    Heatbed issue - Heater 0 fault (...)
    • esobreiroundefined
      esobreiro
      Here we go...
      Heater 0 fault: temperature rising much more slowly than the expected 1.6°C/sec - Heatebed.
      Its a big heatbed originally from Tronxy X55 printer (30cmx30cm).
      Following my config.g heater commands:
      M307 H1 B0 S1.0 ; disable bang-bang mode for heater and set PWM limit era B0
      M143 H1 S280
      Its a 600w 24v power source.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.25
      Thank you very much!
      Regards,
      Erick
      • fcwiltundefined
        fcwilt @esobreiro
        @esobreiro
        You need to run heater tuning - see M303.
          esobreiro
          Thank you!
          Warning: heater behaviour was not consistent during tuning
          Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 4186 seconds. This heater needs the following M307 command:
          M307 H0 R0.326 C543.4 D9.46 S1.00 V23.6
          Send M500 to save this command in config-override.g
          Despite the error, the results seems ok:
            It means that the temperatures expected were consistent over the course of the tuning. Depending on how off it was it might or might not be a problem. The algorithm is new and may have some room for improvement, so thanks for the report. If it's working well though and maintains a steady temp you should be fine to use it.
