    12V Fans with 24V Setup
    • cosmowaveundefined
      cosmowave
      Hello, i'm completely new in the world of Duet3D.
      I have a question about 12V Fans in a 24V Setup.
      I think, it should be possible to supply only the Fans with a separate 12VDC Power Supply? Like in the following picture?
      Note: This scheme is simplified! I know, that the Duet also needs the GND connection! 😉
      But can you confirm me, that this setup will work?
      Will also the "allways on" Fans powered with 12VDC in this setup?
      An other question:
      I have a water cooled hotend. My cooling circuit has a flow detector and i'd like to stop the printing process when no flow is detected.
      The flow sensor is acting like a (normally open) switch.
      Is it possible to connect the flow sensor to the E1 Endstop and stopping the running print with it?
      I think, with the correct mapping and programming it should be possible?
      Thanks for your answer. And also thanks for developing this awesome hard-/ software!
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      cosmowaveundefined OwenDundefined bruceundefined 3 Replies Last reply Reply Quote 0
        cosmowave @cosmowave
        Edit: there is a fault on the scheme!
        The Box in the 12VDC Supply should not be 24V!
        • OwenDundefined
          OwenD @cosmowave
          @cosmowave said in 12V Fans with 24V Setup:
          question:
          The duet documentation covers this here
          https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
          • bruceundefined
            bruce @cosmowave
            @cosmowave
            You need something like this
            https://www.amazon.co.uk/QLOUNI-Converter-3-0-40V-Adjustable-Regulator/dp/B077VW4BTY
