    Pause and Cancel Buttons Not Working Right.
    Duet Web Control
    • ProbiusSCundefined
      ProbiusSC
      Simple enough issue that I haven't been able to find the cause of. When the pause button is pressed the printer just stops what it's doing and goes into the paused state, without running pause.g. Similar behavior when cancelling a print, printer stops, goes into the right state, but cancel.g isn't called.
      Board: Duet 2 WiFi
      Firmware Version: 3.2.2 (2021-02-11)
      WiFi Server Version: 1.25
        What version of DWC? 3.2.2 to match the firmware?
        Please post the contents of your pause and cancel files.
          ProbiusSC
          DWC 3.2.2
          ; pause.g
          ; called when a print from SD card is paused
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 11 2020 14:43:59 GMT-0700 (Mountain Standard Time)
          M83 ; relative extruder moves
          G1 E-3 F3600 ; retract 3mm of filament
          G91 ; relative positioning
          G1 Z5 F360 ; lift Z by 5mm
          G90 ; absolute positioning
          G1 X0 Y0 F6000 ; go to X=0 Y=0
          ; cancel.g
          ; called when a print is cancelled after a pause.
          T-1 ; Park any active tool.
          G0 X0 Y0 F20000 ; Return home.
          M140 S0 ; Turn off the bed heater.
          M104 S0 ; Turn off the extruder.
          M106 P1 S0 ; Turn off part cooling fan.
          M84 S600 ; Disable motors after 10 mins of inactivity
            When you try to pause the print, do you get a warning message on the console that pause.g was not found?
            ProbiusSCundefined 1 Reply Last reply Reply Quote 0
              ProbiusSC @dc42
              @dc42 No warning of any kind. No entries in the event log are created from pausing either.
