    DuetLapse3
    Third-party software
    20
    296
    31.8k
    • JohnOCFIIundefined
      JohnOCFII
      Looking a little more closely, issue seems to be in here:
      -weburl1 http://octocore.localdomain:8081/snapshot
      If I change weburl1 to weburl I get a different error.
      Could this be a permissions issue? I installed DuetLapse3 in /opt. I see it did create subdirectories like so:
      pi@octocore:/opt $ tree DuetLapse/
      DuetLapse/
      |-- DuetLapse3.py
      `-- octocore
          `-- railcore-localdomain
      2 directories, 1 file
      pi@octocore:/opt $
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
      • stuartofmtundefined
        stuartofmt @JohnOCFII
        @JohnOCFII said in DuetLapse3:
        Hi John - We'll get you going.
        The first thing is that it's weburl1 (numerical 1 at the end). Putting weburl will result in an error message about an unrecognized argument.
        The other error is complaining because it looks like your OS is set to latin-1 whereas pretty much any code written today (inclusing DuetLapse3) anticipates utf8. The reason for that particular character (raised colon) is because Windows does not allow a regular colon in filenames and visually - colons are useful for time representation .... so I used raised colons for cross platform consistency 😞
        The area in the code where the issue is being raised looks to be quite early - setting up the logfile and I suspect the OS is complaining at that point.
        Are you willing to change your Centos settings?
        This seems to suggest that its pretty straightforward.
        https://serverfault.com/questions/275403/how-do-i-change-my-locale-to-utf-8-in-centos
        Edit: It could also be the way the filesystem is mounted. Take a look at /etc/fstab - there may be some limiting settings there ....
        And this looks like it may be useful:
        https://www.osetc.com/en/centos-7-rhel-7-change-the-system-locale.html#:~:text=To show the current locale,β€œcat %2Fetc%2Flocale.
        For reference - this is what my Debian systems look like:
        pi@srsenderpi:~ $ localectl status
           System Locale: LANG=en_US.UTF-8
               VC Keymap: n/a
              X11 Layout: us
               X11 Model: pc105
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          JohnOCFII
          Actually, I lied. I have a bunch of CentOS VMs, but THIS is running on a Raspberry Pi.
          pi@octocore:/opt $ cat /etc/os-release
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          But somehow, the locale is not correct:
          pi@octocore:/opt $ localectl status
                 VC Keymap: n/a
                X11 Layout: gb
                 X11 Model: pc105
          pi@octocore:/opt $
          I'm running through raspi-config now to reset locale.
          I'll report back soon!
            JohnOCFII @stuartofmt
            @stuartofmt Fixing the locale to be UTF-8 compliant got me past that issue -- thanks!
            I also had installed DuetLapse in /opt, and had forgotten to set the ownership to user pi, so I was having some permission issues, but that was easy to spot and to fix.
            Basic test went fine. Now on to setting up and testing startDuetLapse3.
              Great to hear !
              Note that there are a couple of small differences between DuetLapse3 and the original. Mainly in the more exotic settings. The defaults Omitted options) should result in more-or-less the same behavior.
              I think you will like startDuetLapse3. You can then do most everything from a browser without "gymnastics".
              Appreciate any and all feedback.
                @stuartofmt So far, so good. About 8 short prints so far today.
                One interesting observation. I use multiple subdirectories for my GCODE files on my printer. Up until this last print, all the DuetLapse tests I've done were from one directory. I just did a small test from another directory (at the same level in the printer GCODE files hierarchy), yet it appears DuetLapse created a separate subdirectory for this job, and created and kept all the JPEGs for this last movie.
                Here is the directory tree:
                pi@octocore:/opt/DuetLapse $ tree
                β”œβ”€β”€ DuetLapse3.py
                └── octocore
                    └── railcore-localdomain
                        β”œβ”€β”€ 4974_Camera1_Sun-10-51.mp4
                        β”œβ”€β”€ 5343_Camera1_Sun-12-18.mp4
                        β”œβ”€β”€ 5868_Camera1_Sun-14-59.mp4
                        β”œβ”€β”€ 6261_21-03-21T18ΛΈ12ΛΈ26.log
                        β”œβ”€β”€ 6261_Calibration
                        β”‚Β Β  └── HoseSideRingTest-v3_0.2mm_PETG_RC
                        β”œβ”€β”€ 6261_Camera1_Sun-18-23.mp4
                        └── 812_Camera1_Sat-21-57.mp4
                4 directories, 29 files
                  So it looks like the print job was named /Calibration/HoseSideRingTest-v3_0.2mm_PETG_RC Does this seem right given your situation ? Code-wise, the print job name is appended to the process id and a directory created accordingly.
                  If this is not the case then I'd need more info to make sense of it - specifically
                  (1) The options used to start DuetLapse3
                  (2) The hostname of the computer running DuetLapse3 (looks to be octocore)
                  (2) the duet printer name (looks to be railcore-localdomain)
                  (3) the full printjobname and the gcode directory in which it was placed.
                  Are the directories cleaned up when you start a new (only one running) instance of DuetLapse3?
                  Take a look at the documentation and see if its clear. If not - let me know and I will fix.
                  EDIT: I can probably (and likely will) suppress the possibility of higher level directory names - but in any case understanding your situation will be helpful.
                    @stuartofmt said in DuetLapse3:
                    This is correct.
                    Yes -- I think what confused me is that at the time I created that tree, the directory and JPEGs were still around -- I was thinking they got cleaned up at the end of the current job, and not the start of the next job.
                    I actually prefer your current design.
                    Also - I am really glad of your current design for another reason -- I love the log file! I ran a 7.5 hour print yesterday evening, and my Pi lost network connectivity 5 times during the print. All the successfully captured images are still available for me to re-run through FFMPEG! Separately I need to try to use the wired Ethernet instead of WiFi to see if the WiFi on this particular Pi is the issue.
                      I mostly use a Pi with my Duet2 Wifi. Both are fairly close to the router - so good connectivity. Nonetheless - DuetLapse3 should (provided the connectivity issues do not last too long) work through them. I tested the code by deliberately turning off the Duet , performing multiple emergency restarts etc. In short - with a bit of luck - DuetLapse3 should create the video provided it saw the transition to "idle" at the end of the print job. Note that today I discovered a possible "transient status" that may prevent a video being created at the end of the print job. It's possibly related to my custom ending gcode - but I have a fix πŸ™‚
                      In any case - "yes", that's a good reason for leaving the captured images in place at the end of the job. Also - if you have not noticed - you can use startDuetLapse3 to zip up the directory (after the DuetLapse3 instances has terminated) then download the resultant zipfile, all from a browser.
                      I'm thinking about adding a "create video" button to simplify the recovery - but at some point - I've go to stop adding in "stuff".
                        @stuartofmt It is great to see how your mind works on this stuff!
                        FYI -- I did disable WiFi, and switch to wired Ethernet. I am no longer seeing connectivity issues, but Duetlapse is still seeing "something" network related. I will gladly 100% blame this on the weak networking code in the firmware on the Duet2 -- whatever library is used in this hardware (not from dc42 -- but whatever the vendor provides) seems to act as if it hasn't seen changes to networking code since the 1990's.
                        This is what I see a few times an hour:
                        railcore.localdomain !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        railcore.localdomain There was a network failure: HTTPConnectionPool(host='railcore.localdomain', port=80): Max retries exceeded with url: /rr_model?key=state.status (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x764ad170>: Failed to establish a new connection: [Errno 111] Connection refused'))
                        or
                        railcore.localdomain There was a network failure: HTTPConnectionPool(host='railcore.localdomain', port=80): Max retries exceeded with url: /rr_model?key=state.status (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7664cdf0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
                        railcore.localdomain getDuetStatus failed to get data. Code: 9999 Reason: Connection Error
                        railcore.localdomain Printer is disconnected - Trying to reconnect
                        railcore.localdomain ****** Duet status changed to: processing *****
                        railcore.localdomain ****** Print State changed to: Capturing *****
                        As you suggested, DuetLapse seems to work past it without issue.
                        John
                          @JohnOCFII
                          The problem is that DuetLapse3 is asking for the current status and not getting a reply. It dutifully retries after a brief pause but will eventually give up. For the most part - it can work through and it does not matter if it misses capturing an image.
                          It may be pure network related or it mat be that DWC is "overloaded" servicing too many requests per unit time. If you have other applications getting status frequently (lets say every second) then that might be an issue - but other than that - 1990s network code seems as good a guess as any.
                            JohnOCFII
                            I'd guess that running DWC on two other devices in addition to DuetLapse might have had the Duet2 board confused...
                            Today, after a fresh start on the printer and after quitting DWC after the first layer completed, I didn't see any disconnect errors.
                            Here's a nice example DuetLapse3 timelapse. This was a 3 hour 20 minute print in a 53 second timelapse.
                            https://youtu.be/civr9_qgMhM
                            • GoremanXundefined
                              GoremanX
                              Still figuring stuff out for my setup, but this is getting fun πŸ™‚
                              https://youtu.be/EscEw5L3rYU
                                JohnOCFII @GoremanX
                                @GoremanX said in DuetLapse3:
                                Really raising the bar with music... I'll have to see what I can find!
                                GoremanXundefined 1 Reply Last reply Reply Quote 0
                                • GoremanXundefined
                                  GoremanX @JohnOCFII
                                  Hah! "Stock" previews from Adobe Premiere Pro. Not even the fully licensed track, just the so-called low quality preview version. If enough people view the video, YouTube will flag it, but it's fine to use for a limited expected audience
                                    JohnOCFII
                                    @stuartofmt I'd like some guidance before I head off in the wrong direction.
                                    I've set up (but not yet started):
                                    /etc/systemd/system/StartDuetLapse3.service
                                    which calls:
                                    /opt/DuetLapse/StartDuetLapse3.py
                                    which calls:
                                    /opt/DuetLapse/DuetLapse3.py
                                    Now -- when I've been testing this over the last few days manually (without the systemd service, and without using StartDuetLapse3) I've used the following command line:
                                    python3 /opt/DuetLapse/DuetLapse3.py -duet railcore.localdomain -camera1 web -weburl1 http://octocore.localdomain:8081/snapshot -detect layer -extratime 4
                                    So switching to this service-initiated launch, do I put all the arguments in the systemd service file like this?
                                    ExecStart=python3 /opt/DuetLapse/StartDuetLapse3.py -port 8082 -args="-duet railcore.localdomain -camera1 web -weburl1 http://octocore.localdomain:8081/snapshot -detect layer -extratime 4"
                                    Thanks for your review!
                                    John
                                      Essentially - yes but note:
                                      (1) it looks like you have capitalized startDuetLapse3.py
                                      (2) startDuetLapse3 does not directly call DuetLapse3. Its a browser accessed service that provides various controls. The "args=" option sets a default string (that you can edit) in the browser interface. For example my startDuetLapse3.service file looks like this:
                                      [Unit]
                                      Description=duetLapse3 Service
                                      After=multi-user.target
                                      [Service]
                                      WorkingDirectory=/home/pi/Lapse
                                      User=pi
                                      Type=idle
                                      ExecStart=python3 /home/pi/Lapse/startDuetLapse3.py -port 8082 -topdir /home/pi/Lapse/Captures -args=" -duet 192.168.86.235 -port 8083 -basedir /home/pi/Lapse/Captures -dontwait -seconds 15 -detect none -weburl1 http://192.168.86.230:8081/stream.mjpg -camera1 other -camparam1=&quot;&apos;ffmpeg&apos; +ffmpegquiet + &apos; -y -i &apos; +weburl+ &apos; -vframes 1 &apos; +fn+debug&quot;"
                                      Restart=always
                                      [Install]
                                      WantedBy=multi-user.target
                                      and results in the browser showing this (when start is pressed).
                                      The text above the second start is what is extracted from args=. It's editable (or you could leave out args= and type / copy / paste into that field.
                                      The important thing is its not until the second "start" is pressed that DUetLapse3 is started. In this manner you can easily manage multiple instances if you wish.
                                      Hope this helps.
                                      P.S. I've made a few tweaks. likely out in a day or two. Mainly the ability to create video from startDuetLapse3 (if the dir still exists).
                                        @stuartofmt Thanks for the review.
                                        Checking status now, I get the following message:
                                        pi@octocore:/etc/systemd/system $ sudo systemctl status startDuetLapse3.service
                                        ● startDuetLapse3.service - DuetLapse3 timelapse launch script
                                           Loaded: loaded (/etc/systemd/system/startDuetLapse3.service; enabled; vendor preset: enabled)
                                           Active: active (running) since Thu 2021-03-25 19:51:17 CDT; 13h ago
                                         Main PID: 471 (python3)
                                            Tasks: 2 (limit: 2062)
                                           CGroup: /system.slice/startDuetLapse3.service
                                                   └─471 /usr/bin/python3 /opt/DuetLapse/startDuetLapse3.py -port 8082
                                        Mar 26 04:10:03 octocore python3[471]:     method()
                                        Mar 26 04:10:03 octocore python3[471]:   File "/opt/DuetLapse/startDuetLapse3.py", line 198, in do_GET
                                        Mar 26 04:10:03 octocore python3[471]:     split_referer = referer.split(":", 1)
                                        Mar 26 04:10:03 octocore python3[471]: AttributeError: 'NoneType' object has no attribute 'split'
                                        Mar 26 04:10:03 octocore python3[471]: ----------------------------------------
                                        Mar 26 04:10:03 octocore python3[471]: Exception happened during processing of request from ('192.168.88.1', 40405)
                                        Mar 26 04:10:03 octocore python3[471]: Traceback (most recent call last):
                                        Mar 26 04:10:03 octocore python3[471]:   File "/usr/lib/python3.7/socketserver.py", line 650, in process_request_thread
                                        Mar 26 04:10:03 octocore python3[471]:     self.finish_request(request, client_address)
                                        Mar 26 09:38:44 octocore systemd[1]: startDuetLapse3.service: Current command vanished from the unit file, execution of the command list won't be resumed.
                                        Looking at that line 198 in startDuetLapse3.py it looks like it has something to do with parsing the URL.
                                        Here is the ExecStart line from the service file:
                                        ExecStart=python3 /opt/DuetLapse/startDuetLapse3.py -port 8082 -args="-duet railcore.localdomain -camera1 web -weburl1 http://octocore.localdomain:8081/snapshot -detect layer -extratime 4"
                                        Thoughts?
                                        John
                                        stuartofmtundefined 2 Replies Last reply Reply Quote 0
                                        • GoremanXundefined
                                          GoremanX
                                          Feature suggestion: add an option to create a symbolic link that always points to the second-most-recent photo for a currently-running timelapse. For example, the current directory for captured images on one of my printers is: /mnt/remote/KosselXT/duet/21439_CFFFP_Riser_191x25_links
                                          An option to have a symbolic link at /mnt/remote/KosselXT/current.jpg that always points to the second-most-recent image would allow us to add it to the DWC interface as a webcam image by serving that file over http. The symbolic link would have to be updated every frame. The reason I'm specifically referring to the second-most-recent image is that sometimes the current image isn't complete yet when DWC tries to display it. Pointing the link to the second-most-recent image would always display a complete image, at the expense of being a few seconds behind.
                                            @johnocfii said in DuetLapse3:
                                            I’ve found that it’s important / helpful to prove the command independently of systemctl first. What do you get from the log file when you use the same command with -verbose ?
