    New experimental firmware 1.19beta11
    Firmware installation
    14
    74
    8.6k
      Read the upgrade notes, in particular the bit about deployprobe.g and retractprobe.g files.
      • eddygaraundefined
        eddygara
        new issue is with the duet not being able to find the its own access point. Though the board communicates with with my PC, and even confirms connectivity. I have no way of accessing the web server. This all worked perfectly while running firmware 1.17e
        Now even after reverting back too my old firmware the duet wont seem to want to connect to the web server. Every time i look into my list of available networks the DuetWifi network shows even after ive already went through the set up. And it will keep showing the DuetWfif network as open no matter how many times i connect it to my internet network.
        • percarundefined
          percar
          I do use a deployable bed probe so I require the two files….it is a Cartesian printer so this should not be an issue.
          • eddygaraundefined
            eddygara
            every time i try to connect my duet too my network, instead of getting an Ip address i get this
            READ: DuetWiFiServer version 1.03 (ch fork)
            READ: Flash size 4194304, free RAM 30544 bytes, WiFi Vcc 3.16V, host name: duetwifi, reset reason: Turned on by main processor
            READ: WiFi is running as an access point with name DuetWiFi
            I still then have an access point for the Duet available to connect too, even after performing the procedure over multiple times times
              @eddygara:
              Did you do a simultaneous upgrade of the main and the WiFi firmware as described at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta ?
              • pta00066undefined
                pta00066
                I just setup my delta with a new DuetWifi I just purchased and it has been a struggle.
                I kept having JSON errors and was unable to use the web server, consistently it would switch from being in AP mode and back to being associated with my AP depending on it's mood when I would restart.
                So I upgraded to 1.19beta11 following the instructions in the document. I used M997 S0:1 to do the upgrade of both firmwares.
                So now it crashes with JSON shortly after opening the web page.
                "× Communication Error
                An AJAX error has been reported, so the current session has been terminated.
                Please check if your printer is still on and try to connect again.
                Error reason: SyntaxError: Unexpected token a in JSON at position 65"
                So I put it back to 1.18.1 and had the same issues. I erased the firmware and reloaded using the SAM-BA tool and I upgraded to the beta again and I still have the same problems.
                This is disappointing.
                Firmware Name: RepRapFirmware for Duet WiFi
                Firmware Electronics: Duet WiFi 1.0
                Firmware Version: 1.19beta11 (2017-07-25)
                Web Interface Version: 1.17+2
                Web Interface by Christian Hammacher
                No matter what I have done has not worked as of yet.
                Please help I ordered your system because it looked to be the best integrated most complete…....
                  I'm sorry to hear of your troubles. I need to see the faulty JSON response to see why it isn't working. Please can you do one of the following:
                  1. In Chrome press control-shift-J to get the debugging console, then try to connect. It should pause on the exception. If you go to the network tab you should find the JSON message that it couldn't parse. Please post it.
                  2. Load Wireshark on your PC and get a WireShark trace of the connection attempt, then post the .pcap file from Wireshark to a file sharing site and post the link to it.
                  Also please make your config.g file available.
                  • eddygaraundefined
                    eddygara
                    @dc42:
                    @eddygara:
                    Yeah in every instance I would do a simultaneous upgrade. The duet just fails to connect to its web server.
                    • Dougal1957undefined
                      Dougal1957
                      And also did you copy the DWC Files into /www on the SD Card?
                        @pta00066:
                        Error reason: SyntaxError: Unexpected token a in JSON at position 65"...
                        By chance I just received this exact message while testing beta 12 firmware. The condition under which it happens is that the XYZ position can't be computed because it is impossible. The way I provoked it was to use very low motor currents that didn't reliably trigger the endstop switches, so that the apparent length of the homing move made by one tower created a geometrically impossible position.
                        I'll fix this in beta 12. In the meantime, my suspicion is that you have a delta printer, and the M665 parameters you have specified are physically impossible - in which case the problem will go away if you correct them. Please share your config.g file.
                        • eddygaraundefined
                          eddygara
                          @Dougal1957:
                          Yes sir re Bob. But not change in allowing me to connect to the server. I'm every instance. It shows a duetwifi network. I'll connect to the network. I'll turn off then on the duet wifi connection. And then it won't connect. I'll get a message saying the duet as connected to a network with the access point name duetwifi. But not my wifi network or ip adress.
                            Please confirm that you are running DuetWiFiFirmware 1.19beta11, DuetWiFiServer 1.19 beta 10, and DWC 1.17+2, and that you have programmed your access point details as described at https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta. You can verify the SSID name by sending command M587. [Edit: or perhaps you are running firmware 1.18.2 now?]
                            I've heard a previous case of a router blacklisting the MAC address of the Duet WiFi. In that case, resetting the router cleared the problem.
                            • eddygaraundefined
                              eddygara
                              fixed it thanks everyone!!!
                              • pta00066undefined
                                pta00066
                                Thanks I have it working reliably now.
                                It was the config not sure what was wrong I reran the web configurator and the problem went away.
                                @dc42:
                                @pta00066:
                                • Forgvn77undefined
                                  Forgvn77
                                  I'm having some quirky and unnerving behavior in 1.19beta11 when I switch tools on my diamond hot end delta. Sometimes the printer will quietly switch and sometimes it makes alarming noises while it retracts and extracts back and forth very quickly. I'm not sure why it does one or the other. My tools definitions are as follows:
                                  ; Tool definitions
                                  M92 E60.28:60.28:60.28 ; Set extruder steps per mm
                                  M207 S3.75 F3000 ; set firmware retraction
                                  M563 P0 D0:1:2 H1 ; Define tool 0
                                  G10 P0 X0 Y0 ; Set tool 0 axis offsets
                                  M568 P0 S1 ; Enable mixing for tool 0
                                  M567 P0 E0.90:0.05:0.05 ; Set mixing ratios for tool 0 (90%,5%,5%)
                                  M563 P1 D0:1:2 H1 ; Define tool 1
                                  G10 P1 X0 Y0 ; Set tool 1 axis offsets
                                  G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                                  M568 P1 S1 ; Enable mixing for tool 1
                                  M567 P1 E0.05:0.90:0.05 ; Set mixing ratios for tool 1 (5%,90%,5%)
                                  M563 P2 D0:1:2 H1 ; Define tool 2
                                  G10 P2 X0 Y0 ; Set tool 2 axis offsets
                                  G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
                                  M568 P2 S1 ; Enable mixing for tool 2
                                  M567 P2 E0.05:0.05:0.90 ; Set mixing ratios for tool 2 (5%,5%,90%)
                                  M563 P3 D0:1:2 H1 ; Define tool 3
                                  G10 P3 X0 Y0 ; Set tool 3 axis offsets
                                  G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
                                  M568 P3 S1 ; Enable mixing for tool 3
                                  M567 P3 E0.34:0.33:0.33 ; Set mixing ratios for tool 3 (34%,33%,33%)
                                  T3 ; select tool 3 (evenly mixed)
                                  I also seem to be having more problems with filaments jamming when I extrude single colors as opposed to evenly mixed which is working without issue.
                                  John
                                  Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                                  Make A Difference!
