3HC Boot Issues
I attempted adding a 30 second delay using G4 and still have had no luck.
@flavamuffin Did you try 3.3 beta 2?
@pkos I have yet to try that that. I will later today and see if it remedies the problem.
@flavamuffin said in 3HC Boot Issues:
If you install 3.3beta2 on the expansion board, you will also need to use 3.2beta2 on the main board, otherwise you will get only partial functionality.
A symptom of the slow startup issue is that after powering up the 3HC, the red LED stays off for a noticeable period of time, several seconds or more. Do you observe that?
@dc42 I have updated to 3.3beta2 on both boards and the problem still persists. I presume the red LED you are referring to is the diagnostic one by the RJ11 ports. That one remains off for roughly a minute after startup. Before updating from 3.2.2 to the 3.3beta2 it immediately started flashing in time with the main board once lit. Now it flashes rapidly for about 1 second after it initially lights up before flashing in time with the main board. If I am wrong in my presumption about which LED you are referring to, and you do mean the one on the corner of the board next to the other LEDs; that one turns on immediately.
@flavamuffin thanks, I did mean the LED between the CAN ports. Which country are you in?
@dc42 I am in the USA.
@flavamuffin, I am still trying to track down what causes this slow startup issue on a few boards, but unfortunately I still do not have a board that exhibits this issue. So I am having to make guesses about what is causing it.
Please can you try the Duet3Firware_EXP3HC.bin file at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0. This should identify itself (using M115 B1) as "Duet EXP3HC firmware version 3.3beta2+2 (2021-04-16 07:53:14)".
If that firmware still shows the slow startup issue, please try the firmware at https://www.dropbox.com/sh/fgpjmta9fut21gb/AADgv9v7MRqywjFj9vOXLvOra?dl=0. This should identify itself as "Duet EXP3HC firmware version 3.3beta2+2-12MHz (2021-04-16 08:04:22)".
If that also exhibits the slow startup issue, please contact your supplier to have your board replaced under warranty.
By "slow startup", I mean that after applying power the red LED between the CAN connectors takes longer than about a second to start flashing.
Do not attempt to update the bootloader on your EXP3HC.
@dc42 Firmware version 3.3beta2+2 did not seem to have any effect on the problem. Version 3.3beta2+2-12MHz seems to have worsened the issue. It causes the board to take several minutes to initialize. I am going to start an inquiry with my supplier about replacing the board.
@flavamuffin, thanks for trying those. I authorize a warranty replacement for your board.
@dc42 Thanks for all your help! I hope you end up finding the cause for the issue.
