correctly Config for my Fan
Config Tool
386
    chuser
    I have a DICE Printer.
    my FAN Config
    M950 F0 C"out3" Q500
    M950 F1 C"out5" Q500
    M950 F2 C"out6" Q500
    out5 and out6 also work.
    But out3 burns my fans (Sunon MC30060V2-00U-A99).
    Measured at the fan 5V arrive.
    But the fan is already on strike at 50%.
    Can someone help me?
    Here the wirring
    undefined 1 Reply Last reply 12 Mar 2021, 16:58 Reply Quote 0
      fcwilt @chuser
      @chuser said in correctly Config for my Fan:
      Are you saying that out5 and out6 are working correctly?
      What do you mean by "burns"?
      Are you saying you have measured that the outputs are providing 5 volts?
      What does that mean?
        chuser
        Thank you for your Answer.
        @fcwilt said in correctly Config for my Fan:
        yes working correctly
        The fan rotate, then stops and smokes and that already at 50%
        yes corretly
        undefined 1 Reply Last reply 12 Mar 2021, 17:13 Reply Quote 0
          fcwilt @chuser
          Not all fans can be controlled with PWM to vary the speed.
          Perhaps the one that is smoking is one of those that cannot be controlled.
          If it is still working try 100% - that feeds un-pulsed power to the fan just as if was receiving power from a 5 volt DC source.
            chuser
            Thanks for the tip
            I tried that but it did not work.
            The fan spins for about 5 seconds and then it stops.
            And I noticed now that as soon as the fan stops the board reboot. no smoke appears.
            Isn't there a possibility to use the out3 withouth PWM?
            undefined 1 Reply Last reply 12 Mar 2021, 17:54 Reply Quote 0
              fcwilt @chuser
              Thanks for the tip
              Perhaps you are drawing more current than the on-board power 5 volt power supply can provide?
              It's limited to about 700ma according to the docs.
              That would explain why the board re-boots.
              undefined 1 Reply Last reply 12 Mar 2021, 18:03 Reply Quote 0
                chuser @fcwilt
                @fcwilt
                The fan which makes troubles has only 0.072mA - in my opinion that shouldn‘t be the reason for re-booting
                What do ya think?
                  If you don't need PWM control or switching, can you connect it directly to a 5v source and run it as always on?
                  Is this the fan?
                  https://www.mouser.ca/ProductDetail/Sunon/MC30060V2-000U-A99?qs=EU6FO9ffTwdvsqO4GP3Tbg==
                  undefined 1 Reply Last reply 12 Mar 2021, 20:59 Reply Quote 0
                    chuser @Phaedrux
                    @Phaedrux yes its this type of fan.
                    I will do a test run tomorrow and will let you know!
                      Does the fan work on the other ports without issue?
                        chuser
                        @fcwilt @Phaedrux Thank you very much for the help.
                        I have measured the power current of the fan and found that it is too much. The current of the fan rised above 1A after a short time.
                        I have replaced the fan and now everything works.
                        undefined 1 Reply Last reply 14 Mar 2021, 12:38 Reply Quote 1
                          fcwilt @chuser
                          So it turned out to be the fan that was causing the reset as we suspected.
                          Glad to hear you got it all sorted.
                          5 out of 12
