Config & GCode review
Hello!
So some quick backstory, I just got into 3D Printing roughly 2 weeks ago. I picked up an Ender 5 Plus. Everything was printing smooth. I originally looked into getting the silent board from Creality as the printer is in the basement near the Wifes Office and she can hear the steppers as well as the glorious Ender 5 Plus Z squeal. A friend of mine is big into 3D printing and gifted me a spare Duet 2 Wifi as it would silence the drivers and offer 32 bit with potential expandability if I ever choose. Now, I completely understood from the start that this was not going to be a drop in replacement. But, I am also struggling with getting the settings ironed out.
Any chance someone can look over the configs, g-code, etc. and see if anything stands out? Or offer any form of direction. Again, I am extremely new to all of this and am learning as I go so please feel free to be overly critical. Thank You!!
Listed below is what I am currently running:
Equipment:
- Stock Ender 5 Plus
- BL-Touch (heater3, pin8)
- PanelDue 7i
Firmwares:
- RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
Slicer:
- Cura 4.8.0 (primary)
- Have S3D if needed
Filament:
- eSun PLA+ (1.75mm,
- 210c/60c
Noticeable Problems:
- Extrusion problems
- Zits and Blobs
- Inconsistent Layers both first and consecutive
- Occasional slipping of extruder
- Losing my mind
CONFIG:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Feb 27 2021 17:22:07 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"EnderV+" ; set printer name ; Network M551 P"" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 E100 ; set steps per mm M566 X900 Y900 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M204 P600 T1500 ; set print and travel accellerations M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z***-1*** S1 ; set axis minima M208 X350 Y350 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F60 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-30 Y-6 Z3.034 ; set Z probe trigger value, offset and trigger height M557 X0:250 Y60:325 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 A101.7 C607.1 D2.6 S1.00 V24.3 B0 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 A268.5 C102.1 D3.1 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S260 ; 280 deg max on hot end ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings M591 D0 P2 C3 S1 ; Filament Run out sensor G29 S1 ; Load mesh bed ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss Start GCODE:
G21 ; Set all units to millimeters M107 ; Turn off the part cooling fan G28 ; Move toolhead to origin (or home X, Y, Z) G29 S1 ; Use last saved mesh data G92 E0.0 ; Reset the extruder position to 0mm G90 ; Absolute positioning G1 X10 Y270 F6000 ; Move to rear left corner M400 ; clear movement buffer M116 ; Wait for temps G1 Z0.3 F100 ; Move Z to prime height G91 ; Relative positioning M83 ; Relative extrusion G1 Y220 E10 F300 ; Prime nozzle G10 ; Retract G1 Y-1 X1 F10000 ; Wipe nozzle G90 ; Set to absolute positioning as opposed to relative M83 ; Set the extruder to relative positioning M122 During Last Print:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7JTD4-3SJ6P-1YU0G Used output buffers: 3 of 24 (22 max) === RTOS === Static ram: 23460 Dynamic ram: 73428 of which 76 recycled Never used RAM 15116, free system stack 115 words Tasks: NETWORK(ready,165) HEAT(blocked,306) MAIN(running,437) IDLE(ready,20) Owned mutexes: === Platform === Last reset 00:16:07 ago, cause: power up Last software reset at 2021-03-01 11:47, reason: User, GCodes spinning, available RAM 15116, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 40.9, current 42.2, max 42.8 Supply voltage: min 23.4, current 23.9, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 19341, ok, SG min/max 0/249 Driver 1: position 19135, ok, SG min/max 0/486 Driver 2: position 213, standstill, SG min/max 0/170 Driver 3: position 0, ok, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-03-02 00:27:21 Cache data hit count 1160178226 Slowest loop: 31.39ms; fastest: 0.18ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.7ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 200740ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 1018, completed moves 1008, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 2 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 2 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. Please let me know if there is anything else that would make solving this puzzle any easier!
Thank you for any help that you can provide.SCIVANIC
There's a series of guides on converting the Ender 3 over. In the end it's quite similar to the ender 5. It may help clarify some things.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
Part 5, for calibration may be what you're after right now.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87
The second link is for a more recent guide using RRF3, which is still in progress.
