    Motors Don't Stop At End Stops
    Using Duet Controllers
    291
      Can you send M122 and M98 P"config.g" and post the results please?
      I wonder if your firmware version matches your config.
      Jonathan Buildsundefined 1 Reply Last reply Reply Quote 0
      • Jonathan Buildsundefined
        Jonathan Builds
          Jonathan Builds @Phaedrux
            Those warnings would indicate a mismatch between your firmware and your config.
            The config you posted is for RRF2, but it doesn't have the commands that are showing the warnings. Are you sure that the config you posted is the config you're using in the system folder?
            Your firmware is quite out of date.
            If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
            That will get your firmware and DWC up to date.
            You can see the change logs here:
            https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
            For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
            https://configtool.reprapfirmware.org/Start
            Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
            These documents will come in handy during the conversion.
            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
            https://duet3d.dozuki.com/Wiki/Gcode
              @Phaedrux I have uploaded the first .zip however during the upload an error appeared saying that some files were not uploaded because they were not suitable for the board... Is this still alright?
                Jonathan Builds
                  Yes it looks like you're on 3.2.2 now.
                  Your DWC doesn't look like it's updated yet. Or you're still using an old URL that is pointing to the older version.
                  Can you connect to DWC by just the ip address of the Duet?
                  You can check the DWC version as well in one of the tab views on DWC.
                  You can upload the 3.2.2 zip file again. Sometimes it won't all update on the first attempt.
                    @Phaedrux f30200ba-6ac7-4907-bce9-41b6b77763be-image.png M122
                    RepRapFirmware for Duet 2 Maestro version 3.2.2 running on Duet Maestro 1.0
                    Board ID: 08DJM-9X66L-LG3SN-6JTDJ-3S06Q-T8X2P
                    Used output buffers: 1 of 24 (19 max)
                    Static ram: 22284
                    Dynamic ram: 66232 of which 40 recycled
                    Never used RAM 26276, free system stack 222 words
                    Tasks: NETWORK(ready,254) HEAT(blocked,353) TMC(blocked,117) MAIN(running,498) IDLE(ready,21)
                    Owned mutexes:
                    Last reset 00:01:13 ago, cause: software
                    Last software reset details not available
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 37.2, current 37.4, max 38.1
                    Supply voltage: min 0.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 50, reads 12270, writes 6, timeouts 0, DMA errors 0
                    Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 50, reads 12270, writes 6, timeouts 0, DMA errors 0
                    Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 49, reads 12270, writes 6, timeouts 0, DMA errors 0
                    Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 49, reads 12270, writes 6, timeouts 0, DMA errors 0
                    Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 47, reads 12270, writes 6, timeouts 0, DMA errors 0
                    Driver 5: position 0, assumed not present
                    Driver 6: position 0, assumed not present
                    Date/time: 2021-03-27 17:35:43
                    Slowest loop: 98.76ms; fastest: 0.17ms
                    === Storage ===
                    Free file entries: 10
                    SD card 0 detected, interface speed: 15.0MBytes/sec
                    SD card longest read time 0.9ms, write time 95.4ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Bed heaters = 0 -1, chamberHeaters = -1 -1
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 98.79ms; fastest: 0.02ms
                    HTTP sessions: 1 of 8
                    Interface state active, link 100Mbps full duplex
                      Jonathan Builds
                      5ac9972c-b988-4445-ad6e-86e8df41f990-image.png This may be the issue
                        Your DWC is still not updated. I think you will need to manually update it by pulling the SD card from the duet and using your PC to replace the /www folder.
                        Download this zip file and use it to replace the contents of the /www folder on the SD card.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
                        As for your config and homing files I suggest you use the config tool linked above to generate a new set for RRF3.
                          Jonathan Builds
                          Thanks for all the help, I have now got it all updated and looks to be the new version, whole new web GUI... end stops now work perfectly, cannot thank you enough for the help. 👍
                            No problem. Glad we got you sorted.
