No connection to Duet-Wifi
Firmware installation
4.4k
    fma
    Ok, I see. pcap file is here:
    https://sys.gbiloba.org/owncloud/index.php/s/wXQK1JBNIyaoRNm
    But I'm now in troubles: I tried to totally erase the firmware, using the erase button, but I'm unable to flash it again! I tried to use bossa, a free linux tool (still waiting from Atmel web site for their soft, but I don't get any notification once registered. When things go wrong…). The strange thing is I still have /dev/ttyACM0 port, but nothing related to bossa.
    [2634139.039937] usb 5-1: New USB device found, idVendor=03eb, idProduct=6124
    [2634139.039941] usb 5-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [2634139.043067] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
    But I'm also unable to send gcodes on this port, so I think there is no more firmware in the flash…
    Frédéric
      fma
      Ok, I was able to flash again the firmware using Atmel tool. But it didn't fix the com problem.
      I tried to enable telnet and ftp. Only ftp works; telnet does not answer neither.
      Strange thing: after the telnet connexion, I initiate a new web connexion, and I got:
      12:39:43.153 : New conn on socket 0 for local port 23 <<<<<<<
      12:39:43.153 : HTTP connection accepted
      12:39:43.155 : Found responder
      12:39:43.155 : Received 404 bytes
      12:39:43.159 : Sending reply, file = yes
      12:39:43.162 : HTTP req, command words { GET / HTTP/1.1 }, parameters { }
      12:40:04.388 : Client disconnected on socket 0
      12:40:04.388 : Can't send anymore
      Port number seems to be wrong (I think it is only in debug message).
      Frédéric
        fma
        Arrgglll!!!! I made a test with a windows machine, running firefox, and it works!!!
        WTF? Why firefox nor chromium does not work from my linux machine???!!???
        Frédéric
          If you get a Wireshatk trace from the Windows machine too, perhaps we be able to spot the difference.
            fma
            If all my problems are related to the wifi module, it would be better for me to switch to the ethernet version.
            Is it possible to make an exchange?
            Frédéric
              fma
              Here is the pcap file recorded from a Windows machine:
              https://sys.gbiloba.org/owncloud/index.php/s/DssgVCz78OtqBGq
              Frédéric
                @fma:
                That will depend on the policy of whoever you purchased it from and/or consumer rights legislation in your country.
                  @fma:
                  Thanks. The traces show that your Windows PC uses an MSS of 1460 and your Linux machine uses 1452. If I set the MTU on my Windows machine to 1492 instead of 1500, this forces the MSS to 1452 as it is on your Linux machine, and I get similar connection problems. So it appears that the TCP/IP stack on the WiFi module is failing to auto-negotiate the MSS.
                  I will look into this. If all else fails, I can rebuild the TCP/IP stack using maximum MSS of 1452 instead of 1460. Meanwhile, if your Linux system allows you to use an MSS of 1460, that may work around the problem.
                    I think I found the cause: this bug in LWIP http://savannah.nongnu.org/bugs/?func=detailitem&item_id=46384. It's been fixed, so with luck we just need to update the version of LWIP we are using.
                      fma
                      That's great news!
                      Do you think this can also be the source of crashs with the 1.18 and previous firmwares, where code is entirely managed by the ESP? If you apply the patch in this branch too, I can make some tests…
                      Thanks for your support.
                      Frédéric
                        fma
                        I will also see if I can use a MTU of 1500, instead of 1492 (I think I reduced it to handle ssh connexions, but I'm not sure if I need it anymore, as I changed my router, and OpenWRT version).
                        Frédéric
                          Please try this preview of DuetWiFiServer 1.19beta10: https://dl.dropboxusercontent.com/u/19369680/DuetWiFiServer.bin. If you don't have networking functional at present, you will need to copy the file into /sys on your SD card, put the SD card back in the Duet, restart the Duet, and run M997 S1 from USB or PanelDue. Then wait until the blue light on the wifi module stops flashing.
                          My windows machine now connects with an MSS of 1452.
                          I can't easily make that patch to the older version of DuetWiFiServer, because that version used a build of lwip pre-compiled by Expressif. In any case, we have no interest in going back to that version because the newer version offers a number of advantages, such as FTP and Telnet support.
                            fma
                            I test this this evening…
                            No problem for the 1.18; it was just a suggestion.
                            Frédéric
                              fma
                              Ok, all works fine with a MTU 1500: I can have access to the duetwifi, and ssh connexions still work! And the test firmware you linked works fine with a MTU 1492.
                              Good! Let's start playing with this great tool 😉
                              Thanks again for the support.
                              Frédéric
                                I'm glad to have been of assistance.
                                32 out of 37
