RRF3 GPIO Confusion
Third-party add-ons
    Pierre52
    I have been on the path of upgrading my Duet 2 Wifi to version 3.2.2 for some weeks now and have slowly been working through the issues of changes to various of the G Codes.
    A few days ago I had the printer (home built AM 8 working perfectly) and then foolishly decided to get my RGB LEDs working. Got all excited when they worked as advertised but then discovered that I got the dreaded "G28 Z Probe already triggered" when I tried to home it.
    Despite commenting out the LED comments the G28 fault remains.
    I have spent the last two days searching through every reference I can find but there is virtually no information available on aspects of the M950 command. The RRF 3 Overview Dozuki is confusing at best and I I note that others have made the same comment. So once again I am forced to trouble the forum for answers to my latest issue.
    My current Config .G is:
    M550 P"Peter Cartesian" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M552 S1 ; enable WiFi
    M569 P0 S0 ; physical drive 0 goes backwards
    ;M569 P4 S1 ; physical drive 4 goes forwards
    M92 X100.00 Y100.00 Z400.00 E419.78 ; set steps per mm
    M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z250.00 E10000.00 ; set accelerations (mm/s^2)
    M84 S30 ; Set idle timeout
    M208 X215 Y215 Z240 S0 ; set axis maxima
    M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin !xstop
    M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin !ystop
    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X24 Y0 Z1.69 ; set Z probe trigger value, offset and trigger height #####################
    M557 X20:215 Y15:180 S20 ; define mesh grid
    M307 H0 R0.392 C310.5 D7.10 S1.00 V23.9 ; Pid Tune 3 March 2021
    M143 H0 S120 ; set temperature limit for Heated Bed to 120C
    M307 H1 R6.299 C94.8 D1.64 S1.00 V24.0 ; Pid Tune 3 March 2021
    M950 F0 C"Fan0" ; create Blower Fan on pin fan0 and set its frequency
    M950 F1 C"Fan1" ; set fan 1 value. Thermostatic control is turned on
    M106 P1 S255 T45 ; Set Hot end fan to 100% when Temp =45
    M563 P0 S"E3D V7" D0 H1 F0 ; define tool 0
    ; LEDs
    ;M950 P1 C"exp.heater4" ; Set heater pin 4 for Red led
    ;M950 P2 C"exp.heater5" ; Set heater pin 5 for Green led
    ;M950 P3 C"exp.heater6" ; Set heater pin 6 for Blue led
    ;M42 P3 S1.0 ;Set LEDs Blue at start
    ;M575 P1 S1 B57600 ; enable support for PanelDue
    T0 ; select first tool
    and my Homeall is:
    M400
    G91 ; use relative positioning
    G1 H2 Z5 F1200 ; Raise Head 5mm
    G1 H1 X-220 F1800 ; Move X to Home
    G1 H1 Y-220 F1800 ; move Y to home
    G90 ; Use Absolute positioning
    G1 X125 Y100 F4000 ; Move head to center of bed
    G30 ; Lower Head, Stop when probe triggered and set Z to trigger height
    G1 X0 Y0 F4000 ; Return Head to Home
      Can you send M122 and M98 P"config.g" and report the results?
      Does the BLTouch pin work correctly?
      Double check the white wire for the Bltouch. That is the trigger signal wire.
      Otherwise the config and home all look ok.
        Pierre52
        Hi Phaedrux
        M122 returns:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917NK-F2MS4-7JKFD-3S46T-1HSNF
        Used output buffers: 3 of 24 (10 max)
        Static ram: 23460
        Dynamic ram: 73392 of which 0 recycled
        Never used RAM 15228, free system stack 191 words
        Tasks: NETWORK(ready,169) HEAT(blocked,228) MAIN(running,449) IDLE(ready,20)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:00:39 ago, cause: power up
        Last software reset at 2021-03-09 15:31, reason: User, GCodes spinning, available RAM 15192, slot 2
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU temperature: min 15.8, current 20.1, max 20.4
        Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 0, standstill, SG min/max not available
        Driver 1: position 0, standstill, SG min/max not available
        Driver 2: position 0, standstill, SG min/max not available
        Driver 3: position 0, standstill, SG min/max not available
        Driver 4: position 0, standstill, SG min/max not available
        Driver 5: position 0
        Driver 6: position 0
        Driver 7: position 0
        Driver 8: position 0
        Driver 9: position 0
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2021-03-09 16:51:43
        Cache data hit count 45937409
        Slowest loop: 80.63ms; fastest: 0.21ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 1.0ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 148.36ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.25
          WiFi MAC address 84:f3:eb:83:4c:6f
          WiFi Vcc 3.40, reset reason Power up
          WiFi flash size 4194304, free heap 26688
          WiFi IP address 192.168.87.40
          WiFi signal strength -31dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
        M98 P"config.g" returns:
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        The BLT Pin works correctly and the trigger signal wire has been checked with continuity tester
          Is the white wire running alongside heater or motor wires that it could be picking up noise from?
          Was the BLtouch working correctly before the LED changes?
          What changes did you make? I can't see what would have caused a problem with the BLtouch.
          Maybe a photo of the install? might give some ideas.
            Pierre52
            Hi Phaedrux
            Answers to your questions:
            1. The white wire runs alongside the Hot end fans, thermistor and heater but none of these are active with this current round of testing.
            2. The BL Touch was working 100% correctly before the LED changes.
            3. For the LEDs I plugged signal leads for R G & B into Heater pins 4, 5 and 6 on the expansion board. These can be seen in the Photo. The LEDs have their own direct feed from the PSU and are linked through a Darlington Array (ULN2803) chip.
            I have also sent the following commands with results as shown:
            Power On - BLT cycles and LED goes orange.
            M199 - Z Probe at min stop
            G92 Z50 DWC shows Z at 50
            M119 - Z Probe at min stop
            M280 P0 S10 Probe extends blue led illuminates
            M119 - z Probe at min stop
            M280 P0 S90 - probe retracts red led illuminates
            M119 - z probe at min stop
              Is it just my bad eyes, or is your BLtouch black and white wires connected to the PAneldue port instead of the probe port?
                Pierre52
                DOH!!!!!!!!!!!!!!!!
                Often it is the obvious mistake that will only get picked up by another set of eyes.
                Thank you Phaedrux it is all working as advertised again.
                3 out of 7
