    Unstable Duet 2 wifi - returns procedure for PCB?
    Order discussion
    • rayhudsonundefined
      rayhudson
      hello please advise how to return a faulty item
      It was purchased to replace a like for like PCB, however the WiFi element of this new board is unstable, tried all the advice links, plus finally tried the SIM from the old board, connected for ma moment this become unstable again
        Where and when was the Duet 2 purchased?
        Can you please provide the results of M122?
        What error messages do you get if any?
        Does the blue LED on the wifi module go out when you're having connection issues?
        rayhudsonundefined 1 Reply Last reply Reply Quote 0
          rayhudson @Phaedrux
          @phaedrux
          Order #89981 from ooziest 31/3/2021
          The unit was installed and instructions followed, no amount of trying allowed me to connect to the local wifi, followed the protocols suggested.
          Note: this was a direct replacement board, the previous board worked fine in the communications area with wifi, it only failed on one of the blower fan outlets, all other aspects were ok.
          As a final test the sim was placed in from this board into the new board, for about 10 seconds it connected to the wifi then dropped out, the existing aerial and the new were tried.
          I also managed to get a connection with a hot spot from the phone, however this required the phone to be sitting on top of your new module and was not possible to connect to a computer.
          At this point the cost o my time was to great compared to the time trying to get a defective board operating.
          Exchanged back to the old board - this worked straight away, wit the original B lower Fan fault.
          Please allow me to return this board as it is clearly faulty, im sure i have the legal right to do this!
          Regards
          Ray Hudson
          07973210963
          ray@rhldorect.com
            rayhudson @rayhudson
            @rayhudson Also the original board that we only have running for two weeks also failed! This was due to a plastic jam on the plate that resulted in the blower wires being pulled ou=t from the motor and shorting, the on board fuses did not blow, however the power out to the No ) blower motor no longer works, shows 24v however does mot drive the motor, can we return this one as well. Iv currently put this one back on and running with B1 output, however this is not a solution as i have 2 printer heads
              @rayhudson In the meantime i am returning the board that has wifi issues, this is being sent today via DPD
                Please contact oozenest and initiate a warranty exchange. Include a link to this thread as authorization.
