    Magnetic sensor errors - long print
    Filament Monitor
    • Depundefined
      Dep
      When printing a part about 100 hours long, a "sensor error" appears. Received it already 4 times in 100 hours.
      You just need to continue printing and everything works until the next error. I don't see any more messages. The filament monitor is working properly. Except for one more nuance - I have already received the message "tooMuchMovement" 2 times, although it is physically impossible for the feed to be increased.
      Well, and another strange thing: for printing, I need about 10 kg of plastic. The slicer shows 3189299.50 mm which roughly corresponds to 10 kg PLA. But in status now: Layer 927 of 1100, Filament Usage: 5827260.0 mm (0.0 mm remaining). This is strange.
      Screenshots:
      • Depundefined
        Dep
        The entire extruder including heaters, motor, etc. as well as the filament monitor itself are connected to one Duet 3 Toolboard 1LC (address 21).
          Can you please provide some more details?
          Config.g and the results of M122 and M122 B1 please.
          Sample gcode?
          • Depundefined
            Dep
            @Phaedrux said in Magnetic sensor errors - long print:
            M122
            Of course.
            Now I have changed the sensor and start printing for 22 hours.
            The printer has a 1mm nozzle, so a lot of plastic goes through the sensor. This print is for 2 kg.
            M122
            RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
            Board ID: 08DJM-956BA-NA3TN-6JTDJ-3S86M-1TBGT
            Used output buffers: 1 of 40 (40 max)
            Static ram: 149788
            Dynamic ram: 95336 of which 156 recycled
            Never used RAM 113552, free system stack 126 words
            Tasks: NETWORK(ready,189) ETHERNET(blocked,110) HEAT(blocked,278) CanReceiv(blocked,801) CanSender(blocked,348) CanClock(blocked,352) TMC(blocked,17) MAIN(running,1141) IDLE(ready,19)
            Owned mutexes: HTTP(MAIN)
            Last reset 00:46:41 ago, cause: power up
            Last software reset at 2021-03-20 16:36, reason: User, GCodes spinning, available RAM 113776, slot 1
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x04
            Aux0 errors 512,512,512
            Aux1 errors 0,0,0
            MCU temperature: min 24.0, current 47.3, max 47.6
            Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0
            Driver 0: position 30000, standstill, reads 5134, writes 27 timeouts 0, SG min/max 0/286
            Driver 1: position 76000, standstill, reads 5138, writes 23 timeouts 0, SG min/max 0/334
            Driver 2: position 139400, standstill, reads 5139, writes 23 timeouts 0, SG min/max 0/342
            Driver 3: position 8000, standstill, reads 5139, writes 23 timeouts 0, SG min/max 0/317
            Driver 4: position 0, standstill, reads 5139, writes 23 timeouts 0, SG min/max 0/329
            Driver 5: position 0, standstill, reads 5135, writes 27 timeouts 0, SG min/max 0/252
            Date/time: 2021-03-26 13:32:36
            Slowest loop: 141.57ms; fastest: 0.07ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 2.7ms, write time 84.7ms, max retries 0
            DMs created 125, maxWait 762879ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 99, completed moves 99, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 42], CDDA state -1
            === AuxDDARing ===
            Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 5 -1 -1 -1
            Heater 0 is on, I-accum = 0.3
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            HTTP is ready with "M122 " in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 141.52ms; fastest: 0.02ms
            HTTP sessions: 1 of 8
            - Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            === Filament sensors ===
            Extruder 0: no data received
            Extruder 2: no data received
            === CAN ===
            Messages queued 11511, send timeouts 0, received 70289, lost 0, longest wait 2ms for reply type 6031, free buffers 48
            M122 B1
            Diagnostics for board 1:
            Duet EXP3HC firmware version 3.2.2 (2021-02-12)
            Bootloader ID: not available
            Never used RAM 154776, free system stack 158 words
            HEAT 92 CanAsync 94 CanRecv 84 TMC 30 MAIN 317 AIN 259
            Last reset 00:47:54 ago, cause: software
            Last software reset data not available
            Driver 0: position -92000, 200.0 steps/mm,  standstill, reads 1707, writes 39 timeouts 0, SG min/max 0/1023
            Driver 1: position 610650, 115.0 steps/mm,  standstill, reads 1654, writes 95 timeouts 0, SG min/max 0/1023
            Driver 2: position 0, 115.0 steps/mm,  standstill, reads 1665, writes 87 timeouts 0, SG min/max 0/0
            Moves scheduled 33, completed 33, in progress 0, hiccups 0
            No step interrupt scheduled
            VIN: 24.2V, V12: 12.1V
            MCU temperature: min 40.0C, current 40.2C, max 40.2C
            Ticks since heat task active 221, ADC conversions started 2874212, completed 2874212, timed out 0
            Last sensors broadcast 0x00000000 found 0 224 ticks ago, loop time 0
            CAN messages queued 146, send timeouts 0, received 49000, lost 0, free buffers 36
            G90                                             ; send absolute coordinates...
            M83                                             ; ...but relative extruder moves
            M575 P1 B57600 S1       						; Comms parameters for PanelDue
            M564 S1 H1              						; Forbid axis movements when not homed
            M552 P0.0.0.0 S1                                 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                       ; enable HTTP
            M586 P1 S0                                       ; disable FTP
            M586 P2 S0                                       ; disable Telnet
            M569 P0.0 S0                                     ; X drive goes back
            M569 P0.1 S1                                     ; Z1 drive
            M569 P0.2 S0                                     ; Z2 drive
            M569 P0.3 S1                                     ; Z3 drive
            M569 P0.4 S0                                     ; Z4 drive
            M569 P0.5 S0                                     ; Y drive
            G4 P500											; Pause for toolboards init
            M569 P21.0 S1                                   ; Extruder 1 (T0)
            M569 P1.1 S0                                    ; Extruder 1 spool driver
            M569 P22.0 S1                                   ; Extruder 2 (T1)
            M569 P1.2 S0                                   ; Extruder 2 spool driver
            M569 P1.0 S1                                   ; Coupler
            M584 X0.0 Y0.5 Z0.1:0.2:0.3:0.4 C1.0        ; set Move drive mapping
            M584 E21.0:1.1:22.0:1.2                    ; set Extruder drive mapping
            M208 Z-4:875 C0:500
            M208 X-570:570 Y-630:500
            ; Define the bed mounting coordinates
            M671 X-473:473:473:-473 Y730:730:-735:-735 S10 ;Snn Maximum correction allowed for each leadscrew in mm (optional, default 1.0)
            M574 X1 S1 P"!io1.in"                           ; configure active-high endstop for high end on X via pin !io1.in
            M574 Y2 S1 P"!io2.in"                           ; configure active-high endstop for low end on Y via pin !io2.in
            M574 Z0 P"nil"									; no endstop on Z
            M574 C1 S3										; Stall detect coupler at low end of its range
            ;Steps per mm = (Motor Steps per Revolution * Driver Microstep) / (Belt Pitch * Pully Number of Teeth)
            ; X: GT2-20 / Y: HTD3-20 * (48/16) / Z: HTD5-20 * 6
            M92 X80 Y160 Z800 C200 					; set steps per mm
            M92 E420.00:115.00:420.00:115.00 				; set steps per mm
            M350 X16 Y16 Z16 E16:16 I1                       ; configure microstepping with interpolation
            M350 C16 I1
            M566 X420 Y420 Z8 C2 E200:200:200:200			; Set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z600.00 C10000 E6000.00 	; set maximum speeds (mm/min)
            M201 X1200.00 Y1200.00 Z100.00 C500 E2500       	; set accelerations (mm/s^2)
            M204 P250 T1200										; Travel and print acceleration
            M906 X1200 Y1600 Z2400 C500 E700:700:700:700	 	; set motor currents (mA) and motor idle factor in per cent
            M913 C50
            M906 I30
            M913 E100:0:100:0									; set Working current to Extruders
            M84 S120                                       		; Set idle timeout
            ;Stall Detection
            M915 C S5 F0 H200 					; Coupler
            M558 K0 P5 B1 C"^io7.in" H5 A5 F120 T9000			; set Z probe type to switch and the dive height + speeds
            G31 K0 X0 Y0 Z0 P1000                            	; set Z probe trigger value, offset and trigger height
            M557 X-500:500 Y-500:500 S100                       ; define mesh grid
            ; Calibrate Nozzle Height probe
            M558 K1 P8 B0 C"^io8.in" H30 F120 T9000
            G31 K1 P1000 X0 Y0 Z0
            ; ==== Heaters ====
            ; Bed
            M308 S0 P"temp0" Y"thermistor" T100000 B3950     	; configure sensor 0 as thermistor on pin temp0
            ;M950 H0 C"out0" T0                             	; create bed heater output on out0 and map it to sensor 0
            M950 H0 C"out0" T0 Q10         						; Heater --> SSD-Steuerung
            ;M307 H0 B0 S0.80                                 	; disable bang-bang mode for the bed heater and set PWM limit
            ;M307 H0 R0.425 C261.3 D4.03 S0.80				; Tuned
            M307 H0 R0.191 C560.9 D3.56 S1.00 V24.1
            M140 H0                                          ; map heated bed to heater 0
            M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
            ; Chamber
            M308 S5 P"temp1" Y"thermistor" T100000 B4138  ; configure sensor 5 as thermistor on pin temp1
            M950 H5 C"out9" T5 Q10                          ; create chamber heater output on temp1 and map it to sensor 5
            M307 H5 R1.000 C30.9 D9.18 S1.00 V24.1 		; Tuned
            M141 H5                                       ; map chamber to heater 5
            M143 H5 S75                                   ; set temperature limit for heater
            M950 F5 C"out4" Q500                          ; cooling fan
            M106 P5 S0 H-1 C"Filament FAN" 					; Control be trigger2
            ;M106 P5 S1 H5 T22:60                          	; thermistatic control
            M950 J8 C"0.io6.in"							; Input 8 for filament Fan
            M581 T2 P8 S1 R0							; Invoke trigger 2 when an inactive-to-active edge is detected on input 8
            ; Extruder 1
            M308 S1 P"21.temp0" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin 121.temp0
            M950 H1 C"21.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
            M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S285                                    ; set temperature limit for heater 1 to 285C
            ;M307 H1 R3.214 C42.3 D7.77 S0.75 V23.2 		; Tuned
            ;M307 H1 R0.056 C194.7 D8.90 S1.00 V23.9		; small block
            ;M307 H1 R3.358 C190.6 D7.20 S0.60 V23.6
            M307 H1 R1.936 C200.6 D7.57 S1.00 V23.6
            ; Extruder 2
            M308 S2 P"22.temp0" Y"thermistor" T100000 B4725 ; configure sensor 2 as thermistor on pin 122.temp0
            M950 H2 C"22.out0" T2                           ; create nozzle heater output on 122.out0 and map it to sensor 2
            M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
            M143 H2 S285                                    ; set temperature limit for heater 2 to 285C
            ;M307 H2 R3.056 C229.5 D7.91 S0.80 V23.3 		; Tuned
            ;M307 H2 R3.090 C199.8 D7.36 S0.75 V23.3
            ;M307 H2 R3.202 C234.301:234.301 D7.52 S0.70 V23.3 B0 I0
            ;M307 H2 R3.358 C190.6 D7.20 S0.60 V23.6
            ; *** Fans
            ; Extruder 1 Fan
            M950 F0 C"21.out1" Q500                         ; Part cooling fan
            M106 P0 S0 B0.1 H-1                             ; Default off. booststart for 0.1s (B0.1); thermostatic control off
            M950 F1 C"21.out2" Q500                         ; Hotend cooling fan
            M106 P1 S1 H1 T50                            	; Default on. thermistatic control on above 50C
            ; Extruder 2 Fan
            M950 F2 C"22.out1" Q500                         ; Part cooling fan
            M106 P2 S0 B0.1 H-1                             ; Default off. booststart for 0.1s (B0.1); thermostatic control off
            M950 F3 C"22.out2" Q500                         ; Hotend cooling fan
            M106 P3 S0 H2 T50                            	; Default on. thermistatic control on above 50C
            ; Extruder 1 Tool
            M563 P0 S"Extruder-1" D0:1 H1 F0
            M567 P0 E1:1									; mixing
            G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
            G10 P0 X0 Y76 Z0 								; Reset tool axis offsets
            ; Extruder 2 Tool
            M563 P1 S"Extruder-2" D2:3 H2 F2 				; define tool 1
            M567 P1 E1:1									; mixing
            G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
            G10 P1 X0 Y76 Z0 								; Reset tool axis offsets
            ; Retraction
            ;M207 S6.5 R0.0 F4800 T4800 Z0.0
            M207 S4 R0.0 F3000 T2100 Z0.4
            	; M207: Set retract length
            	; Parameters
                ; 	Pn Tool number (optional, supported in RRF 3.01 and later only)
            	; 	Snnn positive length to retract, in mm
            	; 	Rnnn positive or negative additional length to un-retract, in mm, default zero
            	; 	Fnnn retraction feedrate, in mm/min
            	; 	Tnnn feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)
            	; 	Znnn additional zlift/hop
            	; Example: M207 S4.0 F2400 Z0.075
            ; FEEDRATE CONVERSIONS
            	; 20mm/s = F1200	; 100mm/s = F6000
            	; 35mm/s = F2100	; 120mm/s = F7200
            	; 50mm/s = F3000	; 133mm/s = F8000
            	; 70mm/s = F4200
            ; * ======= tool offsets ======== *
            ; Set in config-override.g
            ;G10 P0 X0 Y76 Z-21					; T0
            ;G10 P1 X0 Y76 Z-21					; T1
            ; Filament monitors
            ;  ** Rotating
            M591 P3 C"21.io1.in" D0 R30:160 S1
            M591 P3 C"22.io1.in" D2 R30:160 S1
            ;  ** Endstops
            M950 J4 C"!^1.io1.in"		; Input 4 for filament trigger
            M950 J5 C"!^1.io2.in"		; Input 5 for filament trigger
            ; Invoke trigger 1 (M25) when an active-to-inactive edge is detected on input 4 and 5 and a file is being printed from SD card
            M581 T1 P4 S0 R1
            M581 T1 P5 S0 R1
            M572 D0 S0.02 							; pressure advance T0
            M572 D1 S0.02 							; pressure advance T1
            ;M572 D2 S0.05 							; pressure advance T2
            ;M572 D3 S0.05 							; pressure advance T3
            ; Set up the dock indicator switches on the tools.
            M950 J0 C"!^io3.in"					; GpIn 3 = tool 0 dock switch
            M950 J1 C"!^io4.in"					; GpIn 4 = tool 1 dock switch
            ; Z Motors brake
            M950 P0 C"0.out1"
            ; Z Motors brake OFF
            G92 Z0
            G91 					; Relative mode
            M400 					; make sure everything has stopped before we change the motor currents
            M913 Z100	 			; drop motor currents to 20%
            G1 Z0.05
            M400
            G4 P1000								; Pause
            M42 P0 S1 								; Brake oFF
            M911 S23.5 R23.8 P"M42 P0 S0"
            G90
            ;M593 F50							; cancel ringing at 50Hz
            M376 H20							; bed compensation taper
            M501                                ; load saved parameters from non-volatile memory
            ;G29 S1 							; Do not use G29 S1 within config.g, because no Z=0 datum has been established at that point
            G90						; !!! absolute positioning
