    xy movement short +/- 20%
    • KevinSantundefined
      KevinSant
      I have a corexy with duet 2 wifi on rrf 3.2
      when I go move 100 mm it moves approx 80 mm
      if I move 25 mm it moves 20 what can cause this?
        Incorrect steps per mm? M92
        Slipping pulleys from loose grub screw?
        Missed steps from binding or too low motor current?
        • mendenmhundefined
          mendenmh
          wrong tooth count on the pulleys? i.e. a 16 tooth pulley where there should be a 20 tooth pulley? Note that 16/20 = 80%.
            KevinSant
            yea that was it i changed to gates pulleys from 20 to 16 i changetd m92 to 100 instead of 80 and its spoton now
