    How to PID tune dual heater cartridges wired in parallel?
    Using Duet Controllers
    1.2k
    • Duetfan223undefined
      Duetfan223
      I am running a 0.8.5 board with firmware 1.21.2beta1 and 24v power supply
      I'm having some difficulty wrapping my head around this PID tuning stuff with dual 50 watt cartridge heaters
      I'm using two 24v 50 watt heater cartridges in a SuperVolcano heater block with glass mat & silicone sock, wired in parallel. The reason being the 80 watt 24v heaters are still sold out, so I wanted to see if I could improvise.
      When I try to PID tune this setup using M303 H2 s220 (Yes it's wired to Extruder 2 heater) I get:
      -Peak temperature 250
      -Warning: Auto tune of heater 2 failed due to bad curve fit.
      It also gives me the A, C, D values which I used to update the M307 entry for heater H2 inside config.g...
      M307 H2 A3249.8 C542.5 D6.8
      and have also added to config-override.g., just in case.
      Even with the new A, C, D, values in config.g, I set the hotend to 220 and it overshoots by 30 degrees again, and gives this error:
      Error: Heater 1 fault: temperature excursion exceeded 15.0°C
      I know I can change these values in M570 for a 30+ degree overshoot... but I would rather make adjustments that would lead to less of an overshoot.
      Any ideas?
      Do I have to double the A value from the failed PID tuning because I'm using 2x heater cartridges?
        Are they wired in parallel or are you configuring them as Heater1 and Heater2?
        If they are wired in parallel to the same heater terminal you should be able to tune it as a single heater. The firmware won't know the difference.
        @Duetfan223 said in How to PID tune dual heater cartridges wired in parallel?:
        Consider updating to the most recent firmware for your hardware. 1.26.1 I believe.
        https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 < 1.26.1 included with the 2.05.1 release.
          Duetfan223
          Thanks for the quick response
          Yes, all 4 leads attached to only Heater 2's + and - terminals. I am sure it's wired right.
          They do seem to function as intended, they just overshoot the target temp by too much and my edits to the values in M307 don't seem to have any effect.
          I don't think this is a firmware issue so much as likely user error but I will definitely consider updating the firmware.
          For now, I will adjust M570 for 35 degree excursion so I can at least start running some test prints with this setup.
          • hackinistratorundefined
            hackinistrator
            maybe try M303 H2 P0.5 S220
            Duetfan223undefined 1 Reply Last reply Reply Quote 1
              Duetfan223 @hackinistrator
              @hackinistrator said in How to PID tune dual heater cartridges wired in parallel?:
              That seems to help, this time the overshoot was only 13.3 degrees.
              Warning: Auto tune of heater 2 failed due to bad curve fit (G=1505.2, tc=605.4, td=7.5)
              11:14:53 AMAuto tune phase 3, peak temperature was 233.3
              So I have adjusted config.g to:
              M307 H2 A1505.2 C605.4 D7.5 S0.5
              If I run M303 H2 S220 command without a P parameter, does it default to 1.0 or does it use the values saved in M307 H2?
              hackinistratorundefined 1 Reply Last reply Reply Quote 0
                hackinistrator @Duetfan223
                @Duetfan223 your heater has simply too much power
                try m303 h2 p0.3 s220
                i think default is 1
                  @hackinistrator ok, I tried with M303 H2 P0.3 S220. Took another minute to heat up but it was even more accurate this time, and did not fail.
                  M307 H2
                  Heater 2 model: gain 863.9, time constant 606.6, dead time 7.7, max PWM 0.30, calibration voltage 0.0, mode PID, inverted no, frequency default
                  Computed PID parameters for setpoint change: P16.3, I0.239, D87.7
                  Computed PID parameters for load change: P16.3
                  Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 888C.
                  Auto tune heater 2 completed in 748 sec
                  Use M307 H2 to see the result, or M500 to save the result in config-override.g
                  Auto tune phase 3, peak temperature was 228.4
                  Auto tune phase 2, heater off
                  Auto tune phase 1, heater on
                  M303 H2 P0.3 S220
                  Auto tuning heater 2 using target temperature 220.0°C and PWM 0.30 - do not leave printer unattended
                  So, I will set heater 2 in config.g to read:
                  M307 H2 A863.9 C606.6 D7.7 S0.3
                  I should be able to print now.
                  Thank you!
                  hackinistratorundefined 1 Reply Last reply Reply Quote 1
                    @Duetfan223 i'm glad that it works , but honestly i don't think that its the right solution .You don't really need that second heater .
                    Duetfan223undefined 1 Reply Last reply Reply Quote 0
                      The reason for the "bad curve fit" message is that the measured gain is so high, because of the very high heater power. The maximum gain (M307 'A' parameter) allowed is the higher of 1500 and (500 + M143 limit).
                      So your original tuning results were well above the limit:
                      Your second was within a whisker of being OK:
                      Had you reduced A to 1500, you would have avoided the "bad curve fit" message.
                        @dc42 @hackinistrator said in How to PID tune dual heater cartridges wired in parallel?:
                        I have been running a 24v 50 watt cartridge heater on the regular E3D Volcano and can't seem to heat the plastic as fast as I'd like. It's likely a pitfall of using 3mm filament. The SuperVolcano seemed like the logical next step but the standard 24v 80 watt heaters are out of stock. They're nearly 48mm long and I assumed part of the "magic" was having heating elements the whole length of the heater block.
                        So that's why I decided to go with two 50 watt heaters for now, and I'll buy the 24v 80 watt whenever that becomes available. I had figured I'd set these 50 watt cartridges to S0.8 PWM for "80" watts but I guess it doesn't really work that way?
                        I still have a lot of 3mm filament I'd like to use up before switching over to 1.75mm. I'd imagine the smaller filament will solve a lot of the problems I've been having with the filament being unevenly heated at higher print speeds.
                        SuperVolcano block & cartridge for reference
                        2.85mm "bargain basement" PLA, 1650 mm/min at 230 temperature. Notice the "pulsed" affect the filament has on the far side of this print? Is that the heater switching on/off for PID? I updated the firmware and I'll run Auto Tune a few more times. Takes FOREVER to cool down with that sock on there... but that's a good thing, right? 🤠
                        Grody_PLA_Speedrun.mp4
                          Is that a direct drive extruder? If so a geared extruder would help get some torque and smoothness to improve the flow.
                            Duetfan223 @Phaedrux
                            @Phaedrux Yes it's direct, I'll look into gear extruders
