Duet 3 6HC with Openbuilds XYZ Probe
CNC
4.3k
    chrishamm administrators
    I doubt it will make a difference to run the Duet in standalone mode in this case.
    Is it right that your touch probe is configured as the Z probe? If yes, you should be able to check if the Z probe value in DWC goes from 0 to 1000 whenever it lights up. If it doesn't, I suspect you have a bad contact somewhere.
    Duet software engineer
    undefined 1 Reply Last reply 21 Jan 2021, 07:02 Reply Quote 0
      Yveske @chrishamm
      @chrishamm
      The touch probe does respond to being activated, it lights up and the value on the screen goes to 1000. In the video you can see that probing even works (but not always) on the X-axis, it does always fail on the Y-axis though...
      Will try to get my Duet to boot in standalone mode today. Due to circumstances, my Duet was left boxed for over a year and a half, so I don't have the dual boot SD card. I also don't have the PanelDue, so I can't see what it does or doesn't do on boot... That's why I went with the Pi to connect monitor, mouse and keyboard.
        Yveske @Phaedrux
        @Phaedrux
        Took me some time, but got the Duet to work, the touch probe doesn't however...
        Something I could try next ?
        Thanks in advance
        Yveske
          I'm not sure. It's quite odd. You can see the green LED flash on the X probing, and on the Y it certainly lights up, but isn't being respected.
          Maybe related to the dual Y axis?
          undefined 2 Replies Last reply 22 Jan 2021, 06:27 Reply Quote 0
            Yveske @Phaedrux
            @Phaedrux
            Thanks I will try this today and let you know.
              Yveske @Phaedrux
              @Phaedrux
              Not sure how I can probe on Y with only one motor running without breaking the gantry and without disassembling...
              I did however simulate M675 by manually using M38.2 and M38.4 commands on all axis (X, Y and Z) and this works like a charm.
              Is it possible in a macro to access the coordinates after each command and use that to calculate the center of the cavity myself ?
              undefined 1 Reply Last reply 22 Jan 2021, 19:09 Reply Quote 0
                Phaedrux Moderator @Yveske
                @Yveske said in Duet 3 6HC with Openbuilds XYZ Probe:
                Yeah that's not something you can easily test
                  Yveske
                  Is there anyone out there who can try M675 in both X and Y axis please ?
                  Thanks,
                  Yveske
                    Yveske
                    No takers ?
                    Any chance this will be fixed (if need be) in the next release ?
                      Does M38.2 work properly now, and it is just M675 that doesn't?
                      What M675 command are you sending? Have you used the P parameter to specify that you are using a Z probe, and which one?
                      undefined 1 Reply Last reply 11 Mar 2021, 06:48 Reply Quote 0
                        Yveske @dc42
                        @dc42 Yes m38.2 does work, but I would like to have a tool diameter agnostic homing using the hole in the XYZ probe.
                          And what M675 commands are you trying to use?
                          undefined 1 Reply Last reply 11 Mar 2021, 07:16 Reply Quote 0
                            Yveske @dc42
                            This is my probe macro
                            ; Touch probe.g
                            ; called to find workpiece bottom left corner via G38.2
                            ; Display message without time-out and allow to position the bit
                            M291 T-1 S3 X1 Y1 Z1 P"Make sure the bit is positioned in the hole of the touch probe well beneath the top surface" R"Touch probe"
                            ; Find center of cavity
                            M675 X R8 F100 P0                 ; Find center in X axis
                            M675 Y R8 F100 P0                 ; Find center in Y axis
                            ; Set bit above center of probe
                            G0 Z15                            ; rapid move Z axis 15 mm
                            G0 X27 Y27                        ; rapid move X and Y axis to middle of probe
                            ; Probe Z component
                            G38.2 Z-15 F100                   ; seek until the probe circuit is closed Z-axis -15 mm
                            ; Return bit to center of hole
                            G0 X-27 Y-27                      ; rapid move X and Y axis to center of cavity
                            G0 Z-15                           ; rapid move Z axis -15 mm
                            G10 P0 L20 X0 Y0 Z10              ; store relative probe offset for coordinates system 0
                              Thanks. From your video, it looked as though the M675 X command worked but the M675 Y command did not stop when it should. Is that correct?
                              Can you confirm that you are running firmware 3.2.2 now?
                              undefined 1 Reply Last reply 11 Mar 2021, 08:15 Reply Quote 0
                                Yveske @dc42
                                @dc42 Yes indeed. I haven't invested much time in it since, but it seems M675 in X does work and fails in Y. I'm running 3.2.2 now.
                                  If you comment out the M675 X command in the macro, does the M675 Y command then work?
                                    One more question: do you have deployprobe.g and retractprobe.g files, or not? I think I see a problem with the implementation of M575 when these files are present.
                                    undefined 1 Reply Last reply 11 Mar 2021, 11:16 Reply Quote 0
                                      Yveske @dc42
                                      I don't have those present (see below).
                                      I will try to reconnect everything this afternoon to answer your second question. I'm trying to build an enclosure...
                                      H:\gcodes
                                      H:\macros
                                      H:\sys
                                      H:\www
                                      H:\System Volume Information\WPSettings.dat
                                      H:\System Volume Information\IndexerVolumeGuid
                                      H:\macros\Touch probe.g
                                      H:\sys\bed.g
                                      H:\sys\config.g
                                      H:\sys\Duet3Firmware_MB6HC.bin
                                      H:\sys\homeall.g
                                      H:\sys\homex.g
                                      H:\sys\homey.g
                                      H:\sys\homez.g
                                      H:\sys\pause.g
                                      H:\sys\resume.g
                                      H:\sys\sleep.g
                                      H:\sys\stop.g
                                      H:\sys\tfree0.g
                                      H:\sys\Touch probe.g
                                      H:\sys\tpost0.g
                                      H:\sys\tpre0.g
                                      H:\sys\config.g.bak
                                      H:\sys\dwc-settings.json
                                      H:\www\Duet2CombinedFirmware.bin
                                      H:\www\Duet2Firmware_SBC.bin
                                      H:\www\Duet2_SDiap32_Maestro.bin
                                      H:\www\Duet2_SDiap32_WiFiEth.bin
                                      H:\www\Duet3Firmware_EXP1XD.bin
                                      H:\www\Duet3Firmware_EXP3HC.bin
                                      H:\www\Duet3Firmware_MB6HC.bin
                                      H:\www\Duet3Firmware_Mini5plus.uf2
                                      H:\www\Duet3Firmware_TOOL1LC.bin
                                      H:\www\Duet3_SDiap32_MB6HC.bin
                                      H:\www\Duet3_SDiap32_Mini5plus.bin
                                      H:\www\Duet3_SDiap_Mini5plus.bin
                                      H:\www\DuetMaestroFirmware.bin
                                      H:\www\DuetWiFiServer.bin
                                      H:\www\favicon.ico.gz
                                      H:\www\index.html.gz
                                      H:\www\manifest.json.gz
                                      H:\www\precache-manifest.08b4c61242ac3cb9e1bd2a96bd3aacb2.js.gz
                                      H:\www\service-worker.js.gz
                                      H:\www\css
                                      H:\www\fonts
                                      H:\www\img
                                      H:\www\js
                                      H:\www\precache-manifest.a1d0ef5757696b3d6a44992f8c30488d.js.gz
                                      H:\www\css\app.54d98193.css.gz
                                      H:\www\css\GCodeViewer.68d05d8a.css.gz
                                      H:\www\css\HeightMap.389e8521.css.gz
                                      H:\www\css\ObjectModelBrowser.c5e13b42.css.gz
                                      H:\www\css\OnScreenKeyboard.578a974b.css.gz
                                      H:\www\css\GCodeViewer.18c47076.css.gz
                                      H:\www\css\HeightMap.5a0c6c12.css.gz
                                      H:\www\css\ObjectModelBrowser.7385f747.css.gz
                                      H:\www\css\OnScreenKeyboard.a9b1a06d.css.gz
                                      H:\www\css\TouchJog.9db4823c.css.gz
                                      H:\www\css\app.9ef74274.css.gz
                                      H:\www\fonts\materialdesignicons-webfont.3d1f8fa2.eot.gz
                                      H:\www\fonts\materialdesignicons-webfont.3e722fd5.ttf.gz
                                      H:\www\fonts\materialdesignicons-webfont.4187121a.woff2
                                      H:\www\fonts\materialdesignicons-webfont.4187121a.woff2.gz
                                      H:\www\fonts\materialdesignicons-webfont.fec1b66a.woff
                                      H:\www\fonts\materialdesignicons-webfont.fec1b66a.woff.gz
                                      H:\www\img\icons
                                      H:\www\img\icons\android-chrome-192x192.png.gz
                                      H:\www\img\icons\android-chrome-512x512.png.gz
                                      H:\www\img\icons\android-chrome-maskable-192x192.png.gz
                                      H:\www\img\icons\android-chrome-maskable-512x512.png.gz
                                      H:\www\img\icons\apple-touch-icon-120x120.png.gz
                                      H:\www\img\icons\apple-touch-icon-152x152.png.gz
                                      H:\www\img\icons\apple-touch-icon-180x180.png.gz
                                      H:\www\img\icons\apple-touch-icon-60x60.png.gz
                                      H:\www\img\icons\apple-touch-icon-76x76.png.gz
                                      H:\www\img\icons\apple-touch-icon.png.gz
                                      H:\www\img\icons\favicon-16x16.png.gz
                                      H:\www\img\icons\favicon-32x32.png.gz
                                      H:\www\img\icons\msapplication-icon-144x144.png.gz
                                      H:\www\img\icons\mstile-150x150.png.gz
                                      H:\www\img\icons\safari-pinned-tab.svg.gz
                                      H:\www\js\app.f43f66da.js.gz
                                      H:\www\js\app.f43f66da.js.map.gz
                                      H:\www\js\GCodeViewer.928ca6b9.js.gz
                                      H:\www\js\GCodeViewer.928ca6b9.js.map.gz
                                      H:\www\js\HeightMap.7361cf24.js.gz
                                      H:\www\js\HeightMap.7361cf24.js.map.gz
                                      H:\www\js\ObjectModelBrowser.f722b29d.js.gz
                                      H:\www\js\ObjectModelBrowser.f722b29d.js.map.gz
                                      H:\www\js\OnScreenKeyboard.1f9c0f92.js.gz
                                      H:\www\js\OnScreenKeyboard.1f9c0f92.js.map.gz
                                      H:\www\js\TouchJog.a2011aaa.js.gz
                                      H:\www\js\DRO.f8d0c566.js.gz
                                      H:\www\js\ObjectModelBrowser.62b4acaf.js.map.gz
                                      H:\www\js\ObjectModelBrowser.62b4acaf.js.gz
                                      H:\www\js\OnScreenKeyboard.be1a1000.js.gz
                                      H:\www\js\DRO.f8d0c566.js.map.gz
                                      H:\www\js\OnScreenKeyboard.be1a1000.js.map.gz
                                      H:\www\js\HeightMap.79dc5595.js.gz
                                      H:\www\js\TouchJog.a2011aaa.js.map.gz
                                      H:\www\js\GCodeViewer.32f07c79.js.gz
                                      H:\www\js\HeightMap.79dc5595.js.map.gz
                                      H:\www\js\GCodeViewer.32f07c79.js.map.gz
                                      H:\www\js\app.bbd01205.js.gz
                                      H:\www\js\app.bbd01205.js.map.gz
                                        Thanks, I will also try to reproduce this issue.
                                          I confirm that M675 does not work properly in any recent RRF3 firmware version. I am currently fixing it, in time for firmware 3.3beta3.
                                          undefined 1 Reply Last reply 11 Mar 2021, 16:37 Reply Quote 0
