Mesh compensation disappeared from drop down menu
My mesh compensation map disappeared from my drop down menu. it was there before but now it is not there. it disappeared after I tried leveling the bed a bunch of times because the map was getting a bunch of errors. I restarted my machine a few times already and i am still have this issue.
What is your screenshot showing?
What firmware and DWC version?
If you send G29 S1 does it make mesh compensation active?
@Phaedrux yes it does, there is just no graphical interface that shows the height map in the control drop down.
What do you mean by control drop down? The compensation & calibration drop down menu?
Again, what version of firmware and DWC are you using? Did you recently update? The heightmap display is handled by a plugin in recent versions.
So if you're on a recent version check under Settings > General > and the plugins tab and enable the heightmap plugin.
OK that worked, thank you
Happy to help.
