Delta Printer - Start of Print
1.4k
    number40fan
    Is there a way to tell the printer to come down on the outside edge of the bed, run a priming layer towards the middle and then start printing? Getting tired of having to baby sit it to pull the stringy mess off of the nozzle before it starts. Which will end up smack dab in the middle of the print if I don't. I do use a big brim, but it doesn't help.
      Yonkiman
      An auto-wipe function like that is a good idea. If you can write the gcode to do what you want, you can add that gcode to the starting script of your slicer or as a .g macro file for the firmware.
      If you can't come up with the gcode to do what you want, then it's probably not possible. For example: does your delta design allow you to move the head over the edge of the build plate? (I don't think mine will, but I'm gonna check.)
        Yonkiman
        Here's a page talking about what you want to do: http://reprap.org/wiki/RepRap_Firmware_macros#Head_cleaning
        Earlier on that page they mention a start.g file (not in the Duet sys directory by default, but you can add it):
        [c];/sys/start.g Executed at print start (add 'M98 P/sys/start.g' in your slicer start code)[/c]
          @Yonkiman:
          You can use M564 S0 to temporarily allow movement outside the normal area, and M564 S1 to resume applying the limits.
            number40fan
            I have my swipe setup in the O:/sys/start.g, but didn't work. Is there something in the gcode that is keeping it from working?
            G90
            M82
            M106 S0
            M140 S70
            M190 S70
            M104 S210 T0
            M109 S210 T0
            M104 T0
            G28 ; home all axes
            M98 O:/sys/start.g
            G92 E0
            Start of the print gcode.
              DjDemonD
              Why is it o:?
              I normally call a macro using
              M98 Pstart.g
              www.precisionpiezo.co.uk
                number40fan
                Everything else is O:, so I figure that is what it needed. I'll switch and try again.
                O:/sys/config.g etc….
                When I created the start folder it put it as O: as well.
                  number40fan
                  Changing it O: to P: in the beginning of the print gcode didn't help. It must be how I have my start.g file in the directory.
                    number40fan
                    Going to drop the colon after the P and give it a try.
                      number40fan
                      Yep, that worked. Thanks.
                      4 out of 10
