but the installation through the web UI kept hanging at the "Please wait while updates are being installed" message.
After a while (> 15 minutes) I shut down the Duet. I was able to get back to a usable state with firmware 3.0.0, including working WiFi, by following fallback procedure #1 from the documentation.
Today I decided to give it another try with 3.2.2. I again uploaded through the web UI, and it hangs again at the "Please wait while..." message.
What could I do to debug this? I could roll back to 3.0.0, but at some point I'd like to keep up with firmware updates, obviously.
PS. The Duet 2 Wifi is wired up inside the printer with 6 steppers and a Duex 2 connected. I am doing the upgrade on USB power only, no Vin.
@lapjoint said in Duet 2 WiFi: 3.1.1, 3.2.2 upgrades fail, 3.0.0 works ok:
Why no VIN?
Were you uploading bin files or the complete zip file for the release?
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
That will get your firmware and DWC up to date.For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/Start -
For Duet2 Wifi it happens that the Wifi Server FW gets corrupted and needs to be installed manually (e.g. via Pronterface). This happend to me multiple times from 3.0.0 onwards.
@taconite said in Duet 2 WiFi: 3.1.1, 3.2.2 upgrades fail, 3.0.0 works ok:
Manually sending M997 S1 to re-flash the wifi module usually does it.
