New experimental firmware 1.19beta10
Firmware installation
12
63
8.0k
    Yonkiman
    Just in case they got lost in all the back-and forth, here are the two issues I'm still seeing with 1.19beta10+2 & DWC 1.17+2:
    1. M666 in config.g doesn't execute/"stick" - after a reboot M666 is always reset to [c]Endstop adjustments X0.00 Y0.00 Z0.00, tilt X0.00% Y0.00%[/c]. I don't have a config-override.g file or an M501 command in my config.g. M665 in config.g works as expected.
    2. My prints are now ending with a "Can't delete file 0:/sys/resurrect.g" error, and the final lines in my gcode are not executed:
    G1 X0.053 Y9.146 F540
    G1 E-8.0000 F6000
    ; layer end
    T0 ; Select Extruder 0 if not already selected
    G90 ; Switch to absolute mode
    G1 X0 Y0 Z250 E-10 F6000 ; Retract filament and raise printhead
    M104 S0 ; Turn off heater
    M84 S10 ; turn off motors after 10 seconds
    ```I'm guessing it might have to do with the [c]T0[/c], because the print completes, but the printhead doesn't move up and the heater doesn't turn off. I'll try a print without the [c]T0[/c] tomorrow and see if the problem goes away.
      lars
      David, any chance you could add the probe point data in the output together with the adjustment for the leveling?
        @lars:
        21:45:43 M98 P0:/macros/4 - Leveling Check Probe
        Bed probe heights: -0.275 -0.663 0.068, mean -0.290, deviation from mean 0.299
        21:45:15 G32
        Error: some computed corrections exceed configured limit of 0.50mm: 0.260 0.969 -0.344
        21:44:34 M98 P0:/macros/4 - Leveling Check Probe
        Bed probe heights: -0.274 -0.659 0.049, mean -0.295, deviation from mean 0.289
        21:43:43 G32
        Leadscrew adjustments made: 0.136 0.486 -0.174, points used 3, deviation before 0.210 after 0.000
        21:42:42 M98 P0:/macros/4 - Leveling Check Probe
        Bed probe heights: -0.148 -0.339 0.041, mean -0.149, deviation from mean 0.155
        21:41:57 G32
        Leadscrew adjustments made: 0.043 0.230 -0.082, points used 3, deviation before 0.094 after 0.000
        21:41:19 M98 P0:/macros/4 - Leveling Check Probe
        Bed probe heights: -0.010 -0.112 0.054, mean -0.023, deviation from mean 0.069
        Firmware Name: RepRapFirmware for Duet WiFi
        Firmware Electronics: Duet WiFi 1.0 + DueX5
        Firmware Version: 1.19beta10+3 (2017-07-21)
        WiFi Server Version: 1.19beta9
        Web Interface Version: 1.17+2
        This is strange. I set up my bench system, configured as a CoreXY with your leadscrew positions and motor assignments:
        M584 Y5 X7 U8 V6 E3:4 Z0:1:2 ; Set up steppers for x, y, u, v, z and e, use P4 once it works to hide V
        M671 X250:560:-60 Y560:-10:-10 S0.5 ; Set up lead screw positions for bed leveling
        I created a bed.g file like yours, except that I put the initial probe height errors that you reported in it:
        G30 P0 X250 Y420 Z-0.010
        G30 P1 X420 Y80 Z-0.112
        G30 P2 X80 Y80 Z0.054 S3
        I set my Z steps/mm to 3200 so that 1mm movement is 1 revolution of the motor. I have flags on the motor shafts so that I can see the movement. I loaded firmware 1.19beta10+3. I sent G92 X0 Y0 Z10 as I don't have any means of homing this setup.
        When I run G31, I get this:
        Leadscrew adjustments made: 0.002 0.185 -0.117, points used 3, deviation before 0.072 after 0.000
        I can see the X motor moving clockwise very slightly, the Y motor moving clockwise a little less than 1/5 of a turn, and the Z motor moving anticlockwise a little less than 1/8 of a turn. I checked that when I command +Z movement, the rotation is clockwise. So it all looks correct.
        Please can you check a few things:
        1. Is the maximum Z speed in your M201 command in config.g achievable?
        2. Are you certain that you have the motors connected to the driver outputs in the order listed? Bear in mind that the order of driver outputs along the edge of the Duet is 2 1 0 3 4 (i.e. Z Y X E0 E1) not 0 1 2 3 4.
        3. Can you see the leadscrews moving by about the correct amount, in the correct direction?
          @Yonkiman:
          G1 E-8.0000 F6000
          ; layer end
          Thanks for your report.
          I can't reproduce the M666 problem, it works on my delta. Please share your config.g file. If you run M98 Pconfig.g subsequently, does it pick up the correct M666 settings?
          I don't know why the last few lines of gcode are not being executed. Is tool 0 active at the end, or is some other tool active? Do you have anything in the tool change files for tool 0?
          The "Can't delete" message will be fixed in the next beta.
            Yonkiman
            1. My M666 command wasn't "taking" because I put it before my original block of mechanical configuration commands, one of which was [c]M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them[/c]. So the first M666 was just getting clobbered (PEBCAK).
            2. I was also wrong about the issue at the end of a print. I'd switched printing profiles to one that (I didn't notice this at the time) didn't have an ending script with a Z raise. Then when the print finished without moving the head off the print, I looked at the gcode console and saw the "Can't delete" error, so I assumed they were related, and then I managed to look at the wrong gcode when I was "confirming".
            Dave, one of these days I swear I'm going to stop wasting your time and actually be helpful… I really appreciate your patience.
              No problem!
                lars
                @dc42:
                1. I halved all the vales and retested with same result:
                M566 Z12
                M203 Z200
                M201 Z125
                2. Yes, rechecked again.
                3. All lead screws move in the wrong direction. I do estimate they turn about what it says but in the wrong direction…
                Edit: If you look at the result from my last post it shows the test probing confirms that they all turn the wrong way on my printer...
                M569 P0 S0 ; Drive 0 Z
                M569 P1 S0 ; Drive 1 Z
                M569 P2 S0 ; Drive 2 Z
                M569 P3 S0 ; Drive 3 E0
                M569 P4 S0 ; Drive 4 E1
                M569 P5 S1 ; Drive 5 Y
                M569 P6 S1 ; Drive 6 V
                M569 P7 S1 ; Drive 7 X
                M569 P8 S1 ; Drive 8 U
                M569 P9 S1 ; Drive 9
                ```Edit 2: In your test was M569 PX S0 or S1?
                  Hi Lars, I think you are right, I had the corrections in the wrong direction. Please try DuetWiFiFirmware 1.19beta10+4, available at https://dl.dropboxusercontent.com/u/19369680/DuetWiFiFirmware.bin.
                    lars
                    @dc42:
                    [[language]]
                    07:53:56 M98 P0:/macros/4 - Leveling Check Probe
                    Bed probe heights: -0.001 0.008 -0.002, mean 0.002, deviation from mean 0.005
                    07:53:12 M98 P0:/macros/4 - Leveling Check Probe
                    Bed probe heights: -0.003 0.005 -0.001, mean 0.000, deviation from mean 0.003
                    07:52:38 G32
                    Leadscrew adjustments made: -0.023 0.025 0.002, points used 3, deviation before 0.012 after 0.000
                    07:51:53 M98 P0:/macros/4 - Leveling Check Probe
                    Bed probe heights: -0.021 -0.006 0.003, mean -0.008, deviation from mean 0.010
                    07:51:18 G32
                    Leadscrew adjustments made: 0.325 0.014 -0.374, points used 3, deviation before 0.167 after 0.000
                    ```I do believe its working!
                    I guess it might offset the center point from Z=0 if it is not on the plane made up of the 3 probings? I included it as a fourth point to minimize this but I guess one could include a rehome of Z in the bed.g…?
                      @lars:
                      @dc42:
                      [[language]]
                      07:52:38 G32
                      07:51:18 G32
                      I'm glad this is working at last. Thanks for your patience!
                      The algorithm minimises the sum of the squares of the height errors at the probe points. So if the bed centre is not on the plane - either because the bed is not flat or (more usually) because the gantry flexes enough to allow the head to droop a little around the centre, then it will upset Z=0 at the centre. To correct it, you can add a single G30 command in bed.g to probe the bed centre after doing leadscrew compensation. Including probe points near the centre of the bed as you have done will also help.
                        Scottbg1
                        I want to give the bed leveling feature a try.
                        I remember reading about this in another thread, on how to assign the second Z motor, but I can't find it in search.
                        If memory serves…
                        I connect the second Z motor to the E1 port of the board. I assign it in config.g with P4. And then the 2nd Z motor would be identified as "U". Is this correct?
                        Also, would I need to replace the jumper back into the Z2 port on the board when it's empty?
                        If this is a redundant question I apologize. If so, if someone recalls that conversation could they please post a link?
                        Thanks
                          See https://duet3d.com/wiki/Bed_levelling_using_multiple_independent_Z_motors. You will need firmware 1.19beta10+4. If your board is a Duet WiFi you can get it via the link I posted 4 replies up.
                          In summary, you don't configure the extra Z drive as U, and you do need to replace the jumpers in the second Z motor socket.
                            strips
                            Nice! Will give the leveling a try as soon as I have time.
                            And I have that extra U axis working so well 😉
                            David, I must say I'm impressed by your development pace and how quickly you respond to our issues!
                            Ender 5 Plus, E3D Bigbox Dual
                              @strips:
                              Thanks!
                              The difference between the Series 2 Duets and other open-source controller boards is that the profits we make on the Duets fund development, support and a generous warranty replacement policy. So I can afford to work almost full time on Duet development and support. Most other open-source boards rely on volunteers.
                                adri84dj
                                How do we download version 1.19beta10 + 4 for Duet Ethernet?
                                There is only 1.19beta10 + 2
                                a greeting
                                  If you can wait until tomorrow, I will release beta 11.
                                    adri84dj
                                    @dc42:
                                    Ok perfect. That is good news
                                      Eddiie
                                      Did something change that would affect the Z height of my delta between earlier betas before beta 9?
                                      In beta 9 I tweaked the Z probe offset to get the head right when printing.
                                      Now on beta 10 the same settings now the head crashes into the bed, rips the tape off, no filament comes out because the head is pressing so hard against the bed.
                                      Before beta9 -
                                      G31 X0 Y0 Z1.06 P500
                                      On beta9 and beyond -
                                      G31 X0 Y0 Z1.28 P500
                                      I also had a failed print, maybe it screwed up my z probe..
                                        No, nothing has changed in that area.
                                        53 out of 63
