    New experimental firmware 1.19beta11
    Firmware installation
    14
    74
    8.6k
      The 404 error trying to load oem.json is normal, but the other errors are not. If the wifi module disconnects from the access point then it should try to reconnect automatically, so DWC should be able to reconnect after 20 seconds or so without having to use M552. I'll test the auto reconnect functionality in WiFiServer beta 10.
      Have you tried increasing the number of retries configured in DWC? The default is 1.
      • larsundefined
        lars
        Retry count was 1, I increased it to 2. Doubt it will help. the duet stops responding to ping and will not start responding in the 20 sec you stated. I get nothing on the panel duo console until I do the M552 S0.
        Pinging every second when getting ajax timeout:
        64 bytes from 192.168.1.167: icmp_seq=673 ttl=128 time=2.905 ms
        64 bytes from 192.168.1.167: icmp_seq=674 ttl=128 time=2.662 ms
        64 bytes from 192.168.1.167: icmp_seq=675 ttl=128 time=6.049 ms
        64 bytes from 192.168.1.167: icmp_seq=676 ttl=128 time=2.209 ms
        64 bytes from 192.168.1.167: icmp_seq=677 ttl=128 time=2.081 ms
        64 bytes from 192.168.1.167: icmp_seq=678 ttl=128 time=3.954 ms
        64 bytes from 192.168.1.167: icmp_seq=679 ttl=128 time=2.033 ms
        Request timeout for icmp_seq 680
        Request timeout for icmp_seq 681
        Request timeout for icmp_seq 682
        Request timeout for icmp_seq 683
        Request timeout for icmp_seq 684
        Request timeout for icmp_seq 685
        Request timeout for icmp_seq 686
        Request timeout for icmp_seq 687
        Request timeout for icmp_seq 688
        Request timeout for icmp_seq 689
        Request timeout for icmp_seq 815
        Request timeout for icmp_seq 816
        Request timeout for icmp_seq 817
        Request timeout for icmp_seq 818
        Request timeout for icmp_seq 819
        Request timeout for icmp_seq 857
        Request timeout for icmp_seq 858
        Request timeout for icmp_seq 859
        Request timeout for icmp_seq 860
        Request timeout for icmp_seq 861
        Request timeout for icmp_seq 862
        ping: sendto: No route to host
        Request timeout for icmp_seq 863
        ping: sendto: Host is down
        Request timeout for icmp_seq 864
        Request timeout for icmp_seq 865
        Request timeout for icmp_seq 866
        Request timeout for icmp_seq 867
        Request timeout for icmp_seq 868
        Request timeout for icmp_seq 869
        Request timeout for icmp_seq 1829
        Request timeout for icmp_seq 1830
        • adri84djundefined
          adri84dj
          Hello david,
          Today I have free time I have tried the emergency stop again. It seems to only affect when doing a G29. If an emergency stop is made while running a G29, the printer stops and the firmware restarts, but it is still in the "HALTED" state and the power must be removed to restore its state.
          I repeat, it just seems to happen if an emergency stop is made while running a G29
          a greeting
            Thanks, I'll see if I can reproduce that.
            • eddygaraundefined
              eddygara
              So after updating to this firmware, my board as become completely unresponsive over night. initially it worked, but the web server kept crashing, as of this morning, the board, can not connect via wifi, or pointerface. As well as after to trying to attempt the Fallback procedure #3 I cant get the board to connect to SAM-BA.
              I already followed the directions to a T
                Does the Bossa Port appear in Device Manager after you press Erase for one second, then release it and press Reset?
                Windows has a habit of disabling USB ports, so if it doesn't appear, try a different USB port or reboot Windows.
                HTH David
                • eddygaraundefined
                  eddygara
                  Got it seems like I needed a different cable.
                  • percarundefined
                    percar
                    I installed 1.19 beta 11….I have something weird happening when I do a home all.....the x axis goes by the end stop switch and the x axis stalls....this does not always happen.....when I do a home on just the x axis there seems to be no problem.....the home all script I use is just calling the homex.g homey.g and homez.g files...so this shouldn't be a problem...maybe a bit of a bug
                      Read the upgrade notes, in particular the bit about deployprobe.g and retractprobe.g files.
                      • eddygaraundefined
                        eddygara
                        new issue is with the duet not being able to find the its own access point. Though the board communicates with with my PC, and even confirms connectivity. I have no way of accessing the web server. This all worked perfectly while running firmware 1.17e
                        Now even after reverting back too my old firmware the duet wont seem to want to connect to the web server. Every time i look into my list of available networks the DuetWifi network shows even after ive already went through the set up. And it will keep showing the DuetWfif network as open no matter how many times i connect it to my internet network.
                        • percarundefined
                          percar
                          I do use a deployable bed probe so I require the two files….it is a Cartesian printer so this should not be an issue.
                          • eddygaraundefined
                            eddygara
                            every time i try to connect my duet too my network, instead of getting an Ip address i get this
                            READ: DuetWiFiServer version 1.03 (ch fork)
                            READ: Flash size 4194304, free RAM 30544 bytes, WiFi Vcc 3.16V, host name: duetwifi, reset reason: Turned on by main processor
                            READ: WiFi is running as an access point with name DuetWiFi
                            I still then have an access point for the Duet available to connect too, even after performing the procedure over multiple times times
                              @eddygara:
                              Did you do a simultaneous upgrade of the main and the WiFi firmware as described at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta ?
                              • pta00066undefined
                                pta00066
                                I just setup my delta with a new DuetWifi I just purchased and it has been a struggle.
                                I kept having JSON errors and was unable to use the web server, consistently it would switch from being in AP mode and back to being associated with my AP depending on it's mood when I would restart.
                                So I upgraded to 1.19beta11 following the instructions in the document. I used M997 S0:1 to do the upgrade of both firmwares.
                                So now it crashes with JSON shortly after opening the web page.
                                "× Communication Error
                                An AJAX error has been reported, so the current session has been terminated.
                                Please check if your printer is still on and try to connect again.
                                Error reason: SyntaxError: Unexpected token a in JSON at position 65"
                                So I put it back to 1.18.1 and had the same issues. I erased the firmware and reloaded using the SAM-BA tool and I upgraded to the beta again and I still have the same problems.
                                This is disappointing.
                                Firmware Name: RepRapFirmware for Duet WiFi
                                Firmware Electronics: Duet WiFi 1.0
                                Firmware Version: 1.19beta11 (2017-07-25)
                                Web Interface Version: 1.17+2
                                Web Interface by Christian Hammacher
                                No matter what I have done has not worked as of yet.
                                Please help I ordered your system because it looked to be the best integrated most complete…....
                                  I'm sorry to hear of your troubles. I need to see the faulty JSON response to see why it isn't working. Please can you do one of the following:
                                  1. In Chrome press control-shift-J to get the debugging console, then try to connect. It should pause on the exception. If you go to the network tab you should find the JSON message that it couldn't parse. Please post it.
                                  2. Load Wireshark on your PC and get a WireShark trace of the connection attempt, then post the .pcap file from Wireshark to a file sharing site and post the link to it.
                                  Also please make your config.g file available.
                                  • eddygaraundefined
                                    eddygara
                                    @dc42:
                                    @eddygara:
                                    Yeah in every instance I would do a simultaneous upgrade. The duet just fails to connect to its web server.
                                    • Dougal1957undefined
                                      Dougal1957
                                      And also did you copy the DWC Files into /www on the SD Card?
                                        @pta00066:
                                        Error reason: SyntaxError: Unexpected token a in JSON at position 65"...
                                        By chance I just received this exact message while testing beta 12 firmware. The condition under which it happens is that the XYZ position can't be computed because it is impossible. The way I provoked it was to use very low motor currents that didn't reliably trigger the endstop switches, so that the apparent length of the homing move made by one tower created a geometrically impossible position.
                                        I'll fix this in beta 12. In the meantime, my suspicion is that you have a delta printer, and the M665 parameters you have specified are physically impossible - in which case the problem will go away if you correct them. Please share your config.g file.
                                        • eddygaraundefined
                                          eddygara
                                          @Dougal1957:
                                          Yes sir re Bob. But not change in allowing me to connect to the server. I'm every instance. It shows a duetwifi network. I'll connect to the network. I'll turn off then on the duet wifi connection. And then it won't connect. I'll get a message saying the duet as connected to a network with the access point name duetwifi. But not my wifi network or ip adress.
                                            Please confirm that you are running DuetWiFiFirmware 1.19beta11, DuetWiFiServer 1.19 beta 10, and DWC 1.17+2, and that you have programmed your access point details as described at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta. You can verify the SSID name by sending command M587. [Edit: or perhaps you are running firmware 1.18.2 now?]
                                            I've heard a previous case of a router blacklisting the MAC address of the Duet WiFi. In that case, resetting the router cleared the problem.
