Duet 3 6ch not recognized after installing Beta version
im not at the router at the minute give me a few minutes and ill check, just installing firmware you sent thanks.
right seems to be homing now however did get a error pop up:
M120
G91
G1 Y-10 F6000
G90
M121
Error: G0/G1: insufficient axies homed -
When did you get that error? It would mean what it says that an axis has been commanded to move when it isn't yet in a homed state.
@Phaedrux that popped up after i pressed home all
Odd. I don't see anything in your homeall that would invoke that.
ive home again and looks fine, thank you for you help, was the issue to do with the firmware do you think?
I'm not really sure. Are you back on 3.2.2?
i thought it had updated but just checked the config file and its still reading 3.2.3, retried to update firmware and my DWC is sticking on a grey screen.
@UcantCNCme said in Duet 3 6ch not recognized after installing Beta version:
Where are you seeing that? Sounds like maybe just the text in the config file saying what version of the config tool was used to generate the file.
To see what version is installed either send M115 and it will tell you, or check the settings and machine specific tab in DWC to see the firmware and DWC versions installed.
apologies your right, that m,st of been the version during the config, heres the M115
3/15/2021, 10:15:36 PM M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-02-11 -
Ok, that's makes more sense.
The config file text won't change unless you change it. It's just a text file after all.
ah right, good to know, thank you very much for your help. i need to start another thread regarding my XYZ touch probe now, hopefully i can get this thing up and running!
