    New experimental firmware 1.19beta11
    Firmware installation
    14
    74
    8.6k
      deckingman
      Next problem. What's happened with G30? That's how I've always homed my Z axis - don't do any sort of flatness or level compensation. So my home Z is simply move up 5mm, move the centre of the bed, heat the hot end slightly to 140 to soften any blobs, then do G30, move back up 5mm and turn off the heater. Now when I try it, crazy things happen and it's all to do with G30.
      So if I home X and Y, move the head to the centre of the bed then do G30, X and Y travel towards zero (but don't stop when they hit a switch, and Z simultaneously moves down (negative) seemingly forever but I have top hit emergency stop.
      Edit. Oh and after an emergency stop, DWC asks to reset the firmware, I say yes, but the machine remains halted and I have to cycle the power to clear it.
        Read the upgrade notes for beta 10.
          deckingman
          Yes, found it. Deleted deploy probe and retract probe files and that has fixed it. Too much happening at once what with my fairly major machine upgrades as well as trying to keep abreast of all the firmware changes. Starting to feel my age….........
          • larsundefined
            lars
            I get alot of ajax timeout errors. Feels like its every other minute…
            To get it to work again I have to M552 S0 and M552 S1
            Browser console:
            /rr_download?name=0:/sys/oem.json Failed to load resource: the server responded with a status of 404 (not found)
            /rr_status?type=2 Failed to load resource: net::ERR_CONNECTION_TIMED_OUT
            /rr_status?type=3 Failed to load resource: net::ERR_ADDRESS_INVALID
            /rr_connect?password=xxxxx&time=2017-7-29T14%3A55%3A56 Failed to load resource: net::ERR_INTERNET_DISCONNECTED
            /rr_status?type=1 Failed to load resource: net::ERR_CONNECTION_TIMED_OUT
            /rr_connect?password=xxxxx&time=2017-7-29T15%3A37%3A45 Failed to load resource: net::ERR_ADDRESS_UNREACHABLE
              The 404 error trying to load oem.json is normal, but the other errors are not. If the wifi module disconnects from the access point then it should try to reconnect automatically, so DWC should be able to reconnect after 20 seconds or so without having to use M552. I'll test the auto reconnect functionality in WiFiServer beta 10.
              Have you tried increasing the number of retries configured in DWC? The default is 1.
              • larsundefined
                lars
                Retry count was 1, I increased it to 2. Doubt it will help. the duet stops responding to ping and will not start responding in the 20 sec you stated. I get nothing on the panel duo console until I do the M552 S0.
                Pinging every second when getting ajax timeout:
                64 bytes from 192.168.1.167: icmp_seq=673 ttl=128 time=2.905 ms
                64 bytes from 192.168.1.167: icmp_seq=674 ttl=128 time=2.662 ms
                64 bytes from 192.168.1.167: icmp_seq=675 ttl=128 time=6.049 ms
                64 bytes from 192.168.1.167: icmp_seq=676 ttl=128 time=2.209 ms
                64 bytes from 192.168.1.167: icmp_seq=677 ttl=128 time=2.081 ms
                64 bytes from 192.168.1.167: icmp_seq=678 ttl=128 time=3.954 ms
                64 bytes from 192.168.1.167: icmp_seq=679 ttl=128 time=2.033 ms
                Request timeout for icmp_seq 680
                Request timeout for icmp_seq 681
                Request timeout for icmp_seq 682
                Request timeout for icmp_seq 683
                Request timeout for icmp_seq 684
                Request timeout for icmp_seq 685
                Request timeout for icmp_seq 686
                Request timeout for icmp_seq 687
                Request timeout for icmp_seq 688
                Request timeout for icmp_seq 689
                Request timeout for icmp_seq 815
                Request timeout for icmp_seq 816
                Request timeout for icmp_seq 817
                Request timeout for icmp_seq 818
                Request timeout for icmp_seq 819
                Request timeout for icmp_seq 857
                Request timeout for icmp_seq 858
                Request timeout for icmp_seq 859
                Request timeout for icmp_seq 860
                Request timeout for icmp_seq 861
                Request timeout for icmp_seq 862
                ping: sendto: No route to host
                Request timeout for icmp_seq 863
                ping: sendto: Host is down
                Request timeout for icmp_seq 864
                Request timeout for icmp_seq 865
                Request timeout for icmp_seq 866
                Request timeout for icmp_seq 867
                Request timeout for icmp_seq 868
                Request timeout for icmp_seq 869
                Request timeout for icmp_seq 1829
                Request timeout for icmp_seq 1830
                • adri84djundefined
                  adri84dj
                  Hello david,
                  Today I have free time I have tried the emergency stop again. It seems to only affect when doing a G29. If an emergency stop is made while running a G29, the printer stops and the firmware restarts, but it is still in the "HALTED" state and the power must be removed to restore its state.
                  I repeat, it just seems to happen if an emergency stop is made while running a G29
                  a greeting
                    Thanks, I'll see if I can reproduce that.
                    • eddygaraundefined
                      eddygara
                      So after updating to this firmware, my board as become completely unresponsive over night. initially it worked, but the web server kept crashing, as of this morning, the board, can not connect via wifi, or pointerface. As well as after to trying to attempt the Fallback procedure #3 I cant get the board to connect to SAM-BA.
                      I already followed the directions to a T
                        Does the Bossa Port appear in Device Manager after you press Erase for one second, then release it and press Reset?
                        Windows has a habit of disabling USB ports, so if it doesn't appear, try a different USB port or reboot Windows.
                        HTH David
                        • eddygaraundefined
                          eddygara
                          Got it seems like I needed a different cable.
                          • percarundefined
                            percar
                            I installed 1.19 beta 11….I have something weird happening when I do a home all.....the x axis goes by the end stop switch and the x axis stalls....this does not always happen.....when I do a home on just the x axis there seems to be no problem.....the home all script I use is just calling the homex.g homey.g and homez.g files...so this shouldn't be a problem...maybe a bit of a bug
                              Read the upgrade notes, in particular the bit about deployprobe.g and retractprobe.g files.
                              • eddygaraundefined
                                eddygara
                                new issue is with the duet not being able to find the its own access point. Though the board communicates with with my PC, and even confirms connectivity. I have no way of accessing the web server. This all worked perfectly while running firmware 1.17e
                                Now even after reverting back too my old firmware the duet wont seem to want to connect to the web server. Every time i look into my list of available networks the DuetWifi network shows even after ive already went through the set up. And it will keep showing the DuetWfif network as open no matter how many times i connect it to my internet network.
                                • percarundefined
                                  percar
                                  I do use a deployable bed probe so I require the two files….it is a Cartesian printer so this should not be an issue.
                                  • eddygaraundefined
                                    eddygara
                                    every time i try to connect my duet too my network, instead of getting an Ip address i get this
                                    READ: DuetWiFiServer version 1.03 (ch fork)
                                    READ: Flash size 4194304, free RAM 30544 bytes, WiFi Vcc 3.16V, host name: duetwifi, reset reason: Turned on by main processor
                                    READ: WiFi is running as an access point with name DuetWiFi
                                    I still then have an access point for the Duet available to connect too, even after performing the procedure over multiple times times
                                      @eddygara:
                                      Did you do a simultaneous upgrade of the main and the WiFi firmware as described at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta ?
                                      • pta00066undefined
                                        pta00066
                                        I just setup my delta with a new DuetWifi I just purchased and it has been a struggle.
                                        I kept having JSON errors and was unable to use the web server, consistently it would switch from being in AP mode and back to being associated with my AP depending on it's mood when I would restart.
                                        So I upgraded to 1.19beta11 following the instructions in the document. I used M997 S0:1 to do the upgrade of both firmwares.
                                        So now it crashes with JSON shortly after opening the web page.
                                        "× Communication Error
                                        An AJAX error has been reported, so the current session has been terminated.
                                        Please check if your printer is still on and try to connect again.
                                        Error reason: SyntaxError: Unexpected token a in JSON at position 65"
                                        So I put it back to 1.18.1 and had the same issues. I erased the firmware and reloaded using the SAM-BA tool and I upgraded to the beta again and I still have the same problems.
                                        This is disappointing.
                                        Firmware Name: RepRapFirmware for Duet WiFi
                                        Firmware Electronics: Duet WiFi 1.0
                                        Firmware Version: 1.19beta11 (2017-07-25)
                                        Web Interface Version: 1.17+2
                                        Web Interface by Christian Hammacher
                                        No matter what I have done has not worked as of yet.
                                        Please help I ordered your system because it looked to be the best integrated most complete…....
                                          I'm sorry to hear of your troubles. I need to see the faulty JSON response to see why it isn't working. Please can you do one of the following:
                                          1. In Chrome press control-shift-J to get the debugging console, then try to connect. It should pause on the exception. If you go to the network tab you should find the JSON message that it couldn't parse. Please post it.
                                          2. Load Wireshark on your PC and get a WireShark trace of the connection attempt, then post the .pcap file from Wireshark to a file sharing site and post the link to it.
                                          Also please make your config.g file available.
                                          • eddygaraundefined
                                            eddygara
                                            @dc42:
                                            @eddygara:
                                            Yeah in every instance I would do a simultaneous upgrade. The duet just fails to connect to its web server.
