    Show M950 J-inputs
    Duet Web Control wishlist
    • khenderickundefined
      khenderick
      Using M950 one can setup various J-inputs. This could for example be used for tool detection (are all tools docked). These J-inputs can then later be used as source for M581 triggers.
      For debugging purposes, and for general overview (such as on a toolchanger), it would be nice if DWC would show the current state of these J-inputs.
      This could be designed as an extra line in the status-box (below "speeds" and "sensors") where it shows J0, J1, J2, ... (as configured) together with there state. As an alternative it could be added in the tools-box under the "extra" part. This first (inside the status-box) would be preferred to have it always visible.
        dc42 administrators @khenderick
        @khenderick, you can see the current state if you go to the Object Model browser in DWC and navigate to sensors.gpIn.
        khenderickundefined 1 Reply Last reply Reply Quote 0
          khenderick @dc42
          @dc42 This is indeed interesting for debugging, nice 🙂 .
          For a more general overview, another solution could be to implement something more generic where certain entries of the object model could be persisted on the dashboard (either with manual refresh or some kind of automatic refresh (e.g. every second, every 5 seconds, ...)).
            Sounds like a candidate for a DWC plugin.
            • o_lampeundefined
              o_lampe @khenderick
              @khenderick said in Show M950 J-inputs:
              I believe, you could poll the sensors in question with M582 in daemon.g and send an echo to your screen with the result?
